Question about RCA D52W19 52" Rear Projection Television
Rca tv d52w19 shuts-off
I have seen a spark coming from the capacitor on the power board.Do I try replacing the capacitor or is there more to it than that?
870 nano farrod capacitor 2000vdc
    President:
  • 1,099 Answers
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These capacitors alway bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.
use the same type of value to replace.
Good luck...
Posted on May 25, 2010
When power it'll blink three times and shuts off
It is probably the power board. When the capacitors on the board fail they can make a hissing noise. If you look at the board and the small cylindrical things on the board ( which are the capacitors) are bulged on top instead of flat this indicates a failed capacitor. The board should then be replaced. Hope this helps.
Jan 01, 2014 | RCA D52W19 52" Rear Projection Television
RCA D52W19 Flat Screen TV capacitor 2200/16 needs replacing. But I can only find 2200/10. Think this is good enough or should I go higher in voltage like 25 or higher?
the common practice is never go down in voltage rating. as a technician i would defintly not go down to 10 volt i suggest you go up 25 would be ok if you can get it to fit
Oct 16, 2010 | RCA D52W19 52" Rear Projection Television
When I push the power button the light comes on then flashes 9 times and turns off, tv never comes on.
CK the deflection board for bad capacitors CP150 2200uf 16v use 25v CP114 CP120 220uf 35v If any of them is vented,puffed up on top then replace all 3 Capacitors.
Deflection Board is bottom left hand side with FBT flyback Transfomer.
Sep 28, 2010 | RCA D52W19 52" Rear Projection Television
Tv doesnt work
CK capacitor cp150 on deflection board if it is puffed up on top it is Bad 2200uf 16v use 25v other 2 caps in same circuit need to be replaced also cp114 cp120 220uf 35v
Sep 16, 2009 | RCA D52W19 52" Rear Projection Television
TV will not power on. Button slowly flashes green several times
CP120, CP114 and CP150 need replacement. You can get replacements at the following link under the RCA parts catagory.
http://servicemanuals.vstore.ca/
Aug 22, 2009 | RCA D52W19 52" Rear Projection Television
My RCA Bigscreen HDTV will not turn on.
If this is similar to the d52w20 then I almost garantee you need to replace a capacitor. You can check to make sure that's what you need by unplugging the tv, taking off the back cover and feeling the top of 3 capacitors. On my d52w20, CP150 (rated at 2200uf 16V) was blown and the top was bulged out. You should also check CP120 and CP114 to see if either are blown. I don't have a clear picture of where it's located, but I have a picture of what you should see after you take off the back cover.
http://i265.photobucket.com/albums/ii209/fillmore85welder/KodakMoment003-1.jpg
In the middle of the picture you see an aluminum heatsink in the shape of a 'C' with the opening facing away from you. That is where CP150 is located. CP120 and CP114 should be located nearby, but if you can feel a bulge on any of the tops of those 3 capacitors replacing them should fix your problem. Replace the existing capacitors with a higher voltage rating of either 25v or 35v.
"4 capacitors on the power/deflection board. CP110 220uf 200v. CP120 220uf 35 Volts. CP114 220uf 35 volts. CP150 2200 16 volt. also check entire delfection board for cold solder especially around flyback. bad connections here can cause problems like some of the fp fuses blowing and cutting off convergence supply"
Jun 02, 2009 | RCA D52W19 52" Rear Projection Television
Rca d52w19 push power flashes 3 times and makes buzz each time
Check capacitors cp150,cp114,cp120 if any of the capacitors are puffed up on top replace all 3 of them 2200uf 16v and (2) 220uf 35v
Feb 14, 2009 | RCA D52W19 52" Rear Projection Television
Rca D52W19 will not come on
CK capacitors cp114,cp120 cp150 they are on the Deflection Board.
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19BYX1
If yu can email me a location number for the capacitor and I will look up the part number for you.
tvtek (@) msn.com
Jun 24, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
119 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
