Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water not working but still makes ice
Water will not come out but the fridge still makes ice. HELP
  • GE Master
  • 1,606 Answers
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE has a dispensor heater pt. # WR49X10173 to keep this from happening again ( comes with instructions ) .
Posted on May 26, 2010
  • 1,384 Answers
THERE ARE 2 SOLENOID ON YOUR FRIDGE ONE FOR THE ICE AND ONE FOR THE WATER . THERE IS A SCREEN ON BOTH ONE MAY BE PLUGGED THERE IN THE BACK IN THE LOWER RIGHT HAND CONNER OF THE FRIDGE .. LOOK FOR THE LITTLE WHITE HOSES AND THE SOLENOID WITH 2 WIRES EACH.. OH AND YOUR FILTER ALSO MAY BE PLUGGED IT'S ON THE INSIDE OF THE FRIDGE SIDE MAY LOOK LIKE A WHITE OIL FILTER..IF'N I WAS ANY HELP AT ALL PLEASE VOTE.. JAY
Posted on May 25, 2010
3 Suggested Answers
  • 23 Answers
SOURCE: ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Posted on Dec 08, 2007
SOURCE: ice maker broken
Our is broken as well. Water dispenser works.....
Posted on Feb 24, 2008
Daewoo frsu20dci fridge freezer, hiya, hope you can help. Our fridge freezer is making ice and dispensing ice but no water is coming out of the water dispenser when pressed. Help!!!
Check your water filter. They are known for clogging up. If that doesn't work...check your water inlet valve.. if that doesn't work check to see if you have a pinch in your waterline.
Jun 25, 2015 | Daewoo Refrigerators
Deawoo fridge freezer FDF-358 freezer is cold, fridge is not getting cold
The freezer section is working,but fridge is not because defrost door is blocked.Its a defrost cycle issue.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
I have a side by side Whirlpool fridge and the ice maker is not working. If I have it turned on (lever down) and door is closed and water leaks out the front of the ice dispenser and it doesn't seem to...
How old is the fridge? Mine lieterally caught on fire at the start device last weekend. My fridge was manufactured in July 2001. Be careful, The fridge I have is model# ED5FHGXKQ00. I am currently requesting a recall be made by Whirlpool on this appliance.
Other than that it could just be that the ice maker line has frozen or the "arm" in the ice chest is stuck and can't raise itself to pump water directly into the ice trays. Either way be very careful. I hope this was helpful.
Jun 10, 2010 | Refrigerators
Ice maker not working. Water is going to fridge,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
68tj
Dec 15, 2009 | Fisher and Paykel Active Smart E522B...
The ice marker does not make ice. Have looked
If theres water in the line going to the fridge and the ice maker works , most of the times the water valve ( solenoid) that opens when the ice maker needs water , is leaking or doesn't work.
Aug 14, 2009 | Refrigerators
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Kenmore Ice Maker Not Making Ice
the water that is frozen in the fill tube could have come from the old water valve that you replaced ,you got to get the ice out, the easiest way ,though not the fastest ,is to unplug fridge for 24 hrs . and leave the doors open to let it defrost, the plug back up and hopefully in 5 or 6 hrs you'll have ice
May 20, 2009 | Freezers
Water dispenser inside fridge and ice maker in freezer part in bottom both quit working.
There can be many reasons for no water supply. Line feeding the refrigerator is clogged or blocked. The water control valve that turns water to ice maker and dispenser is defective or the water filter located inside your refrigerator is in need of change. I will be here to help you go through the steps. Let me know when you are ready, Thanks, Sea Breeze
Apr 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Ice maker not working, water not going in tray.
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
329 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
