Question about Toshiba Tecra M6-EZ6611 Notebook
Memory Stick Installation
How do I add more memory to my Toshiba Tecra M6? Are the memory sticks under the keyboard?
  • 22 Answers
Under neath laptop
Posted on May 26, 2010
Where is thememory in this laptop
Memory stick usually refers to a usb device that can be inserted into the laptop to provide removable storage. This is not part of the laptop. Memory sticks can be purchased as an accessory and can be used on PC's, Laptops or any other device that supports usb memory sticks.
Some people may also refer to the physical memory that is in the laptop as sticks but this is not generally know as stick memory. The physical memory can usually be accessed underneath the laptop by removing a single screw to the door cover. The Dell D610 for example has one memory module on the underside of the laptop and a second located under the keyboard which means the keyboard has to be removed to access.
Nov 29, 2013 | Computers & Internet
Laptop beeps4 times but doesn't come on the monitor or start-up. ights on front of laptop and start button come on but nothing else happens.
In most cases this means bad memory stick. If you are able to, flip over the laptop, find the panel that has the memory under it, unscrew the screw(s) to get the panel off, and pull out the top stick of memory. Flip the laptop back over and power it on. If it works fine again, then that stick was the problem, and you can go buy a replacement and install it back into that slot. If that doesn't fix the issue, turn it off, flip it over, pull the other stick of memory out and put the first stick into that slot. Flip it back upright and turn on again. If that fixes the issue, then the second stick of memory is bad and you can just replace it as well. If neither of those fix the issue please reply on here and we can do further diagnostics.
Jun 30, 2011 | Toshiba Satellite M55-S135 Notebook
I have a screen problem. My Toshiba Tecra M4 has color imbalance because some black or blue colors become red. My laptop technician said there is a problem with the flex cable, but as I researched on the...
Toshiba is famous for overheating problems, blow out your cooling fan with canned air. Also another fairly common issue with the M4 is memory module seating, basically the memory modules/sticks werent put in properly by the factory...i know..go figure. Remove the memory panel from the back of the unit and remove the memory stick/s. Should be 2 of them, be gentle, and then just simply reinstall them back where they were making sure they are seated in the slots firmly, then replace the memory cover and fire it back up. This worked on 4 or 5 ive repaired with similar issues. Hope this helps you as well.
Nov 08, 2017 | Toshiba Tecra M4 Tablet PC
I have an Everex StepNote SA2052T that came with 1GB of memory. can I add another memory stick of 2GB for a total of 3GB. If so, how do I install the second stick and where?
http://couponsdealsfree.com/coupons-everex-stepnote-sa2052t-refurbished-laptop-pc-1604/
According to the specs of this laptop is 1GB Max. So you can't use a 2GB. Also it states that there is only 1 slot for memory. Which means you can not add another stick of memory, you can only add 1 stick to it.
To add you turn the notebook upside down and start to unscrew. look for the 'memory' section. However doing this would be pointless.
If your experiencing slow processing, try to remove programs that you don't use anymore. Make sure some programs don't 'start-up' while your computer is loading.
WARNING*** you are responsible for your own actions
Go to: START > type msconfig > click the 'Startup' tab > Check for unused programs running (example: msn messenger, Uncheck the box; if you don't know that program then don't uncheck it) After your done, click OK and Restart your notebook.
For future information:
  • If you are going to add memory, make sure it is the same type (example: pc5300 on old chip and new chip) otherwise you will burn out the memory.
  • Always check online for your laptop/notebook specs before doing adjustments, otherwise you risk chances of burning out the notebook and or devices your trying to add into it.
  • If you can afford it, buy a new notebook/laptop.
Good luck, and rate my advice.
Dec 16, 2010 | Everex StepNote SA2052T Notebook
How do i load my ipod from a memory stick on my laptop?
The easiest way is to run iTunes on the laptop and use the "add folder" (in iTunes under "FILE" option to add the files from the memory stick to the laptop.
Nov 11, 2009 | Toshiba Satellite A100-S8111TD Notebook
Upgrading memory on Tecra M2
the other memory chip is under the keyboard.
Oct 20, 2009 | Toshiba Tecra M2-S630 Notebook
I have a Toshiba Satellite 1905-S301 that has 512mb of DDR memory currently. I have a stick of 128 that I was going to throw in there to boost performance but when I opened the compartment the there was...
There are 2 types of memory, one for laptops and one for pc.
Your additional stick seems to be for pc from what your saying.
Additional thoughts:
I'm sure you can buy sticks for laptops at walmart or whereever you bought ur laptop. Just make sure it is the same speed type. Example: yours is 512mb ddr PC 5200, you will need to find PC5200, the 512mb and up you shouldnt have to worry about. So do your research before you upgrade or you will burn your laptop.
Sep 09, 2009 | Toshiba Satellite 1905-S301 Notebook
I need to add extra memory now my lap top works with 128 MB i need to be 256 MB
thats no problem sir,u can upgrade the memory cards of the computer to the level which it supports may be 1gb,2gb or 4gb.....
u can purchase another memory stick of same specifications because its availiable is different size like 128Mb,256Mb,512Mb or 1Gb.....you can use any one according to your wish...
Apr 26, 2009 | Toshiba Tecra 8200 PIII-850MHz/ 256MB/...
I have a Toshiba Tecra M2 Laptop. I just installed (2) 1gb ram chips. Bios only shows 1.256 Windows only shows 1.256 Where or how do I access or show 2gb RAM>
This could be bad memory or possibly (but unlikely) a bad memory controller. To test this remove one stick and power it on and look at the size, than switch the pieces of memory and check that one. If they both show 1gb then try each stick in the other slot. If they both do not show 1 gb then there is the problem.
Jan 15, 2009 | Toshiba Tecra M2-S730 Notebook
Dead machine
you need to replace the memory stick it has given up on you !
Mar 22, 2008 | Toshiba Tecra 8100 Notebook
Toshiba Tecra M6-EZ6611 Notebook Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
