Question about Dewalt DW746X 10" woodworker's table saw with rai
My dewalt d27105 saw keeps blowing a fuse, could it be the module
    Problem Solver:
  • 16 Answers
These saws have a rather large amount of draw on a 15 amp breaker... they should be able to operate on a 15 amp breaker, however nothing else can share that breaker.... and if it is an outside plug (GFI) it will be even more likely to trip. If possible, use a 20 amp breaker...they can be found in the garage where central vacuum plugs in. If this isn't an option then ensure nothing else is on a normal 15 amp breaker, use a heavy gauge extension cord, and the shorter the cord the better.
Posted on Jun 20, 2010
My DeWalt D27105 Type 1 did overload. What can I do in order to get it working again? As I see it, it doesn't have an overload protector.
There is no circuit breaker build in.
The are complete carbon brush motors to buy for this model.
If its overloaded the housing the electric field can be damaged .
It
strongly depends on the age of the machine, the old ones have an induction motor, there are specially complete brush motors for replacement.
Which also make the table lighter in weight, and they are fine but one hint foster timely maintenance bearing on the drive side of the armature in these engines, due to the flat drive belt and higher required tension and low cooling over it they quickly called and often have a problem bearing,
Jul 14, 2016 | Dewalt Saws
Where are the brushes in the dewalt 788 20" scroll saw? Mine keeps blowing fuses & I think the brushes need cleaned but don't know how to get to them
Blowing fuses is not caused by brushes unless there is a huge spark show going on and if that is the case your armature will be trashed as well - the electronic module in that saw is notorious for failure and that is where I would start
Nov 23, 2013 | Dewalt DW788 Heavy Duty 20" Variable Speed...
D27105
you have armature problem,burned,shorted
Jun 13, 2012 | Dewalt DW745 10" Compact Job Site Table...
My DeWalt scroll saw will not turn on. Have checked outlets and would like to check fuse. Not sure how to open fuse hatch without risking damage. I keep all manuals but can't locate one for this saw.
take a small screw driver and push down on the clip at the top of the fuse holder, it should open and you cans ip iy out. be sure and replace the fuse with a 3 AMP FAST BLOW ( not a slow blow) oldcodger2
Sep 22, 2011 | Dewalt & Variable Scroll Saw
Whilst using my flipsaw recently it jammed in a peice of timber and tripped the power, whenever I plug it in and try it now it trips the power straight away, it's a Dewalt D27105
Check the saw for freedom of turning motion (by hand). If ok, then you may have a defective circuit breaker. Check by replacement. Hope this helps!
Dec 08, 2010 | Garden
My d27105 is blowing the 13amp fuse in the plug ?
If it continue to do it the machine had a "short circuit".So inspect the machine and look for any brake cable the is touch any metal part of it.
Nov 09, 2010 | Dewalt DW746X 10" woodworker's table saw...
Dewalt flip saw keeps blowing fuse
common problem with this saw is the brushes when worn down to about half inch, won't go into the brush holder any further and starts to arc against the commutator. eventually the heating will burn out the commutator. a replacement armature will cost you $75 plus shipping.
Oct 20, 2009 | Dewalt DW746X 10" woodworker's table saw...
Dewalt DW746X 10" woodworker's table saw with rai Logo
776 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
