Question about Plumbing
Need wiring diagram for old sears multi-stage water pump.it's 1 1/2 hp model number is 190.5330 not sure on first three numbers. need to know if wired 220 or 110.
jgwhomeequip
  • 1902 Answers
SOURCE: Start Capacitor wiring diagram needed
When hooking up capacitor on a pump it doesnt really matter which way the wires go. The capacitor is set up in such a way the it supplys power wherever the wires are hooked up. I hope this helps
Posted on Jun 02, 2009
  • 89 Answers
SOURCE: Pool pump motor wiring issue
IF THE SCREW ABOVE IS IN THE METAL MOTOR HOUSING IT IS MOST LIKELY THE GROUND. GREEN WIRES ARE ASSOCIATED WITH GROUND IN ALL ELECTRICAL APPLICATIONS. YOU SHOULD BE SAFE IN HOOKING THE GREEN TO THE SCREW. HOPE THIS HELPS, JODY
Posted on Apr 12, 2009
  • 142 Answers
SOURCE: irrigation sprinkler pump, flotec, 230VAC wiring
green to srcew on the motor. this is ground.,
Black on T1
Red on T2
If the rotation is going the wrong way, simply switch the black to T2
Red to T1.
Check this before you couple it to the pump..
Posted on Jun 03, 2009
Roswell453
  • 59 Answers
SOURCE: Pool pump wiring
O.K. MONIKA READ VERY CAREFULLY!!!!
I DON'T REALLY LIKE TO GIVE 220 VOLT WIRING OVER THE INTERNET,LET ALONE THE PHONE,but I have a good feeling that if you all replaced the seal, you have an understanding of what you are dealing with: 1st make sure all power is disconnected,Breakers too(hey I have to say this so don't take it to heart), now the two black wires are 115 volts each, and the white one is ground, now enough said, the wires going from the source, (pool house,pump room), should be one white,one red, and one green, if this is the case the black and white wires, are the ones to hook up your black wires to, it does not matter (which of your black wires) go to either the red one or black coming from the source, and if your white on the motor is your ground it should goe to the green one coming from your source, if you don't already have them,I SUGGEST, you go to home depot,or lowe's and purchase the BLUE "water tight" wire caps, they can and are a "life saver anytime electrical is used around water, they cost some, but isn't a life worth a buck or two more? remember 115 volts can kill you if your around water 220-248volts will really kill you, so please check and double check all that I have told you. make sure everyone is clear,(pet's too), and flip the breaker, and you should be in business, god bless, happy 4th, and please let me know if I can help more
Posted on Jul 03, 2009
  • 832 Answers
SOURCE: Sears 1/2 hp shallow well pump wiring for 230 volts
You don't need to touch the pressure switch when you
convert it to 220. By the way, is it possible for you to send the me the brand of the electric motor driving it
so I can help you. Send you e-mail asap. Thanks and God Bless U.
Posted on Oct 27, 2009
Replaced bake element in Kenmore oven model number **********0
Hello;
My name is Peter. I am a retired field service appliance technician.
You did not provide a oven model number which should be on a label on the face of the oven when you open the door or on the side of the door. Locate the model number for later.
You need to go to a Lowe's or home depot store and spend $25.00 on a multi-meter. Read the manual and you will be able to know for fact what parts are good or bad. This is a good tool that you need for all of your appliances. I guess you spent about $70.00 or more for the element.
You replace a element when you notice a crack or a meter Ohm reading of OL.
There are three components beside the main control board (Which this is rare) that are the cause of failure.
1.) The element - which you have already replaced.
2.) The oven thermocouple - Which regulates the oven temperature. You can purchase this over the internet for about $25.00. Used parts are good. You need a multi-meter to check if the thermocouple is good or bad.
3.) The oven control board - If the two above components are good, then this is your problem. The oven control board is separate from your main control board. Depending on your model, your can purchase this control board from Sears for $200.00 - $270.00. Or you can go into the following website, put in your model number where you will get diagrams and part numbers, search the internet with the part number for best price.
Water Filters Lawn Garden Appliance Parts
Mar 30, 2016 | Kenmore Ovens
How can I find a wirning diagram for a ice maker that has guit making ice but the pump will run?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
Your Ice machine does not have a wiring diagram. I have repaired many of these.
1.) Are you getting water? If not it is your pump.
2.) Reach in and feel the cold plate. Is it cold? If not you have a refrigerant leak.
3.) The problem may also be within your main control board.
Unless you have a current service contract these units are considered throw-always. It will cost you twice as much, if not more, to repair it than what you purchased it for, assuming you call a service company.
Go into the following website. Plug in the first 5 numbers on your model number and a list of model numbers will appear. Your model number is incorrect.
Select the model number then click on parts and you will get diagrams of your icemaker. Water Filters Lawn Garden Appliance Parts
Mar 21, 2015 | KitchenAid 18" Ice Maker - Black
Kenmore 110.26492502 top load washing machine is leaking oil (yellowish with black). any chance, as a DIY-er,i can solve this? its turning 5 years old already... thanks! rex
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
The model number you provided doesn't appear on the Sears site. Are you sure it's the right number??
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Pulling the cabinet, pump, motor and gearcase are relatively easy. Getting the 8 bolts off of the gearcase and removing the top can get a bit messy as the gearcase holds 15 Oz. of gear oil. (Easily replaced with non-detergent gear oil from a local auto parts shop.
This is a Whirlpool / kenmore Serviced Manual PDF for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
See the Following Whirlpool parts list for alternatives to the Sears part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum. See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnectYing power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), and remove the 8 screws carefully the transmission holds 15Oz of 80-90 weight gear oil.
You should be able to either re-seat the cover or make a thin gasket using automotive "liquid gasket seal" products.
Jan 29, 2011 | Kenmore Washing Machines
My pump is wired for 120 and the diagram shows that a black trace wire to terminal B and a black wire to terminal A.Know my problem is the way its hooked up is a black wire on A and a black and white on...
The black and white wire is the trace wire. Using the A and B posts will be the 230 VAC connection. There should be another diagram for 115VAC telling you to move one wire to L2 and the other wire to I believe B. If the 115V diagram is not there is the motor rated for both 115 and 230VAC? If you need more help reconnecting the motor for 115 please provide the motor model number. It is likely an AOSmith motor with about a 10 character number for the model.
John
Nov 17, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
I have a Kenmore Series 70 top loading wash machine that leaks. It is approx 12 years old, model 110.4767290 (canadian). It has a 2 inch crack in the bottom of the plastic tub. I tried filling with expoy...
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The numbers following the 110 (which means it's made by Whirlpool) are usually 8 digits. Using the number that you provided, I couldn't find your washer on the Sears site. You will want to verify the number (usually by lifting the lid) and/or check for manuals / parts site from the following Sears site:
http://www.managemyhome.com/
Sears has replacement tubs (at least for my 12 year old top load for about $116.75 (U.S.) but you may be able to get one from Whirlpool for about the same cost. If you can get to the diagrams on the sears site. they often have "Manufacturer Authorized Substitutes) which are Whirlpool numbers.
FOR EXAMPLE, SEE THE SITE FOR OUR WASHER AND YOU'LL SEE EXAMPLES OF PARTS, DIAGRAMS AND COSTS.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.26902691&pop=flush
Jun 22, 2010 | Kenmore Washing Machines
Pentair WhisperFlo Wiring Help
If you just bought this then there will be a diagram on the motor nameplate and/or under the terminal cover where you connect the wires. Generally speaking, there are two wires inside the motor that change positions depending on 115 or 230 v connection. If one of the wires is on a post common to one of the line leads, that usually means you have the motor set for 115V. Is that the voltage you are supplying to the motor? If there is no diagram you can make out on the motor, post what brand motor and the motor model number for a diagram.
Dec 24, 2009 | Pentair Wf 6 1.5hp Whisperflo Inground...
Have an old sears craftsman 1/4 hp grinder model 397.19501 wires have been disconnected. I want to rewire and test. Does anyone know how to connect the wires? There are 2 copper tabs under the on/off...
the two copper tabs under the on off switch are to break the power source.connect incoming power to one of these(black) then a short piece of wire from the other tab under switch to one of the three tabs under plate that is marked hot or l1 is probably #2 but you need to be sure. the white is the nuetral or l2 which is most likely #3 and the green is the ground most likely #4 I would definately look online for a wiring diagram to be sure if they are not marked with L1 L2 and GND
Oct 10, 2009 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Jun 02, 2009 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Replacing a dual burner control switch
First, have you removed the wires from the old switch?
If not, then look on the switch, old or new, and see if there are numbers on the terminals. If so, just move the wires one at a time, terminal number to terminal number.
If you have removed the wires, then you will need to find the wiring diagram, which is most likely found somewhere inside the unit or on the back panel. You should be able to identify the correct wire connection from the wiring diagram.
If you can reply the full model number, I might can find a wiring diagram for it and give you more direction.
Jan 22, 2009 | Kitchen Ranges
Changing home thermostat
Couldn't find your thermostat based off the information you provided; find the model number and follow the link to the Contractor Support Page.
White-Rodgers Multi-Stage Thermostate Diagrams for Contractors
Nov 28, 2008 | Heating & Cooling
Plumbing Logo
189 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
