TV will not turn on. The fuse is blown. Need to
TV will not turn on. The fuse is blown. Need to know what kind of fuse for Phillips Model 60-TP935217. Took out old fuse no info on amp
    President:
  • 1,099 Answers
replace the fuse with the rating of 2.5A,
you can also check the iron head of the fuse.
Good luck...
Posted on May 25, 2010
Phillips 39" tv problem
a power surge can do alot of damage but does your model have a fused plug? as would check this. if you have changed the power board for a know working one then the main av board has gone this is the board that tells the power board to turn on.
Jul 15, 2017 | Televison & Video
How do I reset my Phillips TV if it will not come on?
Try unplugging all your tvs from mains and keep unplugged for a few hours. try to plug back in and attempt to turn on. See if this trick works. Likely there could be some internal damage in power supply or it could be fuses.
Oct 03, 2014 | Philips TV Tuner Video Capture PCI Card -...
My 2005 Phillips 27 in TV will not come back on after a power outage....
A power surge may well have blown your fuse. Check the fuse in the plug first. If you can't check it, just swap it with a known good one. If that doesn't do anything, then it's possible there may be a blown fuse on the TV's power board. If you don't know what you're doing, don't take the TV apart; there are high voltages stored in capacitors, even when disconnected from the mains.
May 02, 2010 | Philips Televison & Video
I have a 50 inch lcd phillips tv. I turned it on this morning and it just keeps clicking . I can't turn it off I had to unplug it.
This Seems to be a Power Supply Boards.Phillips TV's are Popular for their Power Supply problems.
You need to Open the TV. Make sure it would be Unplugged. You need to Take all the Precautions. Locate the Power Supply Board. Remove the Connectors and Pull out the Board. Once you Pull out the Board, with the Help of Magnifying Glass, locate Cold Solder Joint. If Everything is OK, then you would Locate Bulged / Leaked / Swelled Caps. They would have Ammonia kind of Odor. You need to De-Solder them. You could take the same to Radio Shack / Fry's / Order Online. Once you get the New Caps, Solder them and it is all set.You also need to Check Fuses around that.
If the Problem Still Persists, get back to me with Make and Model we would Troubleshoot other Components.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Apr 07, 2010 | Philips Televison & Video
2002 samsung rear projection tv wont turn on
Go to this website they will List Parts and Part Number for this Model Your STK ICS need to be replaced or convergence board that has ICs on it!. ICs will have Part # on them STK392-020 Encompass Parts Distrubtion
1-800-638-3328
For ICs Call Mats Electronics 1-800-628-1118 If you are able to repair/replace just ICs replace 2 resistors also 3.9 ohms or 2.7ohms in front of ICs
Mar 21, 2010 | Samsung HCM4215W 42" Rear Projection...
My Phillips Tv keeps turning itself off after around a minute,the power button remians on and green but no picture or sound. It is like the fuse keeps tripping. If you unplug the tv and switch it back on...
The main power supply is trying to fail. You might try giving us the model number since we can't guess exactly what kind of TV you have; LCD or plasma?? They suffer from some differing ills-
Oct 23, 2009 | Philips Televison & Video
Blows Fuses
Hi
They have so many reasons why blown fuses in TV... all you have to do is to check the shorted semiconductor like regulator and drivers..
Thanks!
Feb 24, 2009 | Philips 27PT5441 27" TV
My TV has cut off when I turn it on no picture comes on just a beeping noise
It seems that you need to check the fuse because a blown fuse can cause this kind of problems .
If you need more assistance provide details about your tv
make
model
how old is your tv ?
Thanks for using Fixya
Sep 06, 2008 | Televison & Video
Blown fuse
usually these step up transformers are design for one appliance at a time , let me know the brand and model number of transformer so I can get the specs info , does the stereo also shuts down?? let me know AJ
May 09, 2008 | Samsung DVD-V4600 DVD Player/VCR
Phillips 17 in, tv/vcr combo
the problem should not be the fuse if its the sound problem, i am having the same problem with the same tv and im an electronics tech and i have yet to see whats exactly wrong. but if you do want to try a new fuse its a 4A 250v fuse but the base where the plug connects into. if i find what the exact problem is i will come back on and tell you of my findings.
Mar 10, 2008 | Philips 14PV225 14 in. TV/VCR Combo
Televison & Video Logo
279 people viewed this question
Top Televison & Video Experts
Electro Med Services...
