Question about Briggs & Stratton Garden
Lawnmower 35-quicksilver 46S Cant get full throttle, seems to be a hesitation in the running of the engine. New spark plug, gap correct, clean air filter, fresh unleaded fuel.New oil.
rockitman187
  • 2559 Answers
SOURCE: JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Posted on Apr 04, 2009
SOURCE: Spark plug gap?
Without you!
Posted on Apr 13, 2009
AUTODOC01
  • 216 Answers
SOURCE: flymo quicksilver 46s keeps cutting out
make sure button not cracked also fuel filter sits in bottom of tank get you a peice of coat hanger and fish it out just pulls off the end clean it good and also double check your carb sometime you can lose a gasket and it will cause similar issues? let me know if any of this helps ? can also tell you how to adjust high speed side of carb if all else fails?
Posted on Aug 29, 2009
Testimonial: "that was very usefull thank you"
  • 61 Answers
SOURCE: What is the proper spark plug gap for Craftsman
gap should be .o30 thousands
Posted on May 29, 2010
vincob
  • 718 Answers
SOURCE: I'm looking for the spark
.030"
Posted on Apr 21, 2011
Hesitating on a 2006 Buick Lacrosse
this is for a 3.6L engine, should be the same either way. doesnt seem extremely difficult
  1. Turn the ignition OFF.
  2. Remove the ignition coil.
  3. Use compressed air in order to remove debris from the spark plug cavity.
CAUTION: Refer to Safety Glasses and Compressed Air Caution in Service Precautions .
NOTE: Clean the spark plug recess area before removing the spark plug. Failure to do so could result in engine damage because of dirt or foreign material entering the cylinder head, or by the contamination of the cylinder head threads. The contaminated threads may prevent the proper seating of the new plug. Use a thread chaser to clean the threads of any contamination.
  1. Remove the spark plug.
NOTE: Allow the engine to cool before removing the spark plugs. Attempting to remove the spark plugs from a hot engine may cause the plug threads to seize, causing damage to cylinder head threads.
INSTALLATION PROCEDURE
  1. Ensure that the spark plug gap is equivalent to the spark plug gap specification. Refer to Ignition System Specifications.
NOTE:
  • Use only the spark plugs specified for use in the vehicle. Do not install spark plugs that are either hotter or colder than those specified for the vehicle. Installing spark plugs of another type can severely damage the engine.
  • Check the gap of all new and reconditioned spark plugs before installation. The pre-set gaps may have changed during handling. Use a round feeler gage to ensure an accurate check. Installing the spark plugs with the wrong gap can cause poor engine performance and may even damage the engine.
  1. Install the spark plug.
NOTE: Be sure that the spark plug threads smoothly into the cylinder head and the spark plug is fully seated. Use a thread chaser, if necessary, to clean threads in the cylinder head. Cross-threading or failing to fully seat the spark plug can cause overheating of the plug, exhaust blow-by, or thread damage.
Tighten the spark plug to 20 N.m (15 lb ft) .
  1. Install the ignition coil.
Aug 04, 2016 | 2006 Buick LaCrosse
Earthquake Vector Compact Tiller Model#26750
Did you pull the spark plug and clean it, as well as the plug well and compression ring. Blow it out with canned air and dry before replacing the plug. Be certain the plug GAP is correct and it is free of carbon deposits. Rest the plug, tighten by hand and let her go. See if that fixes the problem.
Feb 27, 2014 | Earthquake Vector Compact Front Tine...
Ive a honda lawnmower , engine is surging up an down when full throttle , is startin to do same at low throttle also.
Install a new spark plug,clean air filter,
& check for intake vacuum leaks.
If that doesn't work take the carb apart & clean
Nov 18, 2012 | Cars & Trucks
2001 Chevy venture intermittently running rough.
Check air filter. Check for any vacuum leaks. Check condition of plug wires. Were new plugs pre-gapped? If not, make sure the spark gap is correct for your vehicle.
Sep 24, 2012 | 2000 Chevrolet Venture
I have a quicksilver 46s petrol lawnmower but it wont start when i pull throttle
Check d plug 4 carbon and clean it or put it on choke then start.
Jul 23, 2011 | Kitchen Ranges
My B&S 450 Series Quicksilver 46S motor is "hunting". Local repairer is at a loss!v Please advise me as to how I can fix it - Simple instructions please, I'm no expert! Also what is the...
ok if it is hunting it could be a few things one spark plug two dirty air filter three debris in the carburator most likely in carb get a carb kit from your local small engine shop & take carb off take it all a part soak in carb clean in a pail for a day or so & put back together
Nov 23, 2010 | Husqvarna Garden
Flymo quicksilver 46s keeps cutting out
Aug 29, 2009 | Garden
I have a lawnmower with a BSA 3.5 engine that I cannot start, the problem seems to be no spark at the spark plug. As I have never worked on a lawnmower I have no idea what generates the spark on...
Test for spark by placing a screwdriver into the spark plug wire and holding it close to a bolt on the engine. should see a spark (blue). If not, problem is likely the armature (coil). The coil is located under the engine shroud and held in place by two bolts. If you replace this part, (normally $30 to $40) you must ensure a proper air gap. Auto parts stores have inexpensive repair manuals to help.
Lee
Cherokee Small Engines
Apr 21, 2009 | Garden
Garden Logo
288 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
