Question about Panasonic Viera TH-50PZ85U Plasma TV
After turning on, the picture is displayed for a fraction of second and goes blank. If power off and on, it does the same again. I tried unplugging the power cable, didn't help.
    New Friend:
  • 45 Answers
Count the number of times the red light on the front panel blinks in succession - this is the trouble code that pinpoints the problem area.
Posted on Jul 12, 2010
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
Recently when I boot up my computer I get the monitor to display an image for about 2 seconds and then it goes to a black screen. if I unplug the monitor from the back of the computer and plug it back in,...
The capacitors for the power source are failing. This causes a short burst of power to get to the lamps, but then they cannot hold a charge to continuously power the lamps. You will have to replace the monitor. I suggest checking your warranty status and replacing the monitor.
Jul 19, 2011 | Gateway FPD2275W LCD Monitor
Screen goes blank when first turned on, have to keep restarting m
If you turn the monitor off then about 1020 sec turn it back on and have a picture for five sec again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Jul 24, 2010 | Dell E153FP 15" LCD Monitor
Screen going blank on system boot and on switch off/on
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a fraction of seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 08, 2010 | Sony SDM-HS75 17" LCD Monitor
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
X191w blank screen after 2 seconds
Just got off the phone with Acer Suppport. This was after I sent an email to them, that suggested that I call. 8-/ annoying. So the guy on the phone says there is one thing that we can do before sending it in. Unplug it completely for the wall and computer. Hold the on/off button in for 30 secs. reconnect power and the computer. It worked for me
Oct 07, 2008 | Acer X191WSD Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Panasonic Viera TH-50PZ85U Plasma TV Logo
141 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
