Question about Kenmore 24032\24036 Top Load Washer
Washer stop spinning and water drains out slowly
    Problem Solver:
  • 5 Answers
Im not sure on why the water drains out slowly maybe a clogged drain hose or possibly a leak in the water pump.. as for spinning. if the whole unit spinning as in the drum? if not you have something called a motor coupling it is in between the motor and transmission if you tilt your washer and see black or white shavings then you know your coupling is broken .. is the agitator spinning? inside the middle there are something called Dog agitators they are four if they should have teeth marks on the ends if the are worn they will not. you can view your schematic and manual on sears.com/parts with your model number i used 11024032 and it will offer you a few different models to choose from click them and you can view the pictures and also download the manual and use the troubleshooting guide
Posted on May 25, 2010
The motor is running but it won't turn the belt on my front loader ge washer
It definitely sounds like the belt is stretched, worn-out, and in need of replacement.
Jul 30, 2014 | General Electric Gfwh2400lww 4.9 Cu. Ft....
Water slowly runs in washer when it isn't on
dirt or faulty inlet solenoid diaphragm
simple fix is to turn the tap off at the wall when finished
Jul 18, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Washer spins slowly and will not drain
Sounds like the motor might not be turning the tub at high enough RPMs
Aug 08, 2012 | Frigidaire FEX831CS Top Load Stacked...
Washer does not spin cycle, why?
In top load washers, if the machine goes through the cycles and then just stops at the spin cycle and leaves you with no noise and a tub full of water more than likely the lid switch is bad and not completing the circuit for cycle to continue. This is a safety precaution to prevent injury by reaching in the machine while at high speed spin. If the machine is getting to the spin cycle and still turning slowly but not draining the water, the pump is probably the culprit, either being locked up or in most cases something like a sock, etc. is stuck in it preventing it from turning. This is usually indicated by a humming sound during the spin/drain section with no water draining.
Apr 30, 2012 | Whirlpool Washing Machines
Washer is not completing the spin/drain cycle. Stops spinning and draining.
does it drain out all the water? after it stops or is there still water sitting in the tub?
Mar 22, 2011 | Kenmore Elite 45986 Front Load Washer
MAYTAG PERFORMA MODEL# PAV2300AWW, REVISION#12, SERIAL#12296390ZM Washer filled but made loud grinding sound while agitating. I couldn't drain water on spin cycle. Now it has stopped working, I smelled...
hello you need to change drum rollers but if u remarked water dawn the washer and burn smell it could be the motor OR THE BELT because when the drum stop turning or turn slowly the motor turn fast on the belt when spin time it make this smell .
Sep 11, 2010 | Maytag Performa PAV3200
Unit runs good through wash cycle then while in rinse and spin does not complete cycle. The machine starts doing a short spin, and then dial starts turning around without stopping.
Sounds as if the drain pump is not ejecting the water fast enough. Did you notice of the washer is draining more slowly than usual or at all?
Feb 14, 2010 | Splendide 2100 Vented Washer-Dryer
Wont spin
the machine will only drain after the rinses and give it three minutes to reach a pressure setting if this pressure setting is not met within the three minutes,the machine will stop, this sounds like the drain might be slightly blocked try there first, and then the drain pump and sump of the machine.
Jul 30, 2009 | Washing Machines
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
42 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
