Question about Philips 32PF7320A 32 in. LCD Television
My hdmi ports keep going out. why does this keep happening? i have a 42" lcd flatscreen (philips). I have a PS3 hooked into hdmi port but every 3 to 4 weeks the port stops working and i have to set up an appointment with a tech and all he does is reset it. if i can do this by myself it would save a lot of time and trouble.
5 Suggested Answers
  • 17 Answers
SOURCE: trying to connect nintendo wii to philips tv
If I have the right manual you should connect the wii cable from the package to th backside of the tv. You will see four pluges. Choose with VGA you want to use, this is not important. Use the cable from the wii and plug in two of three pluges, you must match te coulors. If you have a cable box installed you will probably have scart (a big cable with a large head) connect this and it would run smooth. You can also connect the three pluges from the cable to your cable-box, use the red, wihte, and yellow pluge.
Posted on Dec 25, 2008
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
SOURCE: I just bought my Philips 32" lcd tv and tried to hook up the ps3
you have to first plug in the s-video before you use hdmi so you can set it to HDMI on your ps3 when you go to your setting. Then it should work. If you already did that and it still doesnt work its probably the HDMI cord
Posted on Jul 29, 2009
SOURCE: hdmi port not working for ps3
believe it or not it might be your tv. mine did the exact same thing and i thought it was my ps3 but who wlda guessed its the tv lol. soo heres what you do. leave ur ps3 plugged in to your tv through hdmi, then all you do is unplug your tv from the wall, and wait for about 20 mins then volia!!!!! hmdi at its best. i do not know how it works but it does and i hav not had a problem since.
Posted on Sep 15, 2010
Phillips hdmi ports not working
Yes,
When 1 HDMI port is broken most of the time all the ports are defect. This is because all the 3 HDMI ports are connected to 1 multiplexer IC. Only when the connector or the copper connection on the board is damaged the other two ports still be functional.
You still can use the other connections ( not HDMI) the should be working.
Regards GJ
Jun 14, 2014 | Philips 42PFL5332D 42 in. LCD Television
Dear sir/Madame, I?m having a problems with installing my PS3 on mine TV. TV that I?m using is a Tatung V32MCGI 32inch LCD. Problem I?m having is following. When I try to connect my PS3 on to my TV...
Have you tried "resetting" the ps3 with it hooked up to your hdmi port? When the ps3 is in standby (red light), hold the power button to power it on, however, dont let go, keep hold the button down for 5 or so seconds until you hear a beep again, let up and wait about 15 seconds and it should detect the hdmi port.
Brandon
Dec 09, 2010 | Sony Playstation 3 (PS3) Console
I have a sony wega KDF42WE655 TV(42 inch). It has a HDMI port I recently bought a PS3 and hooked it up to the TV. With the HDMI port connected I do not get any picture or sound. Attempts of rebooting...
There is a separate IC on the main board that does nothing but process the HDMI signal, basically if your using the cable, AVI or any other input other than HDMI and chances are that is bad, it can be replaced if you have a lot of electronic experience, its a $3 chip but its not easy to replace..I would replace the main board if you can find one, sometimes main boards are hard to find..below is a link to the service manual.
Sony KDF 42WE655 Service Manual
Nov 23, 2017 | Sony Grand WEGA KDF-42WE655 42" Rear...
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
How do i connect a pc to my 42pfl 5522d
in most cases you must have a video card that supports tv.s will have a special plug in it and a cable
Mar 03, 2010 | Philips 42PFL5332D 42 in. LCD Television
I know this is late, but this happens frequently. If anyone else has the same problem try unplugging the TV for 60 seconds. Plug it back in and then hold the power button down for 30 seconds. That will reset the TV.
You should see the Westinghouse logo come up and the HDMI should work. This has happened twice with my TV in 1 year.
Apr 10, 2009 | Westinghouse TX-42F430S Television
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
Philips 32PF7320A 32 in. LCD Television Logo
346 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
