Question about Goodman CKL60AR60 Air Conditioner
A/C compressor has power to the contactor (220) but will not kick
We set the thermostat to turn the A/C on but nothing happens at the compressor. I read power to the lower power wires and 220 is there. is the problem my contactor or my capacitor?
    Guru:
  • 415 Answers
Check for 24 volts at your contactor coil. If you have 24 volts at your contactor coil, then you should read 220 volts on the other side of the contactor. If you do not read 220 on the other side, then the contactor is failed and needs replaced. If you do not read 24 volts at your contactor coil, then you have to find out where the "break" is. See if you have 24 volts at "common" and "Y" at your outdoor unit. If you do not, the problem is somewhere between your outdoor unit and thermostat. If you have 24 volts at your outdoor unit but not at your contactor, you have a problem somewhere inside your outdoor unit. Using this information, do some more investigating and let us know what you find, we will guide you further from that point. Good Luck! :-)
Posted on May 25, 2010
Bad compressor? when i turn on thermostat, just clicks on outside unit and nothing happens.
Kill the power to outside unit. Look for burned or broken wires on contactor and capacitor and on compressor. sounds like its in compressor circuit.
Apr 03, 2014 | Intertherm Heating & Cooling
Cool will not come on when it's set in auto mode
A thermostat is only a switch, nothing more. It's job is to cut on and off the cooling/heating equipment based on a preset temperature setting. It sends 24-28 volts to a contactor or relay which does the actual closing (turn on) or opening (turn off) the power to the compressor or furnace, and that's all it does. There could be a problem with the other parts of the system. When the space temperature exceeds the preset temperature the thermostat should provide 24-28 volts to the compressor contactor, to start the compressor. The "Auto-on" switch on the thermostat controls the fan only. If there isn't 24-28 volts from the thermostat to the coil of the contactor, the compressor will not operate,
Oct 30, 2013 | Hunter Fan Company 42999B - Heat/Cool...
Central ac compressor keeps running
Sounds like the contactor is stuck. Turn the power off on both units and remove panel on condenser. Pull out on the contactor if engaged. Likely still needs replaced, it's going to happen again.
Jul 25, 2017 | Heating & Cooling
Model # ckl49-il serial # 0506126514. This unit stopped working yesterday, noticed the fan on the outside compressor wan't turning, how do i test the capacitor and fan to see which one to replace?
By far the most common problem with air conditions is the relay (known as a "contactor") by the air conditioner industry. This allows a low voltage (24 volts) electromagnet to turn on the 220 volt motor for fan and compressor. A replacement will generally cost about 50 to 75 dollars on Amazon.com.
Look for the wires entering the unit, The pair of wires entering the unit will go into a small (4" x 2" x 2") unit (the contactor). Another pair small diameter wires will go into the contactor (those are from the thermostat (or control panel of your furnace blower) and control the electromagnet switch.
The pair of output wires exit the unit and go to the compressor motor and fan.
You can check the output power by
1) Turning off the circuit breaker to the A/C
2) Unplugging the switch (must be a second switch within 3 feet of the A/C) near the house
3) opening up the outside panel on the A/C
4) Set voltage meter probes on the two output wires on the Contactor (make sure voltage meter is set to 220 volt AC range or higher)
5) turn on the outdoor switch
6) turn on the circuit breaker (if no body is near the unit and you can see the voltage meter without touching it)
7 check voltage meter to see that is says 220 volts AC
If not, then the contactor is bad and needs to be replaced.
A professional can usually do it for $200 including service call. I highly recommend calling a professional if you feel uncomfortable in any way about working with 220 volt systems. This voltage will kill you if you make a mistake!
-Mark
May 28, 2011 | Goodman CKL49AR49 Air Conditioner
The thermostast kicks on the fan bu the compressor does not kick on
Most of the time it will be your contactor outside in your condensing unit. It could also be your thermostat sometimes they click but the switch inside stat is not making connection. Also check your breaker panel and make sure breaker is not tripped it could be something as simple as that.
Be careful the A/C is 220 volts if you work on it make sure power is off. If your fan is working on the unit outside but the compressor will not come on you will have to install a superboost which are easily installed and about $30. they dont always work but its your last ditch effort to getting the compressor started.
May 09, 2011 | Heating & Cooling
Do bryant condensing units have a reset button? We can't get the unit to kick on. All power is correct and fan starts inside, but can't get condensing unit to kick on.
Most Bryant units do not have a reset button but could have a low pressure or high pressure switch for a safety to protect the compressor. Verify power from the thermostat to the contactor by following the thermostat wires all the way to contactor inside of electrical compartment... TURN POWER OFF BEFORE OPENING.... If power is to contactor and contactor is pulled in then you would need to look at the capacitor of which is a canister about 6 inshes tall with wire terminals on top.. this part should be flat on the top and if it is rounded then thats your problem.. if not then contact a local company to troubleshoot and make necessary repairs.
Sep 01, 2010 | Bryant 463AAC008BA Air Conditioner
Turned unit on for first time, it will not kick on
does the indoor fan blow? If it does you are getting the 24 volts from the thermostat to the ouside contactor need to check your contactor in the oustide unit this is what kicks on the compressor it take the 24 volts and goes to 230 volts to run the compressor and condensor fan. check your schematic for the placement of the contactor.
Jun 04, 2010 | Carrier 38CKC030 Air Conditioner
I have a 220 volt compressor the contactor is kicking in when i turn the breaker on but the motor is not running im getting power on top and bottom of contactor
hi there,
the motor has a problem have check on this it develop a high current,why the high current appear,is it in the compressor or is it in the motor.find it out disconnect the belt from compressor and motor,then run the motor,if still tripping off w/o the compressor .it is in the motor
replace the bearing worn out,have a nice day dont forget to fix my rate,have a nice day
May 01, 2010 | Air Tools & Compressors
Compressor will not start, GSC14-14 SEER
Control wires come from the thermostat to power the contactor coil. At the thermostat the red wire must power (switch) the yellow wire to make the contactor pull in to run the outside unit, Check power with a ac volt meter between the red wire and the yellow wire, with the heat/cool switch turned to off. If you do not have 24 volts ac, your wire may have an open from the thermostat to the outside unit, your transformer may be bad and not supplying power, or your contactor coil may be open
Jun 23, 2009 | Goodman CKL30AR30 Air Conditioner
I have a carrier infinity system. On the thermostat it reads "sens error" where the outdoor temp is normally displayed. The inside unit is running but the outside unit is not. Any suggestions?
A burned or pitted contactor will/can cause a unit to not run. Outside fan. Just thinking out loud. Start with low voltage check at t.stat then check outside low volt. Set t.stat to on. If fan engages at least your transformer is good. Next set calling for cool. Drop t.stat 68-70. If nothing happens go outside and with a screwdriver depress the contactor in. If fan and compressor kicks in change the contactor. If contactor is pulled in check outside fan. Remove the wires from the compressor and see if the fan will run . If it does you have eliminated start components as good. The compressor has to be check. It needs to be ohmed out. Turn off power at disconnect. Pull the cover on the compressor. Check between pins; then pins to ground. Open or infinite is good.Have you checked fuses. Like small 3-5 amp fuses
Jul 03, 2008 | Carrier Heating & Cooling
Goodman CKL60AR60 Air Conditioner Logo
279 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
