Question about Jenn-Air JFC2089HTB French Door Refrigerator
Frost has suddenly started to form around the icemaker and along the top of the freezer compartment. We got back a week ago from a month long vacation and had as usual utilized the vacation program . The problem manifested itself over the following few days. What do we need to do ?
  • 6,784 Answers
HI. This may be a defrost board issue. Just a couple of questions here:
1. Is there proper cooling in the refrigerator compartment?
2. Dose the freezer freeze the contents properly?
3. What is the entire model number of this unit?
Posted on May 25, 2010
  • 11 more comments
  • sandracharle May 25, 2010
    Food in refridgerator is fine
    Food in freezer is freezing properly.
    We have stoped the internal water dispenser.
    JFC2089HTB
  • Michael Masters
    Michael Masters May 25, 2010
    Ok, seems to be running fine. No evaporator issues or frost build up on the evaporator core. This will usually lead to a failed coupling device at the water lines or a clogged drain assembly at the freezer compartment.
    Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up in the freezer compartment.
    The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel. Your freezer has a drain that leads to the exterior drain pan beneath the unit.
    Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
    NOTE-(This may be a leveling issue as well)
    It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
    Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
    If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
    If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
    • Additionally, remember to inspect all water inlet hoses for loose couplings at there respective connections to and form the inlet valve(including the ice maker connections). Make sure that the water pressure is sufficient so that any leaks will be visibly noticeable during your inspection of these points.
    I have made a minor adjustment to the level although the fridge has worked perfectly for two years as it was. However I can find no sign of a drain hole in the freezer compartment. It seems to be a one-piece moulded plastic liner with no hole in it.
  • Michael Masters
    OK, the drain hose will empty into the drain pan. There should be a plug or coupling section to the tubing which allows for the liquid to be dump into the drain pan. The tube can be removed for purging procedures. I would pay close attention to the freezer drain tube, at this point. Have you checked all the inlet line connections for proper coupling to and from the inlet assembly and ice-maker?
  • Michael Masters
    Additionally, you mentioned that you shut of the water to the dispenser. Did you any noticeable dripping's coming from the dispenser, by any chance?
  • Michael Masters
    If so, there may be an issue with the inlet valve not closing correctly. This will cause ice build up in the unit as well.
  • Michael Masters
    OK, here's a diagram of the freezer compartment. Pay close attention to the number three on the diagram. This will be the funnel that will have the tube attached to it, which will lead to the drain pan. Inspect this tube and funnel for debris and purge if possible. If the tube and funnel are clear of debris, move on to the inlet hoses for the dispenser and ice- maker. check all hoses for faults or loose connection.
    CLICK HERE TO ACCESS THE DIAGRAM.
  • Michael Masters
    The actual drain tube will be easily visible from the rear of the unit. it is labeled number 6 on the diagram.
  • Michael Masters
    The clog may be between the sections that link the refrigerator drain line to the freezer line. They both run to the funnel and to the drain pan under your unit. i suspect that this tube or funnel is, indeed, clogged, thus, causing the back u of liquid to settle and freeze up.
    Now, if the drain assembly proves to be clear, the dispenser may be leaking.
  • sandracharle May 26, 2010
    Sorry; I had to leave it (and you) overnight as my daughter-in-law was having a baby. I'm back at it now and will follow your latest instructions.
    To answer your questions, there is no water dripping from the unit and the inlet connections are OK. So I'm tackling the drain hose. Thanks for the diagram.
    I have cleaned everything out - there was no apparent blockage - and I have reinstalled it and turned the water back on. I'll wait a few hours to see if frost starts to form again.
    Incidentally, I checked the level of the ice-maker and it was spot on.
  • sandracharle May 27, 2010
    It has now gone 24 hours and no frosting. The drain was not blocked and I'm inclined to think that it was our return from vacation and switching back from vacation mode that caused the problem. Once I had switched off the water, emptied the fridge and freezer and cleaned out the frost and then switched it all back on again, I had no more problem.
    Thank you for your help.
  • Michael Masters
    Michael Masters May 29, 2010
    Thats great. Have a great weekend:)
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
Frost in top freezer - water leaking in refrigerator - ice maker not working
go through this link it will help you
http://www.ehow.com/video_112132_fix-leaking-refrigerator.html
Oct 08, 2008 | Frigidaire FRT21HS6D Top Freezer...
Freezer works fine, fridge compartment cools but has stopped cooling as good and has recently stopped cooling. did a manuel defrost on fridge and freezer worked fine afterwards, now doing the same thing...
Oncce the fridge was shut off and left for a while the cooling had come back . If frost is seen it is a good indication as the compressor is working with sufficient gas within.
If after about 6 hours you observe cooling it is possible that the defrost timer is faulty.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
replace the defrost timer, heater or thermostat one you have confirmed to eliminate one by one.
Mar 11, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Upright freezer, non-frost free. We are having to defrost it frequently as in monthly. We used to do it once a year if needed. Frosts up quickly, especially on ceiling with snowflakes falling from...
. More than likely you have a bad freezer door seal gasket . If the freezer door does not completely seal when closed , the outside (humid) air enters the inner compartment. As the air is cooled , the water molecules freeze and form the frost you are experiencing . Only one of two things can be wrong . It is either the seal itself , or the door is warped due to excessive force or bad door hinges keeping it from closing properly . There is one more possibility but only if the door has a mechanical latch . If this is the case , the latch might need to be adjusted or replaced .
Feb 18, 2011 | Refrigerators
Fog and dew dripping in ref
It may be high humidity of the air outside of the refrigerator or you are storing highly humid things inside along with the settings of the fridge.
Jun 07, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
GE refrigerator/freezer - defrost noise
Blow it clean or check for loose bolts or broke springs.
Apr 18, 2017 | GE Refrigerators
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Apr 12, 2008 | Refrigerators
Kemore model 795.7731 bottom freezer
You are probably correct that it is the evap motor. If you are seeing frost on the back wall then there is probably some ice built up around the motor and the fan blade is hitting it.
Try defrosting the freezer and look very closely all around the seal for the freezer drawer. It is common for moisture to freeze in the self closers in the drawer rails and not let the drawer close completely on one side or the other. If this happens the small gap will allow the freezer to frost excessively.
Sorrry to be slow in responding. I have been very busy this week and have not been on line very much.
Mike
Apr 10, 2008 | Refrigerators
LG LRFC22750 Bottom freezer french door refrigerator
6343ed3.jpg The problem is ice build up on the back wall. The noise you hear is the fan blades hitting the ice. On the back wall water gets trapped, it then builds up over time, and a big ball of ice forms and blocks the fan. Take off the back wall, defrost the build up and cut the insulation off as above. The water will no longer get trapped and the problem will not come back.
Sgt 48
Feb 13, 2008 | LG LRFD25850 French Door Refrigerator
Jenn-Air JFC2089HTB French Door Refrigerator Logo
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
