Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Our fridge freezer (Admiral GS20C63EV) stops cooling and needs to be turned off with doors open to difrost overnight. it works for a few days and again it stops cooling! both the fridge and freezer stops cooling, fridge gets warm but the freezer stays a bit cold sometines. any help would be appreciated.
    President:
  • 1,218 Answers
Good day,
Step one. Remove the light guard in the fresh food section and where the main thermostat is located is a slot where you can insert a screwdriver. This is where the timer is. With the machine running, turn the shaft clockwise until the machine shuts off. Wait 35 minutes. If the machine comes back on, the timer is o.k. if not replace it.
If the timer is o.k move over to the freezer side. With the machine having been on for at least 6 hours remove the rear panel.
Inspect the cooling coil closely. It should have a frost coating from bottom to top. If the top coils are clean, you have developed a freon leak and have a serious problem.
If the coil is active top to bottom, then you will need to replace the dual glass defrost heaters and the defrost thermostat. One or the other may still be good at the time but it isn't worth the hassle to go into the system twice.
Installing them is tedious but doable. Take your time and keep track of how it comes apart. It's a monkey see monkey do job.
Careful on pulling the new wires.
P.S.The top coils wil not be as heavily frosted as the bottom ones but must have an active coating of frost on them.
Posted on May 25, 2010
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This...
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Sep 14, 2010 | Samsung Refrigerators
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Freezer is working correctly but fridge
hi there is a electronic vent that opens when cool air is needed and a fan ..to blow it up through channel.you need to find out if the fan is working first..open fridge door and push light switch in this should turn your fan on you should hear it hummmming. also put other hand were the vent is to fill if cold air coming through ..if not then you need to change vent assy. hope this helps,01179512835
Dec 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Freezer is working but refrigerator is not
My Maytag (side by side) had a similar problem, turns out to be the damper door. The freezer does the cooling, there's a damper door between the fridge and freezer that opens and closes to control fridge temp. Find the damper door and prop it open. If the fridge temp drops overnight, you'll need a new damper ***'y.
Oct 01, 2009 | Frigidaire Refrigerators
My fridge freezer has stop working but if you open the door it start to work but if you shut door it stop's and you can hear the fan in freezer stop and start it's a admiral gc2224gekb side by side
Hi thanks for te question. it should be the opposite of what its doing did somebody work on this fridge before. it looks like somebody switched the light and the fan switch
Oct 07, 2008 | Admiral Refrigerators
Fridge is warm, freezer works.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Maytag MSD2651HES fridge not cooling freezer works find
  • possible causes:
Jul 06, 2008 | Maytag MSD2650HES Stainless Steel Side by...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
438 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
