Question about ASUS K8V-MX Motherboard
Extra USB connection
I have extra USB connection on the cabinet but i do not understand where i connect the this wire.
    Problem Solver:
  • 14 Answers
Hi kalimm,
Your motherboard does in fact have special connectors just for these internal USB ports. These are often called "USB headers".
Based on the manual for the board (which can be found here [LINK]), two of these are located on the bottom edge of the board, below the three PCI slots. These are labeled "USB78" and "USB56" and have nine pins in them, which should match the connector that leads to your case's USB ports. Use of these ports is described in detail on Page "1-25" of the manual and I'd strongly recommend reading through this section to verify that things match up properly.
If you need anything else, please let me know!
Posted on Apr 08, 2008
How to wire two extra 12v batterys to a 24v mobility scooter to increase the amps
Connect the two extra 12 volt batteries in series to get 24 volts. Then connect this new 24 volt supply in parallel to existing 24 volt battery supply.
Jan 30, 2017 | The Health & Beauty
How do i splice into wiring harness for extra toggle switch on harley flhr?
On the existing wires with the extra toggle switch, one wire should be a ground, and the other a hot lead.
Aug 13, 2014 | 2001 Harley Davidson FLHRCI Road King...
How to fix extra speakers to peavy xr 886 and get the same power to each sperkers not just daisy chain each extra speakers
This powered mixer can only drive 4 ohms a channel...two eight ohm speaker cabinets daisy-chained makes one four ohm load. Ampifier wattage output ratings are usually higher driving four ohms than eight BUT never drive a lower rating than advertised by the manufacturer.
If you need more power than the mixer can provide, connect the "Master Out" or "Mono Out" connections (next to the speaker output jacks) to an external power amp. Connect additional speakers to this external amp and you're done.
Nov 12, 2013 | Audio Players & Recorders
Boot device not found
Dear User...
The Iomega Home Media Network Hard Drive is born to enhance your digital life. you know attaching extra drives to the USB 2.0 port.
If any types of problem create then flow step.1> Proper USB driver installed.
2> You connect only back to cabinet. not to front side USB port.
3> If USB not connect that time go to my computer>property>hardware>device manager and see you USB port working properly or not.
4> Uninstall driver and restart computer. then again start computer and reinstall driver.
I hope solve you problem..
more info visit Techsupportmart
Jan 02, 2013 | Iomega 1TB Home Media Network Hard Drive...
How do I connect the front usb wires to my fic c51g motherboard header?
How to Install Front USB by Connecting Front USB Ports to a Motherboard?In order to have front mounted USB you must have 3 things.
  1. A case with USB ports in the front of it.
  2. A motherboard that supports front USB (usually)
  3. Appropriate wiring between the USB port and the motherboard
A case can support front USB in two ways: via a pass thru connection, or via a port to header connection. The former, pass thru connection, is compatible with all motherboards that have USB ports. Pass thru front USB Pass thru front USB works by having the ports on the front of the case connect to either a standard USB cable, or a fairly small rounded cable. The cable goes from the front of the case to a special slot cover with either a hole (for the standard USB cable) or a special connector for the rounded cable. If the pass thru USB had a standard cable, then you would simply plug the standard cable into one of your back USB ports. If it had a rounded cable, then you have a secondary attachment with something that looks like an old style SCSI connector. The attachment plugs into both the slot cover, and the back USB ports. The draw back of pass thru front USB is that you lose the ports in the back.
Many 3rd party devices that add front USB to a system use the pass thru system. A good example is this now discontinued Front IO panel
directron_1721_2292726
Front USB via a Port to Header connection In order to hook up a Port to Header connection you have to make sure that the wires from your port will connect to your motherboard's header. To do this you need to know what header you have, and what type of connector you have on the wires. You'll find information on both below.
Almost all motherboards these days have a USB header. Due to size and cost restraints many motherboards only have 2 USB ports on their back panel, but often they can actually support more then 2 USB ports. They will typically support additional ports via the use of a USB header. A USB header is either a single or double row of header pins on the motherboard that can be used to add additional USB ports to a computer via the use of an appropriate set of header connectors, wires, and a USB port. Each pin on the header corresponds to a wire inside a USB cable. These pins must be clearly marked so that you can hook them up to the wiring correctly. There are 2 common layouts for a USB header.
Intel Standard USB header Layout: (used by over 90% of motherboards)
Gigabyte Style USB header Layout: (used most commonly on Gigabyte brand motherboards)
instusb2b
Now that we know the types of headers we have to take a moment to understand the USB wiring. Understanding the wires First off: All USB cables have 5 wires. 4 of these wires are actively used. Here's a reference from the official USB standard.
instusb3
On a front mounted USB port you'll have either the first 4 wires connected to properly colored wires (red for power, white/orange d-, green/yellow d+, black for ground) or all five wires attached to the port (same as the former, but one extra black wire). Now where it gets tricky is how to attach each of those wires to corresponding pins on the motherboard.
The wires are "tailed" (attached to a header connector) using any one of a number of different types of connectors. Below you'll find a list of the common ones.
Common USB case header connectors 4 joined pins + 1 extra ground.
usbheader
Compatibility: Compatible with both header arrangements because of the extra ground. May not work with some odd arrangements To hook up carefully match each pin. For the Intel hookup you'll have the extra ground wire not attached to anything. For the Gigabyte hookup you'll have the extra ground hooked to ground pin on the motherboard, and the standard ground jumper will be over the missing pin on the header.
All pins separated
instusb6
Compatibility: Compatible with every header. If all the pins are separated the only real issue is lining up the pins with the appropriate places on your header. It should be compatible with all headers. Just make sure you read the writing on each individual connector. Please check the troubleshooting info at the end of the article for important information on this configuration
Power and Ground separate, d-, d+ joined Lian-Li style
Compatibility: Compatible with all common headers. This sort of arrangement is common to almost all Lian-Li cases. Make sure that you get the wires connected to your header in the proper order. If you find that the port does not function the most common cause is accidental reverse of the d-,d+. Try switching it.
All pins joined Intel style easy connector
usbinst4
making the Connection Once you know what type of header you have, and what type of connector you have on the wiring, you need to connect the two of them. In order to do this, you must first figure out what pin goes with what part of the connector. To do this, you should first consult your motherboard manual. Below you'll find an excerpt from a fairly recent motherboard manual for the Asus A7M266 motherboard. It's typical of a motherboard manual for a board using the Intel standard USB header.
instusb5
The first thing you'll probably notice is that the wiring from your case and the names of the pins might not quite match up name wise. This is a common problem. Motherboard makers and case makers really haven't decided on what to call each pin. Here's a rough list of names.
Power may be called: P, VCC, USB Power, Power, and PUSB. On wiring it's always red. Ground may be called: G, GND, Ground, and GUSB. D- may be called: USB-, USBP-, D-, or just -. D+ may be called: USB+, USBP+, D+, or just +.
To complicate things a bit more you'll probably notice that there's a number before each one. Take a look at the picture above from the USB hookup diagram for the A7M266.
You'll see that Asus decided to number the middle pins. On the first row (starting with pin 1, and marked with a 1) you'll find that they list D- as USBP2-, and D+ as USBP2+. The number 2 tells you a few things. First off: It's the 3rd USB port on the motherboard (they started numbering at 0), second it tells you that that D- and D+ must be used for the same port. Case manufacturers are just as likely to number their ports differently.
Take a look once again at the 4-pin joined picture: usbheader
Notice that you're D-'s have either a 1 or a 2 on them. These also tell you that they are part of the same USB port. (Remember, 1 port has 4 required wires). The numbering on the connector and the numbering on the header doesn't have to match.
To connect everything grab the following connectors: a same number D pair, (D-, D+), 1 power, and one ground. If your power and ground are numbered make sure all 4 are the same number.
Tip: Most cases that use all separated pins will bundle these together for you to make it easier.
Now, take your Power, D-, D+, and Ground and line the connector up with the appropriate 4 header pins on your motherboard. The header pins will be in a row under the Intel style, and in the Gigabyte style it will either be a row of 1 pin, a gap, and then 3 pins, or 3 pins, a gap, and then 1 pin. Press the connector down over the header pin and make sure it's firmly attached. Once you have done this go back and grab another set of connector wires (Power, D-, D+, Ground), and hook up your second front USB port. If your case has more then 2 front USB ports, and your motherboard has more then one front USB headers, then repeat the above as necessary.
Example: If you were hooking up the front USB on a A7M266, on a case with the pictured 4-pin joined connector type then: VCC lines up with USB Power, USBP2- lines up with USB1-, USBP2+ lines up with USB1+, and GND lines up with GND. For port 2, VCC lines up with USB Power, USBP3- lines up with USB2-, USBP3+ lines up with USB2+, and GND lines up with GND.
May 21, 2010 | Computers & Internet
Can I download my camera with the disc
1) Connect to your PC via USB, check in "My computer" for extra drive, should be your camera.
2) Buy a universal card reader, also connects to PC via USB and appears as an extra drive.
Mar 23, 2010 | Cameras
I want to connect the extra usb from the ATX but i have 8 wires and on the motherboard 13 connectors
monkybrain
In regards to connecting the USB wires this is common because not all case/USB connectors use the same pin connection. What you will need to do is look up the info in your motherboard manual to see where the pins go. Note the wires/connectors should be labeled as well.
Hope this helps
Issken
Jan 10, 2010 | DFI AD70-SR Motherboard
The extra pin in Netvista/thinkcenter front panel USB
Thank you, you are most kind.
I would wish that you would take a moment, and join FixYa. It is free to join, and we'd love to have you on board.
Regards, joecoolvette
Dec 22, 2009 | IBM NetVista PC Desktop
5 ton carrier. we changed the condenser motor and marked where the wires connected. Old motor had yellow and brown to capacitor. New motor has an extra brown wire with white stripe... I connected it...
The best way to wire that motor is to connect a separate capacitor to it. The brown and brown w/white stripe go to the capacitor. The black and red wires go to the contactor.
Aug 06, 2009 | Heating & Cooling
JP3 USB header
Dear friend here your solution
all usb jumper setting on mother board
http://www.geocities.com/jisfy/USB.JPG
If it helpfull please rate me. thanks sumon (jisfy@yahoo.com)
Mar 24, 2009 | Abit TH7-RAID Motherboard
ASUS K8V-MX Motherboard Logo
206 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
