Question about E-Machines emachines (emachinees) CD-ROM Drive
Cd Drive won't show in my computer not even showing in device manager
  • 973 Answers
You need to reinstall the driver using your recovery disc or System Restore with Windows.
Posted on May 25, 2010
2 Suggested Answers
SOURCE: CD Drive not working at all
lg gsa-h12n dvd writer
Posted on Dec 10, 2008
Acer aspire 5740 DVD not recognized
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Oct 25, 2012 | Computers & Internet
I have a Systemax Venture Microsoft Windows XP Pro Version 2002 Service Pack 3. The system will not longer play dvd's or cd's and cannot burn cd's as well. I'm not sure if something has...
Well the fact that when you put in a cd it does not see it indicates that either the CD Drive is not being detected or the drive has gone faulty and needs replacing.
First Look in the bios of the computer to see if it is seen the drives section. If it is there then look in windows under control panel , system, device manager. Now look under DVD/CD Roms drives (this may differ slightly in XP) to see if in there with no error against it. If not and not in the bios either then the drive has failed. If however it shows in DVD/CD Roms with no error then try a different make of cd/DVD. If this works then the Bios of the drive will need updating. This info is on the manufacturers website. Good luck.
May 10, 2011 | Systemax Venture PC Desktop
Windows: USB Dongle shows up in Device Manager as Disk Drives: KVM vmDisk USB Device, and DVD/CD-ROM Drives: KVM vmDisk USB Device. Steals drive letters I need. How to get around this? have uninstalled...
Hi Bruce:
Sorry to hear that you are having problems. If you still want to use the device, you can assign drive letters to you other devices that do not disrupt the use of you KVM switch. Using device manager, you can change drive letters on all drives except your hard drive, usually drive 0.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
As for uninstalling the KVM device, if you want to completely remove all files from your computer, do a search (off the start menu) and search for *KVM vmDisk USB Device".
The delete all the files that are found in the search.
Let me know if I can assist you further or you need any clarification on my instructions.
Jan 12, 2011 | Avocent DSR2035 (DSR2035001) 32-port KVM...
My cdrom does not show up anywhere even in the device manager. Is it possible I have a bios problem?
does it show when u open my computer,,if so then its working ,,check for drivers and updates,,,nec website
Nov 04, 2010 | NEC NR 7900A (NR7900) CD-RW Burner
My computer isn't seeing the D Drive at all how can I resolve this
go to control panel, system, hardware manager. .and see if it's showing up there..if not,try scan for hardware changes..of course, if you provide the operating system and computer type that will help too.
Dec 06, 2009 | Samsung DELL CD-RW/DVD DRIVE SM-332 BLACK...
I can't access my drive, even though all my tests say it's fine.
Right click on my computer and click manage then click on disk management. Find your drive and give it a drive letter. It probably just needs a drive letter so you can recognize it in my computer,,,Good Luck and let me know if this works...Darren
Oct 11, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
My computer is not reading the cd drive
first off the computer.
open the cpo and reattch all connection to yhour cd dvd rom drive.
then starrt yhour computer.
go to myh computer properites and device manager then clik on scan for hardware changes.
also check in my computer yhourt drivers show or not.
Mar 26, 2009 | Dell Dimension 2400 PC Desktop
Cd/dvd drive doesn't show up anywhere
Have you checked device manager to see if the drive is in there and has exclamation on it??
Nov 16, 2008 | Dell Inspiron B130 Notebook
Cd drive not showing up onlap top
delete the cd drive from device manager. reboot the laptop. the cd drive should automatically de detected on bootup.
to go to device manager:
Right click My Computer icon, choose Hadware tab, click on device manager button.
May 10, 2008 | Medion md40298 Notebook
Cd-rom
Check it from Device manager;
Right Click my computer. Go to properties.Hardware tab; Device manager; See under device manager ! any yello sign; ETC;
If you could not find any alternate Best Solution is try replacing CD DVD Rom
Regards
Rafique
Mar 17, 2008 | HP (PR017UA) PC Notebook
Computers & Internet Logo
135 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
