Help! hello, what convergence IC's do i use for a phillips projection tv model number 50p8341a? I believe i would have to replace two ic's and what website can i purchase the ics from?
  • 8,617 Answers
You will also need to check the 6.8 ohm resistors also. The sey uses STK392-120 ICs two of them. You can get the phillips DPTV305-DPTV345 convergence repair kit from www.tvrepairworld.com which contains the two ICs and 12 6.8 ohm resistors plus instructions on CD. The DPTV and PTV chassis phillips all use that same kit.
Posted on May 25, 2010
Can I have the part # for convergence ICs for Phillips TV Model 51pp9200D/37?
IC convergence number: STK392-120 or STK 392-150 Will work correctly. Any question, please let me know.
Aug 04, 2011 | Philips 51PP9200D Television
Having i think convegence board problems with my phillips model # 60pp9202/17F called tv repair guy said it was my convergence ..colors are alll orange and bottom of picture kinda bubbles up can i replace...
Replacing the convergence board will require a complete convergence adjustment. A better solution would be the replacing of the defective convergence IC. This would retain the convergence settings for the set. I'll locate the part numbers and costs and update this later.
Dan
Aug 31, 2010 | Philips 60PP9202 60" Rear Projection...
I have a Toshiba rear projection TV model # 50H71 for about a month the tv would randomly pop off (lose sound and picture) for about 45 seconds and then come back on now th picture is reduced in size by...
Good Day,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
Thanks for choosing FixYA, Big Irish
Nov 22, 2009 | Toshiba TZ50V51 50" Rear Projection...
Philips 50p8341a - the red converges, the blue does no move. the screen is all reddish with orange lines in it. the sound is ok. took the back off and the red and blue big lights are on, but the other big...
Hi, convergence IC`s have failed, set is usually a good one, call your local tv shops and get a price to replace the "convergence IC`s ", good luck, video-tek
Jul 01, 2009 | Philips 50P8341 50" Rear Projection...
My tv is showing a double picture in red
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
Convergence ICs
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Hope this helps .
Mar 03, 2009 | Apex Digital GB4308 43" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP920217F Convergence Problems
You will need two STK392-120 Convergence ICs and about 4 6.8 ohm 1watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures so you can do the job yourself. Here is the link.
http://servicemanuals.vstore.ca/
Jul 17, 2008 | Philips 51PW9363 51" Rear Projection...
Need the correct convergence IC number for my Phillips Phillips Magnavox rear projection tv P6034C. I am getting the double picture syndrome . It also appears as if I cannot adjust the red convergence...
Thats not the full model number should be something like 43P6034C or etc. Please respond to this same post and I will let you know the correct Ics and resistors because phillips / magnavox will always burn at least 2 often 4 of the convergence resistors as well.
Jun 26, 2008 | Televison & Video
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
123 people viewed this question
Top Televison & Video Experts
Electro Med Services...
