Question about MSI K9N6SGM-V (7309-020(K9N6SGM-V)) Motherboard
Where is jumper reset - MSI K9N6SGM-V (7309-020(K9N6SGM-V)) Motherboard
  • 26 Answers
The reset jumper is labelled JBAT1 (circled in red below). Pins 1+2 are jumpered/shorted right now, just turn the machine off, move the jumper over to short pins 2+3, wait 5-10 seconds, move it back to pins 1+2 and fire it back up. Have fun!
Posted on May 25, 2010
  • 983 Answers
I am providing you the website to download the manaul for your motherboard, Here is the website, Download the manual:
http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=1086
After downloading , search for the BIOS JUMPER in the manual where motherboard architecture is gicen and shown where is the bios/ CMOS jumper, look into it and if you need to reset the BIOS/CMOS you need remove the jumper and put it into reset mode.
Once you have a look in the motherboard manual you will get to know.
There will be three modes in bios jumper, there will be three 2 pinned structure, you need remove the jumper from one pin and switch it another to reset .
I hope this will surely help you.
Rate my solution.
Regards
How to remove a BIOS password from a desk top
This is both trickier and easier than you might think.
  1. Shut down PC, disconnect power, and open case.
  2. Look for two pins sticking up off the motherboard that say: "RESET CMOS" or "CMOS PASS" or "BIOS PASS" or "BIOS RESET" or some combination.
  3. There should be a plastic "jumper" that is attached to ONE of the pins on the CMOS jumper (step two).
  4. Carefully remove the "jumper" by pulling straight up on it.
  5. Replace the jumper so that both pins are inserted into it.
  6. Connect Power and Power On your PC
  7. (it may beep loudly and shut off or it may startup like normal, allowing you to get into your BIOS)
  8. Shut down PC, remove power
  9. return the "jumper" (step two) so that only one pin is connected like you found it.
  10. Power on your PC and you should be good to go.
NOTE: If you don't have a jumper on your motherboard, you will need to find one. Often, a CD-ROM drive or old IDE hard drive will have a jumper on it. If you find a jumper on an old device that is not connected and not running, you can use it so long as you remember to return it to it's original position. Failing to return a "borrowed" jumper from an external device could make it unusable in the future.
Also, never use a jumper from elsewhere on your motherboard. These jumpers can be critical to the operation of your PC and "borrowing" one could render your PC useless and may not ever help you to reset the BIOS password.
NOTE: When you reset the BIOS password in this manner, all of your custom BIOS settings will be reset. Any hardware that you had to configure manually through your BIOS may not work. Overclocking and other features may be disabled by default. This should not be done without proper consideration.
Hope this helps,
Jase
Feb 26, 2014 | Computers & Internet
Jumper settings to reset BIOS on Motherboard Tyan S2925
JP5 Jumper is the reset jumper. Look at this Pdf:
ftp://ftp.tyan.com/quickref/q_s2925_100.pdf
Jun 30, 2012 | Tyan TOMCAT N3400B S2925 S2925G2NR NFORCE...
"Reset you're cmos/bios jumper to
HI,
No need to worry. There are many known ways to reset / remove / bypass the password:
  • By removing the CMOS battery
  • By using the motherboard jumper
  • By using MS DOS command
  • By using software
  • By using Backdoor BIOS password
Now I'll try to explain each method one by one:
A. By Removing the CMOS Battery:
Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the Motherboard Jumper:
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
C. By Using MS DOS Command:
This method works only if you have access to the system when its turned on because this method requires MS DOS. Open Command Prompt from Programs menu and provide following commands one bye one:
debug
o 70 2E
o 71 FF
quit
NOTE: The first character in the above commands is "O" and not the number 0.
After providing the above commands, restart your system and it should reset the CMOS Settings along with the BIOS password.
If you are curious to know how it works? then let me explain the above commands:
In this method we are using the Debug tool of MS DOS. The "O" character present at first in these commands, outputs the values to IO ports. The number 70 and 71 are port numbers which are used to access CMOS memory. By providing FF value we are telling CMOS that there is an invalid checksum and it resets the CMOS settings as well as BIOS password.
Jan 08, 2011 | Intel DG31PR Motherboard
I have no on board video or external video via the agp video card. computer emits no beeps during boot prosess. all power supply voltages are available.
I've got a via p4m266. and I've found that it does that if you put the cmos reset jumpers on the reset setting. check for one stand alone jumper across 3-pins, check readings on board for location of cmos reset jumpers & move jumper to bridge the unbridged connection.
Nov 14, 2010 | MSI : P4MAM2-V (7095-010)...
A200 bios password how to remove
HI,
The best way to remove the bios password is to reset your bios jumper. All boards have the jumper, you will move the jumper from it's current position to the next pin. Example. It has two pins. Jumper Pin 1 and 2. The jumper might current be set on pin 1 and blank. Move the jumper to pin 2 and blank. Leave it on for about 10 seconds and then move it back to the original position. This will reset your BIOS.
Good Luck
Mark
Dec 29, 2009 | Computers & Internet
My foxconn when i try to turn on! dont turn on! but when i reset bios! without jumper can turn on but if i put the jumper again dont start when i try to put on!.
Putting the jumper on the two pins shorts out bios and resets it. Computer will not start if the jumper is on the pins. Leave the jumper off after reset, or just change jumper to the other two pins if you have them on your mobo..
Hank
Aug 19, 2009 | Computers & Internet
Reset Cmos Settings for Acer Computers
There might be a jumper on your motherboard that's labelled CMOS, or reset... you just have to move the jumper to the other pin combination, power up your PC, then turn it back off and replace the jumper.
If you can't find a CMOS jumper, try unplugging your computer and removing the battery on your motherboard for a few minutes. When you turn it back on, your CMOS should reset to factory defaults.
May 07, 2009 | Computers & Internet
I NEED THE JUMPER SETTINGS FOR MICRO STAR MS-6533E MOTHERBOARD. THANS FOR THE HELP!
why are u trying to set the jumpers ? i should have thank u if u add some more details. all the jumpers onboard have their own purpose. look carefully on ur mainboard, u'll see the jumpers with their distinct labels.
May 05, 2009 | Computers & Internet
Jumper settings
There is no jumper settings, it is just a small bridge aside the bios Chip. you bridge the two pins and power to reset cmos.
A much easier way is removing the Cmos coin shaped battery from motherboar for few seconds, and put it back, this will reset Cmos the same .
Oct 05, 2008 | Toshiba Satellite A135-S4527 Notebook
MSI K9N6SGM-V (7309-020(K9N6SGM-V)) Motherboard Logo
4,421 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
