Question about HP LaserJet 3330 All-In-One Printer
Font change How do we change the font on a multi function Laser 3330? We have programmed the fax for one ring and no rings are coming in.
  • 22 Answers
You might have a bad formatter board
test with a regular phone first
Posted on May 26, 2010
How to receive a fax
  1. Connect the multi-function printer to a phone line. Most printers with fax capability have more than one phone jack, so make sure you are plugged into the right one.
  2. Turn the printer on and access the start-up menu. Pick an answering mode based on your expected usage of the fax capabilities of your machine (see the next steps for more information about this).
  3. Put the printer in manual mode if you expect little fax traffic. The manual mode usually requires you to pick up every call that comes to the machine. If you hear the signal for a fax, you push the start button and hang up.
  4. Choose the automatic mode if you expect a lot of faxes or have a dedicated fax line. In automatic mode, the printer listens to incoming calls and determines whether they are faxes or voice calls. Voice calls get sent on to your phone, and faxes are picked up by the printer.
  5. Select the number of rings you want your multi-function printer to give you before dropping a call. If you are using the manual mode you may want to go with four or more rings. Two rings should be sufficient in the automatic mode.
  6. Load paper into the paper tray. Check on the paper level frequently if you receive a lot of faxes.
  7. Set the desired print quality, and you are ready to receive faxes.
Mar 01, 2011 | Samsung SCX 4521F All-In-One Laser Printer
We changed our telephone package last week, eliminating the dedicated fax line to one multi-ring line. The faxes aren't coming through now. Any suggestions?
You will have to set the Multi-ring pattern in the Printer Fax Setup to distinguish between the phone ring and fax ring
Press Setup button
Scroll to Advanced fax setup ( Press OK )
Choose Distinctive Ring Pattern ( DRP )
Set the multi-ring you have been assigned for Fax
Press OK -
Try dialing the no., the Fax should ring
Try sending Fax or Recieving, it should work.
Also, Turn off the ECM
under SETUP - FAX Settings - ECM ( Error correction mode ) - Turn it OFF
Jul 06, 2010 | HP Photosmart C7180 All-In-One InkJet...
The hp laserjet 3330 diverts to fax too quickly
What you need to do is on the printer, hit the menu/enter button, then scroll through until you see "Fax Setup" click enter, then scroll until you see "fax receive setup", click enter, then scroll until you see "rings to answer". Here can you set it to a higher number of rings, just remember to click enter once you've got the number set to where you want it.
Jul 09, 2009 | HP LaserJet 3330 All-In-One Printer
Fax Printing is not Clear
You can change the default font of your printer from the settings panel at the front. Carefully go through the manual and you will be amazed how easy it is to effect such changes. However, if is attached to a computer, it will call the shot as default font of the system overrides that of the printer. Good luck
Apr 27, 2009 | HP Laserjet M1319F Laser Multifunction...
Need to change the pickup from one ring to picking up on the 5th
This should do it:
Press the {Function} {6} then enter
the access code {2} {2} {2} {2}.
Then press {6} {1} and the {Yes} key
press the 'next' (right arrow) key until it displays "set number of rings" . Press "yes" (the current setting is displayed). Press "no" to change. Enter the desired number, then press "yes" to set. Press "function" to exit.
Please rate me :)
Mar 14, 2009 | Ricoh 2050L Laser Fax
Increase the number of rings
Press
function
64
set
look at the printout
look for number of rings
to set the parameter
press
function 74
set
Feb 07, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Changing font size
Try changing the font size in Notepad/Wordpad/Microsoft Word. If that fails, then go to the settings on your printer, and it should have a default size on their that you can change. Change it to 0 and it will go to all sizes allowed.
Hope this helped -CA
Nov 08, 2008 | Brother Multi-Function Center MFC-240C...
I need to set Distinct ring
Press Function then Data Registration press set use the Down arrow to RX setting press set scroll down to RX mode press set Scroll down to DRPD press set pess set again at Drpd Select fax and Choose your ring type.
Apr 09, 2008 | Canon FAXPHONE L80 Laser
How do i get my fax to answer only after 6 rings
Luckily, you can choose to answer at up to 9 rings. It's in Function Parameters, Function 45 "Ring Detect Count". You can change that number from 1 through 9.
Entering function mode:
Function + 7
Hit "Monitor" 4 times
Hit " * "(star)
Press "1" for Function Parameters
Scroll through, or type "45" to get to that parameter.
Hit enter/Start to change.
Jan 09, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
Unreceivable
Manual can be found here: http://www.samsung.com/support/productsupport/download/FileView.aspx?cttfileid=526982&type=Multi+Function+Printer&typecode=16&subtype=Laser+MFP&subtypecode=&cmssubtypecode=1601&model=SF-5100I&filetype=UM&language= Does the unit ring at all? If it does do the following (taken from the manual) Receiving automatically in FAX mode 1. Press Rcv.Mode/Contrast until the display shows ?FAX MODE?. 2. When you get a call, the machine answers the call on a specified number of rings and receives a fax automatically. You can change the number of rings. See ?RINGS TO ANSWER? on page 5.4. To adjust the ringer volume, see ?Adjusting volume? on page 2.8. If the phone is not ringing, then the call is never even getting to your fax machine. Hope this helps If you need more information, please ask before rating this solution. Ed
Jun 09, 2007 | Samsung SF-5100 Plain Paper Laser Fax
HP LaserJet 3330 All-In-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
