Question about Nordic Track Exercise & Fitness
I have a norty track C2500 an the screen went blank
    President:
  • Nordic Track Master
  • 832 Answers
I suggest checking your power plug then check or reset the circuit breaker on the treadmill next to the cord if that ok and the unit is still dead. Unplug unit the remove motor shroud and if you own a multi meter start checking the AC all the way to the lower board and see where the Ac is missing.
If the Voltage is good to the board then check DC Out put going the console wire harness should have 5v or 12v DC depending on model if missing then replace lower board if present, then check the continuity of wire harness if bad replace harness. If good upper console needs to be replaced
Posted on Jun 01, 2010
My treadmill nordatrac c2500 won't incline need a
Dear Sir:
There many possibilities: 1( False signal to due flexible cable loose *tight( 2( console display faulty 3(main motor board faulty 4(the pot attached to the elevation motor need adjustment 5( the gearing can sliping 6( Main motor damaged.
Try to RUN the software calibration for easy diagnose and trouble.
See my personal TIPS for HELP.
sincerely. God Bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 12, 2012 | Nordic Track Exercise & Fitness
What would be the symtoms if my timing chain went out on my 1990 C2500 PU
it would be a no start condition and ther would most likely be extensive valve damage.
Apr 26, 2011 | 1990 Chevrolet C2500
Just purchased a new Nordic Track T7.3 treadmill. Set it up and completed one perfomance workout plus 3/4 of a weight loss workout when disaster struck. The mill was placed on pause and when the start...
Just had mine delivered on February 11th. Ran on it once and the screen went to complete contrast darkness. You could still see the display but you could see it better at an angle than you could looking right at it.
Got on it today and the screen was completely blank just like you (after 6 uses). Sears came and the guy said the screens on these treadmills were junk.
Apparently Sears will be replacing our treadmill at some point!
Mike
Jan 10, 2011 | Nordic Track NordicTrack T7 si Treadmill
Hi, where can i get a C2100E motor control board for my Nordick Track C2500 ?
Two places either iconservice.com under replacment parts or Treadmill Doctor.com under treadmill products
Jul 19, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a Ricoh MP C2500 Copier and I can not select any functions on the menu when I press it with my finger
Your touch screen went bad. This is a common problem with many newer Ricoh models. Get in touch with your service technician to get a new screen.
May 26, 2010 | Ricoh Office Equipment & Supplies
Screen blanks out after a few seconds. If I turn
Fixya:
My IE 8 loads the correct odds on the tote-board and then suddenly the odds go blank.
I have to click down to another track and then click back up to get the odds working again.
The issue happens again at another track that I click on. Forces me to go through the same proccess over again.
This bug related issue is very aggravating so if there is a fix I would appreciate it.
oppusone
My IE 8 loads the correct odds on the tote-board and then suddenlly the odds go blank.
oppusone
oppusone
oppusone
Aug 31, 2009 | AOC LM720 17" Flat Panel LCD Monitor
Sansa E270 Blank Screen and Bad Tracks
well if you can still connect it to your computer just format the mp3 this should work after the format just go to WMP and sync your music
Formating:
1. connect mp3 to computer
2. got to "My Computer "
3. find the mp3 in the computer
4. right click on the mp3 drive
5. click on "Format"
6. click on ok
note : formating will delete all picture,songs, and videos on the device
Oct 30, 2008 | SanDisk Sansa e270 MP3 Player
Camera lens does not retract & view finder is just blue, will not go to other screens
The lens maybe out of track. Perhaps you have bumped the camera or dropped it. Look if the lens are a bit tilted, if so, try straighten the lens with your fingers, very gently. Hope it works.
Oct 04, 2008 | Fuji FinePix F470 Digital Camera
Monitor is blank, power is on
it was on after it went blank & again on means there was a loose connect as it came back on. but now that loose contact has got permanent due to print breack or track open. the problem is in 1 monitor to computer connector not properly connectec. 2 crt base loose 3 track open or print in power supply. 4 if it is ok check for horizontal section print or loose. hope this will help good luck. 1 power supply print b
Sep 28, 2007 | Gateway FPD2275W LCD Monitor
SONY ERICSON W810I
faulty display or software issue
Sep 02, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Exercise & Fitness Logo
182 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
