Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
Narrowbanding-can you look up serial number to see if capable?
If I have a 2 way radio serial number can you tell me if it is narrow band capable for the FCC mandate to go narrowbanding or can you only look it up by product number?
  • Motorola Master
  • 1,654 Answers
Yes, it can be looked up by either method, serial number or product number. In a Motorola serial number the first 3 numbers will tell the kind of radio and the next 3 letters will tell where and when it was manufactured.
Best regards.
Posted on May 26, 2010
Testimonial: "This is great information! Thank you so much! Anna"
On our narrowbanding website (www.narrowbandinglaw.com), there is a link to an article from APCO's magazine, where the author tried to list all (that he could find) narrowbandable equipment. Also, there's a link there to Motorola's website, and while I haven't checked lately, they told me that they intended to try to post a list, too.
Alan S. Tilles, Esquire
Shulman Rogers Gandal Pordy & Ecker, P.A.
www.shulmanrogers.com
Posted on May 27, 2010
Frequency for Motorola MU24CVS UHF (4 Channels) 2-Way Radio
This radio has several available frequencies built into the unit:
1 - 464.5000
2 - 464.5500
3 - 467.7625 *
4 - 467.8125 *
5 - 467.8500
6 - 467.8750
7 - 467.9000
8 - 467.9250
You would need to read out each channel to determine what each of the 4 channels is programmed to. Reading out is easy on this unit. With the radio turned off, select the channel with the channel knob, then hold in the PTT button while turning the radio on, immediately it will tell you the frequency number, (if you want to change the freq you can use the PTT button to walk your way up through the numbers to the number you'd like), then if you press the monitor button it will lock in your chosen frequency and it will tell you the private line code (if zero it is turned off), then press the monitor button again to lock everything in. Do this on each channel and you will know how your 4 channel radio is programmed.
Note: This radio is a wideband radio and only a few were produced with narrowband capability. After Jan. 2013 you are required to use narrowband only in the USA. If your MU24 radio has two RED dots above the word Spirit it is narrowband on only frequencies 3 and 4. If your radio has no red dots on the label your radio is wideband only.
Best regards.
Dec 08, 2013 | Motorola MU24CVS UHF (4 Channels) 2-Way...
I NEED TO KNOW WHAT FREQ. RANGE IS ON THIS SERIAL # 777FWLE408
Sorry, the serial number does not tell the frequency band of the radio. From this serial number I can tell you it is likely an SP50 radio, and it wwas produced Nov. 1996. You would need the model number to know the frequency band. The model number of an SP50 radio beginning with P93 would be VHF, and if P94 it would be UHF.
Note: With the mandated change to narrowband by Jan. 2013, only SP50 radios with a 00 (double zero) in the model number will do the new narrowband. Those models on wideband would have a 20 (twenty) in the model number. Example: P94YQT20AA2 would be a wideband UHF radio.
Best regards.
Aug 17, 2012 | Motorola HT1000, MTS2000, MTX8000/9000...
Is the LMH 3142a a narrow bandable radio
none of the LMH radios are narrow band capable, also no "L" series radios are narrow band capable. Most "E" series are though.
Nov 21, 2011 | Bendix King LPH, LPA, LPX, EPH Compatible...
I need to know if my gm 300 is narrow band
Look at the model number. Following three alphabet letters it will have either the number "00" (narrowband) or the number "20" (wideband).
Best regards.
Aug 30, 2011 | Motorola MU21CV (1 Channel) 2-Way Radio
What model mobile motorola radios and motorola HT1000 portables are narrowband capable?
Most Motorola portables manufactured during the past five years or so are capable of being programmed for narrowband operation. A definite exception is the Saber which is strictly a wideband radio.
The narrowband-capable versions of the HT1000 have a model number ending in "DN." Some of the previous models ending in "CN" may or may not be narrowband-capable.
More in-depth information may be found at www.batlabs.com or at http://batboard.batlabs.com.
Mar 24, 2011 | Motorola HT1000, MTS2000, MTX8000/9000...
Are my Motorola MagOne BPR40 handheld radios narrowband capable?
Yes. They are programmable to either wideband or narrowband on a per channel basis.
Best regards.
Feb 16, 2011 | Motorola Mag One BPR40 Two Way Radio
How to narrow band the ht1000
Some HT1000 are programmable to narrowband, while sadly others will need to be retired. See your local Motorola dealer for more details.
Best regards.
Feb 12, 2011 | Motorola HT1000, MTS2000, MTX8000/9000...
CAN THE HT1000 PORTABLE 16 CH. BE PROGRAMED VHF NARROW BAND,IFSO WERE CAN I GET IT DONE
The HT1000 change to narrowband depends on the generation of HT1000 you have. If a model made since the year 2000 (or so) it should be able to be either programmed or converted. If it is a pre-2000 (or so) model, it will not be capable.
Programmable narrowband can be done by any authorized Motorola dealer. Conversion to narrowband requires components in the radio to be changed by a qualified electronics technician using approved methods, not necessarily available at every dealer.
Check with your local Motorola dealer to see if they can help you with programming or conversion. If not, repost your model number in a question here on FixYa and we will let you know which scenerio you are facing and give you some suggestions on where you can have it done.
Best regards.
Apr 21, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
One quick question about narrow band compliancy? our agency uses a Motorola MTR 2000 repeater S/N 474czh0094, MOD. #T5766A 100W. Is this narrow band comliant? Thank you , Lt. Dave Gamache Yreka Police...
The MTR2000 repeater currently available is capable of narrowband (aka 12.5K channel spacing) and wideband (25K channel spacing).
Your serial number indicates your MTR2000 was manufactured in April 1999, which would be around the time narrowbanding began to come on the scene. The only way to know for certain is to have a dealer read out the repeater and see if it is programmed for narrowband. Most-likely it is.
Jul 10, 2009 | Motorola Radio Communications
Realistic pro 2020 scanner
The Realistic PRO-2052 is an old (vintage) scanner receiver with fixed AM and FM modes on the bands it cover, as specified by the U.S. band allocation. The PRO-2020 covers only the VHF and UHF frequencies and modes AM and FM is not user selectable. Frequencies can be programmed into any of the 20 memory channels
U.S. Coverage: (varies from state to state and other countries. We don't use 30-50 Mhz here in the Philippines for 2 way mobile communications, except for cordless phones)
30-50 Mhz Lower VHF at FM narrowband only (covers mobile, emergencies, businesses, etc. and
cordless phones)
108-136 Mhz Aircraft band at AM narrowband only
138-174 Mhz Amateur and Commercial band at FM narrowband only (2 meter band)
410-512 MHz Amateur and Commercial band at FM narrowband only (70 cm band)
If you're trying to select AM or FM for a specified frequency, I'm afraid you can't do that as it is not selectable.
If you are trying to program AM Broadcast frequencies (mediumwave (MW) or FM Broadcast frequencies (FM radio stations), those were not covered by your PRO-2020's microprocessor. Even if you modify your scanner to receive those bands, you will not hear radio transmission properly since the receiver do not decode FM wideband, which is the standard mode for FM broadcast and Television band.
MANNY DE GUZMAN, JR.
SoundMagik Home Studio
Manila, Philippines
Visit my website at http://mannydeguzmanartist.wetpaint.com
My talents and modeling site at http://teenmodels2007.wetpaint.com
Jul 02, 2008 | Radio Shack Pro-2052 Scanner
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
1,878 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
