Question about PNY 8GB Secure Digital High Capacity Memory Card
My card is locked and I can not take any pictures with it in my camera.
  • keishamylesi May 25, 2010
    Thank you so much your help fixed my problem.
  • 4,281 Answers
For that first pull battery and memory card from camera.
Then connect your memory card into card reader and connect that card reader to computer.
Then you can see your memory card in my computer as removable storage.
Then take backup of all files and then format memory card then you can use it again.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 25, 2010
    there is a write protection on my card how can I remove that?
    1. There is a write-protection tab on the mini sd card HOLDER. Every
      time you insert this into your PC or card holder, this tab slides to
      the write protect position. Either keep resetting, inserting &
      reinserting until it doesn't slide or tape it down.
    2. There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
    3. The mini sd card has some error: Go for a low level formatting.
    4. The card has virus: Remove the virus.
    5. Let me know if you need further assistance.
I try to take a picture and this comes on the screen write protect.
This is a common problem with SD & SDHC type memory cards - and is easily fixed.
Remove the card from the camera and inspect the edge for a sliding tab and lock indicator.
690144df-2144-46c7-9b90-dd85c207a09b.jpgYou can see the tab & lock indicator on the left side edge in the picture of the front of the card above. Slide the tab UP - away from the lock position - as shown in the picture. The card is now able to be written. When the tab is in the lock position, the card may only be read.
Carefully reinsert the card into the camera - taking effort to see that the tab is not bumped / moved back into the lock position. You should be able to take pictures and have them saved to the card - without the locked message from this point on.
I hope this helps & good luck!
Aug 02, 2013 | Canon Rebel XT / EOS 350D Digital Camera
Card locked shows of view finder, cannot take a picture it shows a't picture but won't take a picture
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 06, 2012 | Canon PowerShot S2 IS Digital Camera
Card is locked
There is a possibility of two problems here, your camera uses an SD/SDHC card which has a slide lock on it I'll give you a diagram for this.
Next thing there is a Custom Set Function I thinks it's number 5 "No memory Card" it's there so you can switch your camera over to make pictures without the card, which to me is not so good because it lets you make pictures without a memory card.
Make sure you have an SD card in your camera and it's been formatted for that camera and change this to "Lock" so you can't make pictures without a card in the camera.
So a quick recap make sure you have an SD/SDHC card in your camera, make sure it's formatted for your camera and take Custom Set Function and change it to "Lock". You should be good to go
Jan 03, 2011 | Nikon D80 Digital Camera
The camera says in the screen that the card is locked The memory card is locked and I cant figure out how to un lock it is in the set up or what do I do ? my camera is EXILIM 8.1 Mega Pixels
I've never fiddled with this brand of camera, but there will be the option to lock the pictures in the menu. In your manual, look for "memory", "locking your pictures", things like that. Also, some memory cards have a plastic tab that slides to lock the card- make sure that isn't in the lock position, if your card has one. Good luck, and hope this helps.
Jun 11, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
My camera says card locked
Your memory card has a lock switch, move the switch to unlock.
Jul 02, 2009 | HP Photosmart M447 Digital Camera
Casio Z80 card locked
Make sure the write protect lock is off by taking the card out of the camera, face the card towards you, look for a small white tab on the left hand side of the card, to unlock it push the tab down, it will be at the side of the card like this 59a6de4.jpg .
If the lock is off and you still get the error then the card maybe damaged.
Hope this helps.
Good luck
Jun 22, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
When i try to take pictures my camera says card locked.
It's the memory card or SD card you have in the camera. (it sounds like)
Try taking the SD card out and if you look at it closely there is a little switch/ thing you can slide. Slide it to the other side, put it back in your camera and try again. Hope that helps
Jun 02, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
CARD LOCKED
take out the memory card and move the switch located somewhere on the memory card usually on the side to the unlocked position. Then the memory card isn't locked this is so you don't accidentally delete important things
Thanks and enjoy,
Lee
Apr 26, 2009 | Pentax *ist D Digital Camera
My camera wont take pictures says card locked
There is a lock on the SD card
Check this is good.
Regards
Richard.
Feb 02, 2009 | Vivitar ViviCam 3935 Digital Camera
Sd card not working
Check to make sure you didn't accidentally move the locking switch on the SD card to the locked position. There will be a switch on the side of the card. One side of the switch says locked, (or has picture of a locked lock) and the other side says unlocked, or has a picture of an unlocked lock. Try it out.
Dec 31, 2008 | Nikon Coolpix L11 Digital Camera
PNY 8GB Secure Digital High Capacity Memory Card Logo
24 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
