Question about Kenmore Washing Machines
Need to replace the lid switch and how to get to it. Do we need to completely remove the casing? Then how to replace the lid switch?
    President:
  • 1,218 Answers
Good day,
Yes, the whole cabinet needs to be removed. The whole front sides, and top are actually one piece, although it oesn'r look like it.
Your first step is to rotate the console out of the way. Be aware the 2 screws that hold it in place can be either on both bottom corners, on both bottom corners but with end caps that have to be unsnapped first, and lastly on both back corners.
Here's a tutorial on disassembling.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Posted on May 25, 2010
Instructions on how to replace lid switch on Whirlpool Washer, model # LSQ911OPW2
The following link explains how to replace the lid switch on a Whirlpool top loader:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
The part number (if you haven't purchased a replacement yet) is 3949247. If you have questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Sep 11, 2009 | Washing Machines
Replace lid switch
You will need to not only remove the control panel, but you will also need to remove the washer casing from the frame in order to acces the switch. It sounds intimidating, but really isn't that difficult to do. The following link explains how to replace a lid switch:
Your washer is manufactured by Whirpool, so these instructions will apply. Most commonly, the lid switch is located under the washer casing along the right hand side of the lid. If the model number you have this listed under is correct, your switch is under the washer casing near the right lid hinge. The mounting screw(s) and ground connector are under the operator console. For clarification, you can refer to pcappliancerepair.com for some excellent exploded view diagrams to assist you. The lid switch is located under the "Top and Cabinet Parts" heading.
If you have any questions about this repair, or need additional assistance, please let me know.
Sep 11, 2009 | KitchenAid KAWS850LE Top Load Washer
Washer fills but won't agitate
Check your lid switch.
If the washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
A new lid switch or lid strike (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all them for the best price.
If you have questions, or need additional assistance, please let me know. Please post back with a complete model number (located on a nameplate around the wash tub opening) with your questions, so that I may be able to provide you with better assistance. I hope this is helpful.
NOTE: You do not need to bail or empty the wash tub to complete this repair.
Sep 10, 2009 | Kenmore 22422 Top Load Washer
How do I remove the cabinet on a direct drive washer. I have a bad lid switch.
The following link explains step-by-step how to replace a lid switch:
You will need to remove the washer casing from the frame for better access to the switch. Once you disconnect the lid switch connector plug from the timer, push in on the release tabs of the white connector plug located on the washer casing and push it down through the hole it is installed in. Now reach under the washer top and remove the switch from the washer casing. Disconnect the ground wire and remove the screw(s) that hold the switch in place.
If you have the type of lid switch that is mounted near one of the lid hinges, this type unplugs and the mounting screw is removed, along with any ground wire.
If you have questions, or need additional assistance, please post back with your complete model number (located on a nameplate around the wash tub opening) let me know. I hope this helps you.
Sep 08, 2009 | Washing Machines
Machine washes but will not spin and drain to go through the rinse cycle??
A new lid switch (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all them for the best price.
Sep 08, 2009 | Kenmore 24032\24036 Top Load Washer
Won't drain after wash cycle. no noise, no dial movement model # 110.28912790
A new lid switch (if needed) can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. The part number is 3949238. All these sites offer competitive pricing, so shop all them for the best price.
Sep 07, 2009 | Washing Machines
Kenmore washing machine fills then stops
Sep 05, 2009 | Washing Machines
I think lid switch needs to be replaced
It could very well be the lid switch. Or, in the case of your washer, it could be the actuator that controls the switch, or the lid strike on the lid itself. Appliancepartspros.com has some excellent exploded view diagrams that you can refer to. Type in your model number (the last character is a zero "0", not and O) and the lid switch components will be listed under the "Top and Cabinet" heading in the following manner:
Item 10 - Lid Switch Shield
Item 11 - Lid Switch
Item 12 - Lid Switch Acuator
Item 20 - Lid Strike
Any one of these components could have been damaged so you will need to inspect them all.
The exterior washer case has to be removed in order to view these components. Follow these steps:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
The lid switch and associated components are located on the right hand side. Refer to the parts drawings on the website I referenced to assist in part location. It's a pretty easy repair job. All you should have to disconnect is a couple of electrical connections, a ground wire and mounting screws.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
If you have questions, or need additional assistance, please let me know. I hope you find this information helpful.
PS All parts combined, cost less than $30. Not bad for a Do-It-Yourself repair.
Aug 26, 2009 | Washing Machines
My 70 series kenmore washer won't spin . I think it is my lid switch, how do I remove it to replace it?
To replace a lid switch on a Kenmore top loader, just follow these steps: First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps: 1. Under the console you will find the lid switch connector. Unplug the switch from the connector. 2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release. 3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first. You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge. Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps: 1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips. 2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in. 3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget. A replacement lid switch can be purchased on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. All these sites offer great service and competitive pricing, so shop around for the best price. Use your complete model number (located along the tub rim under the washer lid) for your search criteria. If you have questions along the way, please let me know. I hope this helps you.
Jun 09, 2009 | Kenmore 25852 Top Load Washer
Washing machine not agitating
If your washer does not recognize when the lid is closed, then this may be a symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $25 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. Post back if you have any questions. Replacement parts can be found at either searspartsdirect.com, or repairclinic.com. Just type in your COMPLETE model number (located around the wash tub opening) and follow the prompts. Both sites offer competitive pricing.
May 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
18 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
