Question about Metrologic Instruments MS1690 Handheld
Not scanning 2D
Hey...
my metrologic 1690 is scanning 1D barcodes with ease but not scanning 2D barcodes at all.
I have tried configuring it several times...but it jus doesnt scan.
Apart from that, I am not able to configure it using the metroset2 program.
Do suggest a solution
    Problem Solver:
  • 13 Answers
Hello Having loaded the reader to metroset, print setting on paper and you read on paper. This player does not confugura with usb. give me answer. Roberto
Posted on Dec 17, 2008
The barcode reader eclipse ms5145 powers on,the laser light blinks and beeps at scan by not scan the barcode
It could be either one of two things, first of all will this unit scan any barcodes, or is it just one particular one it will not scan. If nothing scans and if no special programming was added to the scanner I would consider defaulting the unit back to factory settings. This procedure can be found in the manual that came with the scanner or here is a link http://www.honeywellaidc.com/CatalogDocuments/00-02544%20Rev%20K%202-11.pdf *** If you are going to do this please confirm that no special programming was done to this *** but normally they are ready to scan right out the box. So scan the barcode to "enter/exit configuration" the unit will beep tree times, then scan the "recall defaults" and the unit will beep once. Then scan the "enter/exit configuration" once more. Then try to scan a retail barcode. Hope this helps.
Nov 02, 2012 | Eclipse Metrologic MS5145 Barcode Scanner
Unable to scan a certain barcode, i think it's just a configuration as I'm able to scan some. I know this model works as i already have one that scans OK but was set up before my time in this company. I...
what kind of scanner is it? is it a 2d barcode that you are trying to scan?
Also make sure it isn't a printer issue: ie: barcode is too light.
Does the scanner act like it sees the barcode? beep or any other notification?
Oct 04, 2017 | Dolphin 7600 Barcode Scanner
We are using a Metrologic MS9520 (keyboard wedge) with QuickBooks. It won't scan barcodes provided by Quickbooks, even though it's supposed to be compatible. We've downloaded about every driver, config,...
What I would first is to bring the barcode scanner back to factory defaults. To do this you will need the manual that came with the scanner, on the first page is a bar code that say "enter/exit configuration mode" scan that first and you will hear three beeps, then scan the bar code for "recall defaults" and rescan the bar code to "enter/exit configuration mode" then retry using your scanner, if this does not work bring up "notepad" on your computer and try to scan any bar code form any retail item. This should scan, if it does net then it could be a defective scanner. See page 2 on the manual link
http://www.posguys.com/download/voyagerprogramming.pdf
Nov 11, 2010 | Microsoft Metrologic MS9520 Voyager...
How to Scan 2D barcode on MC55 (mc5574). How to enable Imager mode to scan 2d , as currently my mobile (mc55) only scans 1d barcodes. Thanks
unfortunatley if your device is preconfigured for 1d only you will not beable to scan or decode 2d barcodes. Which configuration of the mc55 do you currently have? if you can provide me with this information i can let you know if it is possible or not.
Oct 13, 2010 | Zebra Symbol MC5574 Wireless Enterprise...
Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
May 25, 2010 | Microsoft Metrologic MS9520 Voyager...
I have not instruction for default settig where are barcode for default setting
Check metroselect single line configuration guide page no. 2
1) Scan Enter/Exit configuration mode it gives 3 beeps
2)Scan recall defaults it gives single beep
3)Scan Enter /exit configuration mode it gives 3 beeps
Now scanner is set to default setting
Sep 16, 2009 | Microsoft Metrologic MS9520 Voyager...
Scanner makes the right nosie and the ligth come on when scanning but does read the barcode
What type of cable are you using to connect to a host?
You will need to configure the scanner for that type of connection, for example, usb, keyboard wedge, serial etc.
If you have purchased it new, you should have the configuration barcodes on the instruction manual, otherwise you wil be able to download the full manual from metrologic website.
Mar 26, 2009 | Microsoft Metrologic MS3780 Fusion Barcode...
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
Ms9535 bt not reading barcodes.
I'm using the same Barcode reader, the Metrologic MS9535 VoyagerBT.
The brief humming noize is called a "Rasbery tone" in the manual. It means that the barcode reader is not configured to read that kind of barcode, a barcode Code if you will.
There are many types of barcodes so you have to go to the Metrologic Website and get the Barcode Configuration tool to configure your barcode reader to read the type of codes you will be using.
Alternatively there is a book with configuration barcodes you can scan to configure your barcode reader manually.
Sep 28, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
Metrologic Instruments MS1690 Handheld Logo
448 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
