Question about Hayward Navigator Pool Cleaner
Directions on removing filters - Hayward Navigator Pool Cleaner
  • 640 Answers
Removing the filter on these automatic pool cleaners is easy. It should be in the easy open bottom. After you disconnect, turn the unit upside down and locate and loosen the captive screw. You can clean this area and reapply the captive screw.
Posted on Jul 20, 2010
Change fuel filter
NO smoking or ignition sources within 30 ft. The fuel line to the filter may be under pressure so remove the line slowly and catch all leaking fuel. Filters are directional so install following the direction of fuel low arrow.
Feb 16, 2014 | 1998 GMC Sonoma
Where is the oil filter located in a toyota 2004 avalon six cylinder
As you are standing in front of the car with hood open, the oil filter is located directly under the left side of the exhaust manifold and to the right of the alternator. The filter angles upward, so have a drip pan directly under the filter location when you remove and replace with new. Another tip: The filter removal device that works the best is the type that attach to the end of the filter and you turn with a ratchet wrench. You will need a short extension for the ratchet wrench. Longer one will not clear the radiator fan when trying to remove. Wrap around filter wrenches do not allow enough room to clamp on and turn the filter loose. In some cases, you can hand remove them. This is much easier with the Fram design filter that has the rubber in the bottom of the filter housing; easier to grip and turn.
Aug 30, 2011 | 2004 Toyota Avalon
Fuelfilter try to change fuelfilter and wont come
ou need a special tool to remove the fuel lines on your vehicle. Fortunately Ford had the wisdom to provide it to you. Here's how to do it.
Removal:
Warning: because of the combustion characteristics of gasoline, always use extreme care when removing and installing any fuel system component or personal injury or damage to the vehicle may occur.
  1. Perform the fuel pressure release procedure.
  2. Raise vehicle on hoist.
  3. Remove push connect fittings at both ends of the fuel filter. NOTE: To remove 5/16" push-connect fittings, use Fuel Line Removal Tool T90T-9550-B or tool supplied on vehicle. Tool is located 254 mm (10 in.) behind fuel filter. Place in glove compartment after use.
  4. Install new retainer clips in each connect fitting.
  5. Remove fuel filter by pulling fuel filter toward center line of vehicle and free from fuel filter bracket. NOTE: The flow arrow direction should be positioned forward and downward to make sure of proper fuel flow through replacement fuel filter.
Installation:
  1. Install fuel filter in fuel filter bracket, ensuring proper direction of flow.
  2. Install push connect fittings at both ends of fuel filter.
  3. Lower vehicle.
  4. Start engine and inspect for leaks.
Mar 25, 2011 | 1998 Ford Windstar
On a '95 winstar, where is the fuel filter located?
Fuel Filter Fig. 3: The fuel filter is located under the vehicle on the driver's side frame rail 89691g08.gif
Note the arrow showing direction of flow. It must always point toward the front of the vehicle 89691p14.jpg
Although the manufacturer does not specify a replacement interval for fuel filters, we feel the fuel filter should be replaced every 60,000 miles (96,000 km) under normal conditions or 30,000 miles (48,000 km) under severe conditions. NOTE: For fuel pressure relief and push connector fitting removal, please refer to Section 5.
  1. Relieve the fuel system pressure.
  2. Raise and support the vehicle safely.
  3. Place a rag under the fuel filter to catch any residual fuel that may leak out when the filter is removed.
  4. Remove the push connect fittings at both ends of the fuel filter.
  5. Install retainer clips in each connect fitting.
  6. Note the flow arrow direction for installation reference.
  7. Remove the fuel filter by pulling from the bracket. To install:
  8. Install the fuel filter in its bracket, ensuring proper direction of flow as noted earlier.
  9. Install push connect fittings at both ends of the fuel filter.
  10. Lower the vehicle.
  11. Start the engine and check the filter connections for leaks by running the tip of your finger around each connection.
Dec 19, 2010 | Ford Windstar Cars & Trucks
Front air vents have diminished velocity
Your in cabin air filter is probably clogged. $12 at rockauto.com
you could remove the filter and blow it out with compressed air. Put it back oriented in the same direction as removed. Your owners manual should have detailed directions.
Aug 21, 2010 | 2003 Dodge Sprinter
How to replace the cabin microfilter
Hello, I'm sending you exploded view of the glove box and the in cabin micro filter cover illustration. Remove the two upper screws on the glove box and carefully pry metal clips loose.
Disconnect glove box lamp electrical connector. Do not let glove box assembly hang from glove box lamp harness.
Remove three lower screws and remove damper clip from glove box door. Separate glove box housing and passenger instrument lower panel.
Remove three screws and remove in cabin micro filter cover.
Remove in cabin micro filters from front heater and cooling unit assembly.
Note When installing two new in cabin micro filters ensure that the filters are facing in the direction indicated by the direction arrow for the airflow. Direction arrow is printed on side of in cabin micro filters.
Install in cabin micro filter cover. Reinstall glove box.12eb879.gif63a72f6.gif
Thanks
Jul 27, 2010 | 2005 Nissan Quest
How to change the fuel filter on a suzuki grand vitara 2.0td with RHZ engine
Fuel FIlter - Removal
  1. Relieve fuel system pressure.
  2. Remove or disconnect the following:
    Negative battery cable Fuel lines from the fuel filter Fuel filter
To install:
  1. Install or connect the following:
    Fuel filter and tighten the bracket bolt. Note the fuel flow directional arrow. Fuel lines to the fuel filter. Negative battery cable
  2. Start the engine and inspect the fuel filter connections for leaks.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Relieve fuel system pressure.
  3. Remove or disconnect the following:
To install:
Fuel filter is incorporated in fuel pump assembly in fuel tank.
Hope this help.
May 15, 2010 | 2003 Suzuki Grand Vitara
I need to replace my Nissan Quest 2007 in cabin micro filter
I'm going to send you exploded view of the glove box and the in cabin micro filter cover illustration. Remove the two upper screws on the glove box and carefully pry metal clips loose.
Oct 10, 2009 | 2007 Nissan Quest 3.5 Minivan
Loacation and replacing dust @ pollen filter, 2000 vw beetle
Dust and pollen filter, removing and installing
The filter is located in the right rear of the instrument panel under a cover.
Components of dust and pollen filter:
97527421
1 - Frame 3 - Filter element 4 - Plastic nut, 2.5 Nm (20 in lb ) 5 - Filter housing with seal Removing
97527422
  • Push center cover -1- forward -arrow A- and lift up to remove.
97527423
  • Remove screws -arrows-.
  • Lift right plenum panel cover -1- and remove from clips at front and rear edge.
  • Pull cover -1- toward center of vehicle and out of retainer in A-pillar to remove.
97527424
  • Remove screws -arrows- and remove right closeout panel -1-.
97527425
  • Remove rubber grommet -1-.
  • Press tabs of filter housing in direction of -arrow-.
  • Remove filter element with frame in upward direction -arrow A-.
Installing
  • Guide frame -1- into first slot on left and right sides of new filter element.
  • Press frame with filter into housing -2- and engage retainers.
Jun 05, 2009 | 1999 Volkswagen Beetle
Air filter
Remove the Drip Bucket and you will find the bottom of the filter at the top of the opening where the bucket was. The filter is behind the front grill. Push the tabs away from you and pull down.
Aug 30, 2006 | Kenmore 54501 Dehumidifier
Hayward Navigator Pool Cleaner Logo
52 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
