Question about Amana Washing Machines
Amana clothes washer model LWA80AW, serial # R9903011919, when washing light weight items such as shirts they come out of the washer with small black marks. My guess is that they get caught under the agitator. There are a few small black marks on the stainless steel tub at the base of the agitator. The machine has been in service for about 10 years and works well. The black mark problem is recent. Because of a tight fit the agitator is very difficult to remove
SOURCE: Black marks on clothes
My wife complained that we were having similar problems recently. After investigation I located the remains of a pen entering the filter and removed this and did a few empty boil washes to remove any remains of ink and this worked for us. Check the filter and hose between the drum and filter.
Posted on Mar 03, 2007
  • 213 Answers
SOURCE: washing machine
the u-joint balancer kit needs to be replaced. it located under the wash plate where your clothes. its not the stainless steel. you might want to do a search to see if your model falls under the class action on this washer before you repair it
Posted on Nov 28, 2007
early1234
  • 871 Answers
SOURCE: washing machine problems
is the spinner inside color black? this might be the cause you have black marks.
i suggest you buy a replacement for that spinner.
Posted on Jan 14, 2008
  • 125 Answers
SOURCE: Frigidaire Washer - Loose Inner Tub
the inner drum is most likely broken. go to sears.com select appliances then select parts enter model number and you can get a blow up. Hope this helps.
Posted on Jan 31, 2008
  • 5 Answers
SOURCE: Black mark on clothes after washed in Maytag top load washer.
Check and make sure the seal at the bottom of the washer is not wore out. Alot of times you will get grease from the bearins and drum assembly if this wears out.
Posted on Apr 14, 2008
Where can I get good collections of T- shirts for traveling?
T- shirts are always preferred while travelling. It is mostly light weighted and comfortable to wear while travelling.
T-shirts will provide a base layer and are also perfect for hot weather.
I can suggest you some of the Best Travel Shorts and shirts :
1)Men's Moisture Wicking T-Shirt
2)Women's Yoga T-shirt
3)Men's Wicking Crew Neck
4)Women's Yoga Long Sleeve
5)Women's Crystal Cove River Shorts
6)Columbia Men's Barracuda Shorts
Sep 15, 2017 | Washing Machines
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin ยท Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
Amana 7300 Tandem
Check the drum surface of your dryer for possible object that may be stucked in the drum holes that may cause damage to the clothes. You may do similar checks of the washer drum if your dryer drum checked negative.
Good hunting.
Aug 21, 2017 | Dryers
When I have only one item or a very small amount of clothes in washer no matter whether it is set to normal or quick wash, it doesn't spin the clothes dry. I have to try to put it with a bigger load to...
If you just got it I would call the manufacture it comes with a 1 year warranty might be a board or sensor issue there are sensor's that tell how much weight is in there so it knows how fast to spin the drum thats where the power saving features come in.
Jan 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
Comes up with the sign UE ??
Hi
Thanks for using FixYa. The error code UE means there are some heavy clothing is loaded. Rearrange items to help balance the load. If the imbalance is heavy, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and will display the error code UE. In case, if the load is small then you need to add 2-5 clothes to balance the load. If the load is out of balance then you need to rearrange the clothes to balance it. Although the Washer has an imbalance detection and correction system but if still the problem persists then it means that it is due to control error and needs to replaced preferably by a qualified service technician.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 09, 2009 | LG WM-2277HW Front Load Washer
For some reason, my washer is now starting to leave rust color stains on my clothes. Not on all clothes but only on the corner areas of clothes like the tips of the collars on mens shirts or the small...
If you wash your clothes with warm or hot water, try using ONLY cold to see if the problem goes away. Sometimes older water heaters start to produce rusty-colored water as they age.
Jul 12, 2009 | Kenmore Washing Machines
Clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso
This could be an out of balance condition. When its happened to my washer, I rearrange the load if its large enough, and if its not, I find other items of like weight and add them to the load and start over. Calypso's are sensitive to fabric weight, so If you're washing towels, wash only towels and wash cloths. Make sure you put small items, like bras, panties, nighties, etc., in mesh bags and combine them with other light weight fabrics.
Aug 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 80 series washing machine
Marrr
Ingllis washers have a bad habit of picking up socks, small items anyway in the drain protector hose, slows down water flow but ensures the items dont get sucked into the impeller.
from the underneath you shhould be able to see a clear cup sized container with a hose in the side, held in with hose clamps. check if this is filled with any clothing, undo the hose clamps and you should bew able to empth the cup with fingers
Apr 06, 2008 | Kenmore 24902 Top Load Washer
Washing Machines Logo
157 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
