Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
I have a 96 harley classic, yesterday I blew a hole in the right side of the jug at the top near the manifold. What on earth would cause this?
  • 623 Answers
Detonation or failure of the connecting rod or wrist pin maybe.
Posted on May 25, 2010
  • Harley Davidson Expert
  • 119 Answers
Brether timing being off by a tooth can literally mae the back cylinder nothing more then an air compressor and booom they go up quick then
Posted on Jun 07, 2010
Ticking noise near top left side of manifold
could be one of two things. #1 is your spark plug leads could be faulty causing thre srark to jump to the block that is earthed to the negative of the battery or #2 it could be that your manifold has a leak will also cause a ticking sound. if you have lost power or your fuel consumption is not what it was before the sound it is probly a leaky manifold> easy to repair and no expensive and it is diy. if you need help contact me
Sep 04, 2013 | 2002 Saturn L-Series
2000 Yamaha V star Classic 1100; Once it warms up, tends to backfire a bit and overrevs in low gear (very high idle). What should be the cause of the high idle.
The idle is set too high. Check on the left side of the engine, about mid point of the jugs "V", you should see a knob near the middle. Turn it R/L until the idle lowers. (slowly!) (only AFTER it has warmed up.
Aug 21, 2010 | 2000 Yamaha V Star 1100 Classic
1996 harley sportster. It idles fine but when going it acts like it isn't getting enough gas.
First check for a leak around your manifold. You may just have an intake leak. Shine a flashlight between your jugs and see if their is black sooth around your manifold where it joins the jugs. The guy above doesnt have a clue. It really does sound like an intake leak.
Jun 16, 2009 | 2000 Harley Davidson XL 1200 S Sportster...
I have a 96 sportster. no oil to top end
i just did a 883/1200 conversion new jugs and piston i put in a set of used 1200 f1 cams and heads now i have an oil pressure problem at idle ???????
Jun 12, 2009 | 2000 Harley Davidson XL 1200 C Sportster...
MISSING HOSE ON TOP OF TRANS ? WHERE IT CONNECTS?
If it's the hose to the vacuum modulator on the trans, then the other end should be connected to manifold vacuum. Look for an open port on either the throttle body or carb (whichever you have)... Hope this helps...;-)
Apr 24, 2009 | 1994 Chevrolet Caprice Classic
Need to reassemble the D.E. filter
All D.E. filters are basically the same. There are two plastic manifolds. One attaches to the bottom of tank by threads or bolts. The other plastic manifold goes on top, and ussually has small holes in this manifold for stainless rods to run through.All fabic looking materials(grids) run between bottom manifold, and top manifold.All grids must be washed free ofD.E.(diatomacus earth). Place bottom manifold on solid ground and begin plugging grids into large holes in manifold so they form a circle, this sometimes takes two people. Place top manifold on other end of grids in a simular fashion.Gently turn assembled filter to its side while holding together, and run ss rods through small
holes in bottom manifold, i n between grids , and through small holes in top manifold. Secure rods with ss washer and nuts, until snug but not overtightened.
Feb 15, 2009 | Jacuzzi Pool & Spa
Smoking Jug
Sounds like you have a blown head gasket. Does it go away when the engine warms up? Does it "chirp" when you blip the throttle? The changes you made had nothing to do with this, but when you started the cold engine and twisted the throttle to hear your new power the head gasket went away. Harmless until it gets real bad and does not go away when the engine heats up.
Dec 25, 2008 | 2000 Harley Davidson FLSTC Heritage...
Lands Phones Logo
181 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
