Question about Coleman Powermate Premium Plus 6250W Portable Generator
Where can I get owners manual?
We purchased a used coleman generator and we need to clean it put new oil and get a spark plug.
Go to powermate.com and click on the "manuals" button.
Posted on Jun 18, 2010
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
I am looking for an owners manual for a Coleman Powermate generator model PMO645250
Powermate doesn't have an owners manual listed for the PM0645250 on their website.
Since wintertime is a good candidate for power failures I would recommend using a good synthetic 5w-30 oil as it is a good year around oil. This would make starting much easier during the cold weather
Oct 20, 2014 | Coleman Electrical Supplies
No spark replaced coil no spark does the low oil have anything to do with no spark oil is up to full line
We use growler to test the coil off the engine. To make sure that other components are not the problem, remove any other wires connected to the coil. Always use a new spark plug for testing. Once you have solved the problem, remove the new plug and put it away for spare. If spark with other wires removed suspect faulty oil sending unit or short in wiring or faulty kill switch (test old coil also). Do not replace sending unit however, just check oil before every use. Good luck
Sep 17, 2011 | Coleman Powermate Powermate 5000W...
Haven't started it since 6/13/08. Tried for IRENE,went through step by step but pull after pull and no start. In 08 added stabilizer ,but now fuel smells bad. Book says clean carburetor;see engine...
Robin/Subaru post all their engine stuff on their website. If you poke around you should find a PDF owners manual, parts manual, and the service manual. Service manual should have what you need. Definitely drain all the gas, clean spark plug, and change oil as well.
http://robinamerica.com/industrial.aspx
Sep 05, 2011 | Coleman Powermate Subaru 5000W Portable...
My neighbor put too much oil in his coleman 10HP brigs. engine. It ran for several minutes and locked up and spit oil out the exhaust. Now it cranks very hard. I am trying to help him fix it if possible....
If it is gas motor it may have collected dirt (burnt oil) in spark plug(s).
 When the oil level is OK, take the spark plug(s) out and with open hole try to turn the motor 10 - 50 turns to clean the combustion chamber(s) from any oil residues.
Than replace the spark plug and try to crank it again.
Jun 29, 2010 | Coleman Electrical Supplies
I have a Coleman Powermate PM0435001 5000W with a Subaru EX30D 10HP OHV/OHC gasoline engine. I want to change the oil and cant find a drain plug. Did I overlook it or does it not have a drain plug? If not...
You probably overlooked the drain plug, it is usually located on the mounting base of the engine. BUT, there have been some engines (old cheap ones) that the oil was drained by tipping the engine and draining out the oil fill. I am almost positive yours is not one of these.
Your manual is here, but that is only an "insert". It does look like the drain plug is located on the base of the engine. Find the spark plug, and the drain plug is almost directly underneath it at the very bottom of the engine.
More information is available from Subaru's website, including owners manual and especially a service and parts manuals. Your drain plug is item #13 on page 2 of the owners manual located here:
http://www.robinamerica.com/pmanuals.aspx?pid=80
Jun 06, 2010 | Coleman Powermate Powermate 5000W...
The cloeman 1850 portable powermate generator
Check spark, is plug wet? use sae 30 oil for summer use
Apr 11, 2010 | Coleman Powermate Premium Plus 6250W...
Looking for owners manual for coleman powermate 4000
Hi
First you need to change the plug with a new one with the same heat range(too long time).Priming the engine few times(put some gas in the cilinder through the plug hole)and start the engine until it runs constantly.
bestregards savumihai71
Feb 06, 2009 | Coleman Powermate Premium Plus 6250W...
Wont start
Hi
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
560 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
