Question about Samsung Televison & Video
DIGITAL receiver wont work
The electicity went off. After that the DIGITAL CABLE RECEIVER WITH BUILT-IN HARD DISK DRIVE doesn´t go on. Only two lights blink. samsung DCB-P853Z
2 Suggested Answers
SOURCE: the receiver doesn´t work. When i switch on,
Hi. Check MP40 in PIP Box.
Posted on Sep 24, 2009
My TV brings up message "No Hard Disk Found" and doesn't show pictures
sounds like the hard drive went in the Digital TV box, call your local tv cable company for a replacement.
May 08, 2015 | Audio Players & Recorders
Hard drive failure
The hard drive on our receiver's is built in to the box and can't be replaced. Since the hard drive is failing, I would recommend backing up recordings to an EHD and then having a replacement box sent out.
To use an External Hard Drive just plug it into the receiver, format it, and it will walk you through the rest. If you would like a replacement receiver, you can reach out to me at thomas.faust@dish.com and I will get you squared away!
Tommy Faust
DISH Social Media Representative
May 24, 2012 | DISH Network ViP622 DVR DTV Receiver /...
Tv (plasma) made loud pop then went black, turned off still no picture but has sound through different channels. Happened before and dish said to reset box? thanks
That's an interesting issue you posted, yfz45011959! Try unplugging the receiver's power cord from the outlet for at least ten seconds and then plugging it back in. If that doesn't fix the problem, let me know what type of receiver you have. The model can be found on the front panel in the bottom left corner.
Hope that helps!
Jul 26, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Had my My Book for more than a year. A few days ago my Mac stopped detecting it. I have since change the usb cable, tried the fire wire and it dosen't work
if there is firewire available, try that.
Open Applications
Open Utilites
Open Disk Utility
On left side - see if there is a Western Digital hard drive, there will be two icons for the drive it is there. The drive and its host. the drive may be grayed out. If so then click the mount button and you should be fine.
if the drive doesn't show up there - then try using a pc. also as weird as it may sound. try (if it lets you) flipping the ac adapter in the wall 180 degrees. may be the case if it is not the ac adapter that came with the unit
May 07, 2011 | Western Digital My Book Home Edition 500...
Tech support tells me hard drive failed. but I need valuable recordings off the drive. How do I get that?
Hello, this is Matthew Gonzales with DISH Network. If the hard drive on the receiver is faulty, there is no way we can guarantee the recordings would be able to be transferred off the receiver. However, if you wish to back up recordings in the future, you can hook up an external hard drive to the unit, it is a one time $40 fee to activate the service on the account. With an external hard drive, you can transfer your recordings from the receiver to the EHD, that way in the future if the receiver goes bad, you have the recordings on the external hard drive. Hope this helps.
Aug 14, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Want to remove wd2500 drive from HDD enclosure and
OK your hard drive is an ATA drive.
You motherboard will have two hard disk controllers, on the 1st controller the ATA cable will have two connectors - a connector will have the C drive hard disk attached to it and the jumper on the hard drive will be set as the Master drive. You may also have a CD or DVD drive connected to this cable, if so then the CD or DVD drive will be jumpered as a Slave drive.
If the second connector does not have a drive connected, then you can connect the second hard drive to this connector BUT it needs to be jumpered as a Slave drive.
You may elect to connect the second hard drive to the second IDE controller instead on the first controller. If there aren't any drives on the second ATA cable then the second hard drive can be jumpered as either a Master or Slave drive.
If there is a drive on the second ATA cable you need to determine the jumper setting of that drive and then set the jumper on the second hard drive to a different setting. BOTH drives on the same cable CANNOT have the same drive setting.
After installing the second hard drive, check the BIOS configuration of the second hard drive, if the hard drive is detected then when Windows boots up you will see the hard drive and its contents.
Dec 08, 2009 | Western Digital Caviar WD2500BB 250 GB...
The receiver doesn´t work. When i switch on,
the solution: Fount of energy broken and 50€ less in the pocket...lolo
Aug 14, 2009 | Philips E-Box FTR9965 DTV Receiver
Pvr is locked on 1 channel as if it is frozen.
hard disk is nackered - had same problem. if you take power cable out of hard disk it will work as just freeview box. tried replacing my hardrive but it does not like drive and freezes again - software problem or format?
Jan 14, 2009 | Samsung HDTV Digital Terrestrial Receiver
Disk boot failure, insert system disk and press enter
The drive should be set with jumpers or cable select to be primary master. Some pc & drive combinations don't like cable select, others insist on it. Try both, one at a time.
Jul 15, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Televison & Video Logo
120 people viewed this question
Henry  Thomas
Henry Thomas
