Question about Dell E173FPb 17" TFT LCD Monitor
Monitor trouble shooting
My monitor is displaying a box moving around the sreen which says 'self test feature check' with the colours 'red', 'green', 'blue', 'white' written underneath. This has been displayed for nearly an hour, I have turned the hard drive on as usual.
  • 1 more comment
  • OK_needhelp Jun 15, 2008
    The same problem. I was on the computer when it went black and this box came up. I have turned it off and on, unpluged the system, unpluged the monitor, called it names, gave it a shake and still only the floating box.
    Has anyone figured this out yet??
  • Anonymous Apr 06, 2009
    have a Dell 15" monitor. Has been in closet for a month, when plugged in all that shows is a window with the "self test feature check" and cannot get passed that..........can anyone help
  • Anonymous Apr 14, 2009
    i have the same problem with my dell monitor. It has been off for several months. when I powered it back up, the screen only displays a text box with the self test check feature and the names of the colors in it. What do I do to get this to go away?
Is the VGA cable attached to the monitor & the PC?
Posted on Apr 26, 2008
What would i do for my monitor that went blank
Posted on Apr 07, 2008
SOURCE:
The monitor will not show a picture the led is flashing green
* If the issue is visible in the monitor STFC (Self-Test Feature Check), the monitor is defective. * If not, the issue is with either the video card driver or the video card.
* Turn off both your PC and monitor * Disconnect the monitor from the PC (either the white DVI or the blue VGA. They should never be connected at the same time to one PC) * Turn the monitor on * The floating Dell red/green/blue/white dialog box should appear on a black background * Check for the issue
Mar 02, 2011 | Dell E173FP 17" LCD Monitor
The screen has a box that says : 1:Analog input Self Test Feature Check Red (line across) Green (line across) Blue (line across) White (line across) if you push the menu botton you get a other screen...
The issue is that the monitor in not getting the signal. This tells me that the video adapter ( or on board video) has went bad. Try another video card if all your doing is social media and surfing you can pick one up for around 20.00
Oct 27, 2017 | Dell Computers & Internet
My computer is showing a floting box which say self test feature check, wit red,green blue and white box.What do this mean
its showing u monitor self test feature screen issue either with the monitor cable or monitor or the graphic card
Nov 19, 2009 | Dell Dimension 2400 PC Desktop
Hi my monitor has bright colours on it and i cant make out what im doin its really bright and hurts my eyes
Turn off the pc but leave the monitor on. unhook the monitor from the pc. the screen SHOULD run a "self test" with a moving white green red blue box. if that box is on a bare black screen and there are no bright spots or cracks or anything weird looking, then the screen itself is ok. If however, you see odd shades of blue and pink and it looks cracked or scratched or has lines in it, then it is time to replace that screen.
Nov 10, 2009 | Dell E173FP 17" LCD Monitor
E153PFc Dell monitor: cannot change resolution
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating red/green/blue/white dialog box should appear on screen against a black background. What appears?
Jul 17, 2009 | Dell E153FPc 15" TFT LCD Flat Panel...
Computer powers up, but monitor shows a self test
Your video output is bad. Either the video card, or the onboard video built into the computer. You need to swap out the card or add a card to bypass the built in video port on your computer.
Thanks and please take a moment to rate as fixya.
Feb 11, 2009 | Gateway 550GR PC Desktop
Dell Monitor goes blank, green light still on.
Have you tried connecting that monitor to another PC. It sounds like you may have a problem with the monitor itself (component failure, heat problem, etc)
Nov 20, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Dell E173FPb 17" TFT LCD Monitor Logo
289 people viewed this question
Ekse
Clive
Clive
Alun Cox
