Question about Nextar X3-03 Car GPS Receiver
Ever thing works except the maps.
When you try to transport program buy only two of the small squars
only two of the squars light and it goes back to the start up page
  • brsha May 25, 2010
    I can not stay any longer today,will cal you later
  • 441 Answers
First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the maps can load successfully
Posted on May 25, 2010
  • 2 more comments
  • Richard T May 25, 2010
    Also make sure the Mapping Data Card is in the system.
    Note: Please take special care of the Mapping Data Card if you remove
    Photo Viewer as the navigation function will not work without it.
    I tried both the reset and checked the card
    Great, please confirm make and model: Nextar X3-03 ?
    Also go into the menu settings and check your display options.
    Make sure the Map display options are what they are supposed to be.
I need to put a scotland map on my garmin.what do I do ?
The map of Scotland comes with the "UK and Ireland", "Western Europe" or "Europe" maps so if you buy any of the three you'll have the map of Scotland. You can buy one of the maps by going to www.garmin.com and logging into myGarmin. Click on the myMaps tab at the top of the screen and then on "Purchase more maps" Follow the prompts.
Before buying the map, if you have a satnav bought in the USA you need to check if it will work in Europe. Most of the USA garmin nuvis will not work in Europe with the exception of those that come with both European and American maps.
Jun 14, 2011 | Garmin GPS
I have a glass door knob (I do not know that manufacturer for this.) I do not have the latch for it. It only came with a gray plastic piece. I purchased a schlage spring latch replacement part for this,...
I am thinking that the knobs and the lock have the same size of square metal shaft. You can try out a good hardware store for some square stock metal. This might be an easy fix. If the lock shaft size is actually smaller than the knob, you can cut some small strips of tin to shim the 4 sides of the shaft that goes into the knob.
joe
Jan 15, 2011 | Garden
Arrival won't load on halo 3!! Please Help.
if you are tight on money your best solution is trying to find like a game crazy store or buying your own cd fixer or just buy a used and referberished disk of halo 3.
Aug 01, 2009 | Microsoft Halo 3 for Xbox 360
Loss of power when driving but no service light
hi i have a renult trafic i was told to buy an egr valve , map sensor , and a glow plug relay problem was still there got **** of with it spending money, i found the problem myself were your ( EGR VALVE IS THERE IS A SMALL NIPPLE AT THE BACK OF IT THERE IS A TUBE ON IT THAT GOES TO A THING CALL A MAP SENSOR PULL THE TUBE OF THE BACK OF THE EGR VALVE AND THAT NIPPLE WILL BE BLOCKED UP, THAT WILL SORT THAT OUT FOR U.
May 02, 2009 | Renault 181 Cars & Trucks
1 iQue 3600 no Installation Disks or anything else.
You can download for free the installation disk software from www.garmin.com. You can also download a base map, but may have to buy maps from Garmin for more detailed maps/charts. You may need the serial number of the unit to unlock the maps, this is on a paper sticker under the gps antenna.
Mar 06, 2009 | Garmin iQue 3600 GPS Receiver
Loading TomTom one maps for northern France
First you need to have the relivent map on your SD card. Typicly this will be the Tomtom Map " Western Europe ". When you purchase maps from TomTom you also get an activation code and instructions telling you how to install the map onto your device and how to authorise it using the code that comes with it.
Before doing anything ... BACK-UP your existing data ( the whole SD card ) onto your computer . This will ensure that if any update is unsuccesful you can at least return things to the way they were before you tried to update.
There are several ways to obtain maps
  • buy a new TOMTOM SD card for your tomtom that containes the required maps. Make sure it comes with the authorisation card.
  • buy a CD from TomTom or a TomTom authorised dealer . This CD will contain the required map so you can download the required map to your own SD card. Make sure it comes with the authorisation code AND instructions.
  • buy the required map from TomTom online . You can download it to your PC , then copy it onto your SD card later. It will come with some instructions and authorisation code ...... You can also use "TomTom Home" software and this does most of the job of downloading maps ( that you buy from tomtom ) and puts them onto your sd card for you in a semi-automatic way . If you go down this route then its best to be sure you have the latest version of TomTom home software by going to the TomTom website first.
With ANY of the above methods------- BACK UP your existing SD card first . In fact ... make a BACK UP NOW , then if anything goes wrong at any time , you can at least revert back to your backup.
Good Luck
Jan 18, 2009 | Tomtom One Europe v2 GPS Receiver
Fine Drive 400 Software/Maps
> How do I get it to go to Louisiana?
You internal GPS antenna does not work.
Buy an external GPS antenna for FD400
on eBay $10+$10 shipping = $20
Jan 19, 2008 | GPS
Garmin Streetpilot 2620 Goes not go to maps
I would like to know the same thing! My father has the same unit and he updated his with version 4.80 & web updater (both free) on garmin and it solved his problem. I believe my problem is that my North America v8 did not install properly. ????? well see
Aug 25, 2007 | Garmin StreetPilot 2620 GPS Receiver
Nextar X3-03 Car GPS Receiver Logo
101 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
