Question about Compaq Evo N610C Notebook
Alps pointing device software
Hi i own a A933TU COMPAQ LAPTOP WITH WINDOWS VISTA BASIC I AM HAVING PROBLEMS with this touchpad software as it says on the screen time and again that this program is not responding so close the program and the moment i close it i cant fully use the touch pad as i cant click but only move the pointer i have re installed again and again from back up but the problem still persists please help
  • 520 Answers
Down load synaptics touchpad driver first.
once downloaded open the file to install.
before u install go into device manager..check mice and pointing devices and look for ps/2 compatable mouse....delete it and restart pc on restart it will find and reinstall ps/2 mouse.
if everything works,sorted ,if not install touchpad driver downloaded earlier.
you can find this driver on hp site.this driver works on all hp laptops.
Posted on Apr 07, 2008
I am using Compaq CQ40-108TU model, I have changed the OS to Windows 7 (32bit) after that the Imaging device is not appearing in the device mgr.. due to this my notebook webcam is not working. any help? ...
Hi, welcome to FixYa!
You can try installing the driver for the webcam. Try to download and install the driver from this:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3791887&
Choose Windows 7 (32-bit) as your operating system.
If Windows 7 is still not recognized the webcam, you can try download and install webcam software such as Cyberlink YouCam.
Thanks for using FixYa.
Jul 06, 2011 | HEWLETT-PACKARD Presario Cq40...
Good mornning , i have dell d620 laptop (latitude) and i removed the original vista windows were on it when i bough it and installed windows 7 , i need to know is my laptop model match with window 7 or no...
All the vista drivers can be used for 7. By default, windows 7 installs all drivers except for touchpad.
You can find 32 bit version for it here
The 64 bit of Windows 7 64-bit ALPS touchpad driver from the Dell support site for a Latitude E6410 is reported to also work for D620. Give it a try.
May 11, 2011 | Dell Latitude D620 Laptop (Latitude-C620)...
When typing, my cursor will randomly jump to some other part of page thus screwing up what I have already typed. I am not accidently hitting touch pad. Lenovo G550 thinkbook Windows 7 proffesional...
Hi rbdav1,
Based on your situation. I suggest trying the following steps:
1. Download touchpad driver from here:
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_list.aspx?CategoryID=600154
2. go to Touchpad section and make sure you select the Windows XP, Vista or Windows 7 version of the drivers that matches your Windows operating system.
3. After downloading the touchpad driver driver install it and then restart your computer.
4. Log back in to your computer then go to control panel --> open mouse properties then look for Alps pointing device tab.
5. Under Alps tab uncheck tap off when typing.
Hope it helps.
Best regards,
Reyjoshua07
Dec 13, 2010 | Lenovo G550-29583AU Notebook
Mousepad not working
Each Touchbad should have basic functionality by default in every Operating system, letting it be used even when no driver is installed. However, try pressing FN and F7 together and see if the touchpad works again. Some people accidently press this FN + F7 key when they mute the sound with the FN + F8 key.
The FN + F7 is there to disable/enable the touchpad as some people use a USB mouse instead of the touchpad.
If you still need the drivers, here are the download links. Please choose desired driver by Operating system and Touchpad brand...
Acer Windows XP TP Drivers Synaptics
Acer Windows XP TP Drivers ALPS
Acer Windows 7 TP Drivers Synaptics
Acer Windows 7 TP Drivers ALPS
Acer Windows Vista TP Drivers Synaptics
May 18, 2010 | Acer Aspire One PC Notebook
How do you adjust the sensitivity of an ALPS pointing device touch pad with VISTA.
You may very well find you ALPS driver installed on the laptop in question doesn't have a sensitivity setting.
In that case you can try locating this driver:
ALPS Touchpad Driver 7.2.302.105
I know it can be found on "www.softpedia.com".
Installing it may resolve your problem as it updates the lack of sensitivity settings in older ALPS drivers for touchpads that have the capability to discern the level of pressure being applied to them.
Feb 04, 2010 | HP Compaq Presario C770US Laptop
Inspiron Keyboard Jumps Around
Install the latest touchpad driver from support.dell.com
There is a setting in the touchpad tab of the mouse driver. Either Enable PalmCheck or Disable touchpad when typing (Depends on Synaptics or Alps drive I believe)
With palmcheck enabled, the touchpad is disabled when typing
Jan 24, 2010 | Dell Inspiron 1420 Notebook
Touchpad of VGN-NR110E
1. Please click "Run", type "devmgmt.msc" and press the Enter Key.
2. In the Device Manager window, please click the "Mice and the other Pointing Devices".
3. Right click the "Alps Pointing Device" and select the option "Disable".
This should disable it.
You can also disable the Touchpad using "VAIO Control Center" Software. If the VAIO Control Center is not installed in the Computer, please download and install it from this link.
Dec 16, 2009 | Sony Vaio VGN-NR110E/S Notebook
The scrollbar on touchpad in my Compaq C-772TU laptop[windows XP] is not working.Pls help.
You will need to install the touchpad software (ALPSTouchpad Pointing Device Driver) for the Compaq Presario C772TU Notebook PC.Below are the download links
Microsoft Windows Vista
File name: sp38629.exe,(8.02M)
ftp://ftp.hp.com/pub/softpaq/sp38501-39000/sp38629.exe
Hope this helps. Please rateyour feedback!
Thanks,
VJ
Mar 03, 2009 | Compaq (153515-001) Touch Pad
WINDOW FREEZES WHEN OPENED MESSAGE SAYS ALPS POINTER PROBLEM
my compaq laptop freezes up when not used for a few minutes and then data is lost and I have to reboot it!
Jan 04, 2009 | HP Pavilion dv5170us Notebook
Alps pointer device driver
Dont give much pressure or harder press over the area and on the keyboard on your laptop. If any pressure on top area will makes your touch pad to start working all laptop has it option to off it . Also make your mouse sensitivity very low - if you set it in high a small movement or any kind or pressure over that can make it on.
May 18, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Evo N610C Notebook Logo
433 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
