Question about Polaroid i737 Digital Camera
It wont turn off or on and the lens wont close
Hi my name is Ed. I have a polaroid i737 digital camera. The problem is the lens wont close when I try to shut the camera off. A green light flashes in the back of camera. It wont turn on or off i checked the batteries. thank you
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 25, 2010
Where is service center for polaroid i737 digital camera in India
Have you tried calling this number +(91)-(40)-66048356 -- the service center number for polaroid digital camera located in Secunderabad, Hyderabad-500003
Feb 26, 2011 | Polaroid i737 Digital Camera
When I push the on button the lens comes out but the screen is black
In most cases, the camera is beyond economic repair. If the camera is a few years old, buying a newer one is a better option. I'm seeing brand name 10 MP models NEW for $60. you might check online auction sites for used ones. I've picked up 5 MP ones for $5.
Jul 02, 2010 | Polaroid i737 Digital Camera
Lens won't close
Please charged your battery fully & then try. If same thing going on then i say ,Yes its a problem of internal zooming function. Some slot is damaged or dislocate & your camera motor make noise. Its need service & after that it will work.
Look at this picture, you will see then what place is damaged.
Feb 06, 2010 | Polaroid i737 Digital Camera
I have a polaroid i737 and the lens is stuck out and it wont turn on, any ideas how to fix this?
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 20, 2010 | Polaroid i737 Digital Camera
Screen cracked
Yes and it will be expensive.
Nov 20, 2009 | Polaroid i737 Digital Camera
My camera will not turn on. The lens is extended and will not close. How do I fix this?
Try lithium ion or quality rechargable batteries if you have not already. Regular alkalines will not cut it, even if they are new sometimes. The battery type really can make a difference with digital cameras.
If it sounds like the lens is jammed or you try those batteries and it still won't move, then you've got a bigger problem. If you bought it less than a year ago and have your receipt (this is important), call Polaroid and they may replace it (assuming it's not too beat up looking or damaged). Be prepared to wait a few weeks for the replacement.
Aug 19, 2009 | Polaroid i737 Digital Camera
Lens will not open to take a picture
The first thing to try is new lithium ion batteries (Energizer Advanced or Duracell PowerPix) or quality rechargables. Battery type makes a difference with these cameras and regular alkalines (even new ones) often just don't cut it.
If it still doesn't turn on, or open up, press and hold the playback button [>] to start up the camera in Playback Mode (resets the lens).
If all else fails, the lens is probably jammed. If you bought it less than a year ago and saved the receipt, call Polaroid tech support and they may replace it. Be prepared to be without a camera for a few weeks.
Jul 29, 2009 | Polaroid i737 Digital Camera
Polaroid i737 usb cord
I was in need of a new USB cord for my Polaroid i737 as well. This was a problem for me because thee SD card I use with my i737 is a HC card and can only be read by/through my camera. Thankfully, I managed to find one on E-bay and purchased it.
However, if you are using a non-HC SD card for your camera, I would suggest just using an SD card reader to transfer your photos from your card to your computer.
Jun 23, 2009 | Polaroid i737 Digital Camera
Icant download pictures from my polaroid i737 camera to vista
go to the file on your camera where you know the pictures are and drag and drop or copy and paste all the pictures into a folder you put on your desktop or where ever you want it.
Feb 23, 2009 | Polaroid i737 Digital Camera
Polaroid i737 Digital Camera Logo
116 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
