Question about Pitco Frialator SG14 Deep Fryer
Small problem, how do you turn the timer beeper off (sound) when done with a batch? Hold timer key down?
I have a whirlpool oven which I bought from Ikea a few years ago but at the end of a timed programme the beeper is not going off can you tell me the answer please.
Timer
To Turn Tones Off/On: Press and hold TIMER SET until a tone
sounds. The display will show "TIMER" and "NA9 On" or
"TIMER" and "NA9 OFF." To remove from the display, press
UPPER OFF, LOWER OFF or OFF/CANCEL. Repeat to turn
back on.
Feb 26, 2015 | Whirlpool RBS305PDS Electric Single Oven
Microwave timer makes no sound
I would need a full model number and more detail to help you on this.
I'm wondering if you mean that the keypad is not responding to input, or the beeper is not working when you press a key or when it's done cooking.
If the former, then you have a failed membrane keypad. We can help you with more information with the full model number and detailed symptoms.
If the latter, the beeper may be turned off via the control panel. You'd have to consult your owner's manual for information on whether it ahs that feature, and how to activate and deactivate it.
Feel free to contact me for a free estimate or DIY info, including part help.
Oct 02, 2011 | Amana MVH230 Microwave Oven
When I turn the dryer on and dial in the proper settings - the sound is gone. I also don't have any sound (music) when the dryer is finished.
There is a button on the far middle right on the front of the unit that needs to held down for about 5 seconds.
That button will read:
"DAMP DRY BEEP"
*BEEPER ON/OFF.
Hold that button till you hear the unit respond. Now you should hear the sounds. If no sounds, you may have to reset the computer and will need to unplug the unit for 5 min and then plug it back in. You may have to hold the beeper button down to turn on the sound.
If that does not work then you will need a new display board that is right behind the front panel of the unit.
Good luck and I hope that I have helped you.
Jul 16, 2010 | LG DLE2301 Electric Dryer
Need instructions on how to program a RCA model RCR 3273N universal remote
Hi! There are two ways on how to program your RCA Universal Remote Control. First is the direct code entry. In following these steps you need to provide me the type and brand of the device you want to be programmed to your remote control so I can give you the code for that certain device. Since you did not indicate the information I need for the code I will advise you to do the second way which is the Auto Code Search. Here are the steps for you to be able to program your Universal Remote without the code list.
1. Manually turn on the device you want to control.
2. Press and hold the device key you want to program. While you’re holding down the device key, use your other hand to press and hold the remote’s POWER key at the same time.
3. Wait until the remote’s indicator comes on and stays on. Then release both keys.
4. Point the remote directly at the front panel of the device you want to control. Press PLAY on the remote and wait 5 seconds. The remote is testing a batch of 10 codes on your device.
Did your device turn off?
YES: Go to step 5.
NO: Press PLAY again. The remote tests the next batch of 10 codes.
Keep pressing PLAY every 5 seconds until your device turns off.
5. When your device turns off, press the REVERSE key on the remote
and wait at least 2 seconds. The remote tries the last of the previous ten codes.
Did your device turn on?
YES: Press the STOP key. You’re done! You’ve programmed this device key.
NO: Press REVERSE again. The remote tests the next code in the batch. Keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
Note: If you accidentally press the REVERSE key after your device turns on, press the FORWARD key. Then, wait two seconds to see if your device turns off again.
Jun 14, 2010 | RCA Universal Remote Control
I have an RCA rcr3273n and it does not have the code search button, what button do I use to sync it with my TV?
These are the steps for the auto code search function for your remote.
  • Manually turn on the device you want to control.
  • Press and hold the device key you want to program. While you’re holding down the device key, use your other hand to press and hold the remote’s POWER key at the same time.
  • Wait until the remote’s indicator comes on and stays on. Then release both keys.
  • Point the remote directly at the front panel of the device you want to control. Press PLAY on the remote and wait 5 seconds. The remote is testing a batch of 10 codes on your device.
  • Did your device turn off?
  • YES: Go to step 5.
  • NO: Press PLAY again. The remote tests the next batch of 10 codes. Keep pressing PLAY every 5 seconds until your device turns off.
  • When your device turns off, press the REVERSE key on the remote and wait at least 2 seconds. The remote tries the last of the previous ten codes.
  • Did your device turn on?
  • YES: Press the STOP key. You’re done!
  • NO: Press REVERSE again. The remote tests the next code in the batch.
  • Keep pressing REVERSE every 2 seconds until your device turns back on. When it does, press STOP.
Because there are a couple other methods you can use to search for codes I included a link to the manual for your remote.
Hope this helps.
http://audiovox2.info/docs/rca_acc/man/RCR3273N_DOC_OM.PDF
Oct 17, 2009 | Televison & Video
Clock timer volume too low
The beeper sound level can be adjusted.
Press the "BEEPER VOLUME" pad on the keypad, then select 0–3 for mute to loud.
Your owner's manual is here.
Jan 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Timer instructions for a Rangemaster Toledo dual fuel 90 required
OK, here we go, this is actually a fairly lengthy explanation, but I will do what I can to explain.
The timer can be used to turn just one, or both ovens on and off automatically, however the start and stop time must be the same for both ovens, though different cooking temperatures can of course be set, so if you play around with temperatures to extend the cooking time of an item in one oven, you can often cook items needing very different settings for the fixed time you set in both ovens. Note that when the timer is on and the AUTO message is on the display, the ovens are disabled and will ONLY work during the timed period unless the timer is disabled again. (This is a common problem when you first power up, because the AUTO setting is automatically engaged on installation or power up after a power cut, disabling the ovens until you figure this out!). So, with all that garbage out of the way, how to use the timer settings:
For ease of understanding, I will refer to the buttons on the control pannel (Running from Left to Right as: BELL, HOT DISH, COLD DISH, HAND, + and -)
TO TIME SOMETHING THAT'S ALREADY COOKING (Minute Minder). Press and hold down the BELL symbol (Far left), use the + or - to adjust the amount of time you want to cook for (You can check time remaining at any point, or cancel the beeper when the time is up, by pressing the bell button.
TO STOP AUTOMATICALLY AFTER YOU HAVE MANUALLY STARTED COOKING. Press and hold the COLD DISH button at the same time use + and - to adjust your required stop time. AUTO will show on the display. When cooking is finished, the beeper sounds. TURN THE OVEN TEMPERATURE KNOB TO "0" FIRST, then press the HAND button, once to stop the beeper, and again to cancel auto and return to manual mode.
TO START AND STOP THE OVEN MANUALLY: Before you start, decide when you want the cooking to stop and how long you want the food to cook for (The cooker will work back from your stop time and figure out the START time for its self.). Press and hold down the HOT DISH button and at the same time set the minutes and hours you want the oven to cook for with the + and - buttons (You are NOT SETTING THE TIME HERE, you are setting how many minutes and hours to cook. Next, press and hold the COLD DISH button and use the + and - to set the stop time (YOU ARE SETTING A TIME IN THIS OPERATION). AUTO will show on the display. Set the temperature for the oven (or both ovens) that you want to auto cook with. When cooking stops the beeper sounds. Press the HAND button to cancel the beeper and press the HAND again to cancel AUTO and return to manual mode. (Note that the beeper stops after a while if you leave the oven attended, but the manual states you still have to press the HAND button twice to return to manual, I have not personally tested this).
GETTING BACK TO MANUAL MODE. If AUTO is showing on the display, because you have set automatic and no do not need it, or you have just powered the cooker up, any cooking time already set must be returned to 0:00 before you can return to manual, so hold down the HOT DISH button and ensure the display is set to 0:00, once you gave done this you can press the HAND button to return to manual mode
Dec 22, 2008 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Disabling the beep on a Kenmore microwave
I have Kenmore microwave model 721.61820100.
It has an "Option" button. Press it. The display say "NUMBER"
Then press "1". The display should say "SOUND" and then "OFF".
Press "Start" and that beast turns silent, well not really, but the beeps are goooone.
If for some reason you don't like it this way repeat the sequence and the sound this time will turn "ON".
Jun 05, 2008 | Kenmore 80809 Microwave Oven
Pitco Frialator SG14 Deep Fryer Logo
66 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paulcarew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
