Question about Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher
How to fix leaking heating element? Water appears to be dripping from where one end of the element passes through the tub. Is there a gasket that needs replaced? Thank you D. Brush
  • 901 Answers
Switch off the m/c. Remove the heater and clean the gasket seating area. Replace the gasket. If new gasket not available, clean the old gasket free from oil.
Apply rubber solution on both the ends metal parts. Allow it to dry. Now attach the heater along with gasket. Use after few hours.
Posted on May 26, 2010
Where is the water coming from that is leaking from the base of the unit? It is not coming from the drip tray, and we replaced the water tank. The water pools on the right, underneath the water tank t
Does it only leak when making coffee? There are 2 hoses, one that supplies cool water to heating element in base the other one that supplies the heated water from heating element to top of coffee grounds. Typically over time this 2nd hose degrades at heating element connection and begins to leak
Oct 13, 2014 | DeLonghi Perfecta ESAM5400 Black Espresso...
During the defrost cycle our refrigerator leaks water from the freezer side out the front into the floor of the kitchen. Where could it be coming out and what will fix it?
The water from the melting ice during defrost should be guthered from the drip drain pan which is under the evaporator pipe coil and is passing though the drain tube which is conected to the dip pan and should end out on the back of the fridge to the compressor to evaporate. The problem posibly is that the drain tube is goggle either from ice or from dirt or both and the water since it can not end to compressor it overfrow from drip pan inside the freezer. So you can clean the drip pan and drain tube using a wire rod and problem will be solved.
Sep 13, 2011 | Refrigerators
Inside of freezer on the bottom on the back lit up red as though on fire, heard a hissing sound as though water was leaking on hot surface. whats happing?
It's defrosting. Depending on your make and model, it'll do that a couple of times a day. There is a heating element behind that panel that's on a timer. The element looks like a bake element in an electric range, sort of. It's doing what it should be doing. The hissing is the frost/ice being melted off of the evaporator and dripping onto the element. All normal.
The end.
fil
Mar 01, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
I have a Zanussi W/M ZWF1640 showing E34 fault codes in diagnostics mone. any clues?
Three things i would suggest on the zannuzi. Does water come into the drum at the beginning of the wash? Does the drum turn if asked to wash or spin? Does the drain motor disperse the water in the drum when supposed to. If motor does not turn, check the brushes. Sorry for being so vague, Zannuzi not common in S.Africa, but those are the common problems i have found while repairing the odd one.
Aug 03, 2010 | Washing Machines
My Kenmore refrigerator is making dripping sound
Mine does same, there is no water on floor or around base of machine in back or sides. Most modern refrigerators have a cycle which uses a heating element to thaw out the coils and the water drips into a pan and naturally evaporates with or without a fan. That is how a defrostless refrigerator works. If the sound is continuous I suspect that there might be an "ice dam" buildup which could be approached by unplugging the machine long enough to allow it to melt or perhaps the heat element might be inadequate.
May 05, 2010 | Kenmore Refrigerators
Frs28zrg leaking. frozen water in bottom of freezer. drips on inside of fridge/freezer. water/ice not working....should I attempt to fix this or pay $100 for my home warranty repair...
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model clean drains
Aug 15, 2009 | Frigidaire FRS3R5EMB Side by Side...
LG Bottom Freezer Frost Issue
It sounds like your defrost controller has gone bad. I have an LFC25760 and had ice build up in the bottom of the freezer such that water would start leaking onto the floor. The ice build up in the bottom of the freezer was due to a failing/bad defrost controller. Behind the back white wall in the freezer compartment exists the cooling fins along with a heating element underneath. Due to moisture that comes into the freezer from opening it, frost/ice builds up on the cooling fins. Thus the defrost controller turns on the heating element to melt the ice/frost off of the fins which then drips into a metal pan which channels the water to a drain hole which drops into the drip pan underneath the fridge next to the fan. The problem is that the defrost controller doesn't keep the heating element on long enough or the cooling cycle comes on too soon thereby freezing the water and plugging up the drain. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
Jun 22, 2009 | LG LRFD25850 French Door Refrigerator
I have LG French Door Refrigerator Model LFC25760SB. I have the ice build up problem on the floor of the freezer. Is there a way I can only turn off the Freezer so that it can thaw to resolve the problem?...
George,
The short answer to your question is no. It sounds like you are having the same problem I had almost 1 year ago. The defrost controller in your fridge has gone bad. I have an LFC25760 and had ice buildup in the bottom of the freezer such that water would start leaking onto the floor. The ice buildup in the bottom of the freezer was due to a failing/bad defrost controller. Behind the back white wall in the freezer compartment exists the cooling fins along with a heating element underneath. Due to moisture that comes into the freezer from opening it, frost/ice builds up on the cooling fins. Thus the defrost controller turns on the heating element to melt the ice/frost off of the fins which then drips into a metal pan which channels the water to a drain hole which drops into the drip pan underneath the fridge next to the fan. The problem is that the defrost controller doesn't keep the heating element on long enough or the cooling cycle comes on too soon thereby freezing the water and plugging up the drain, which then causes the melted ice on subsequent defrost cycles to overflow the drip pan and flow into the bottom of the freezer and then eventually onto the floor when the bottom is full of ice. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
When I had the problem and started diagnosing it I opened up the freezer, pulled out the racks, draws, and eventually the door. Then I removed the ice maker and then a few screws and carefully removed the back white wall panel disconnecting the fan and any other electrical connections. Behind the panel you will see the cooling coil/fins, the heating element, the drip pan, and drain hole. Most likely you will see a sheet of ice everywhere. The best way to remove the ice is to boil a bunch of water in a tea kettle and slowly pour it on the ice to get it to melt so that you can start breaking out the pieces. Have a sponge and bucket ready to remove the water as the ice starts to melt. Eventually you should get all of the ice removed and get the drain hole unplugged. After all the ice is removed, you still need to fix the real problem by replacing the defrost controller, using the paper clip trick, or both.
Good-luck.
Jun 19, 2009 | LG LRFD25850 French Door Refrigerator
Water level below heating element and element does not appear to heat
Make sure the drain hose high loop is installed properly, normally you have this in the sink cabinet high up. Otherwise the water inside the machine may drain "by itself", leaking through the inactive drain pump during the wash cycle and cause this and other troubles.
May 24, 2009 | Kenmore Dishwashers
Water leak at heater element connection seal, rusted connection
Mlecha, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Mlecha), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool DU1055XTSQ Built-in Dishwasher
Frigidaire 24 in. FDB750RCC Stainless Steel Built-in Dishwasher Logo
80 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
