Question about Ryobi Garden
Sirs; I have a 16" RYOBI 31cc gas trimmer (Model # 775R"EZ", S/N 802183858) that does not have a spark. A local repair store told me that it needs a new coil at a cost of at least $90.00. I am a shade tree mechanic and can fix many items if I have the repair manuals for them. The engine has good compression and the trimmer has not been used very much so I want to repair it. Can you give suggestions as to where I can get the manual? Thank you!
4 Suggested Answers
  • 512 Answers
SOURCE: Ryobi 775r gas trimmer stalling when tilted
You have a air leak between to tank and motor. Could be carb gasket. When using in tilted position you dont have gravity feeded carb anymore, causing air to be sucked into carb. Take off carb and spray with crb cleaner, then blow out with air gun. Replace gasket, make sure all new lines and bulb connections are connected securely.
Posted on Jul 17, 2009
  • 130 Answers
SOURCE: MY RYOBI 31CC 775R WEEDEATER WON'T START I
spary a little startingfluid in carb to see if it start if it start rebuild carb.to change fuel line
only if there dryrotted if it go thourght the gastank in little hold cut new line on a angle and thread through hold.hope helps you.let me know ok
Posted on Jul 25, 2009
rycgl
  • 1545 Answers
SOURCE: i need the fuel/oil mixture
The fuel/oil mixture is 40:1. That is 3.2 oz. oil/US gallon. Now for the fuel lines:
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Posted on Jan 11, 2011
Where can I get a parts breakdown ( exploded view ) for a Ryobi 775R 16" string trimmer.
here's the link. http://www.partstree.com/parts/?lc=mtd&mn=775r+41AD775A034
Mar 17, 2013 | Garden
Ryobi 31cc 18'' 790r ez has no power
You have done just about all you can do with this machine give up and buy a new one
Jul 08, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Need a diagram that will show the tubing feeds on ryobi weed trim
If you need a fuel line diagram for ryobi 775r let me have your email address.
tony
Oct 13, 2009 | Garden
MY RYOBI 31CC 775R WEEDEATER WON'T START I REPLACED THE SPARK PLUG AND STILL NOTHING I DON'T THINK ITS GETTING GAS HOW DO I FIX OR REPLACE GAS LINES.
Jul 24, 2009 | Garden
Jul 17, 2009 | Garden
Ryobi 775r won't start. I replaced the spark plug but still no go. I have never replaced the fuel line didn't know that was necessary
make sure you have fresh gas miture first, then put spark plug on housing as you pull it over (with the switch on) watch for spark if its there then its a gas problem. old stinky gas is usually what happens when it sits for months. carb may need to be rebuilt if it still won't start. also check exhaust screen to make sure its not plugged.
Jul 16, 2009 | Ryobi Garden
How do I connect the fuel lines on the Ryobi 31cc petrol edge trimmer.
I have a Ryobi 31cc 17inch cut with gas line problems and this answered my questions. Thank You
R Green
Oct 18, 2008 | Garden
Ryobi 725r 31cc
Ryobi is Japanese for "Piece of ****" My suggestion is to throw it out!
My 767r has had fuel line and carb trouble from day one. I'll never buy another Ryobi or Craftsman tool again.
Jun 13, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
256 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
