Question about Whirlpool Duet GHW9150P Front Load Washer
Unable to unlock the door of washer
Tried unplug the power, hold manual unloc for 3 sec, or hold diable signal for 3 sec. the machine will not run and showed problem code is F12
  • 15,935 Answers
F12 isnt an easy code to diagnose. It means the mcu isnt communicating with the ccu.
The problem could be the door lock or either board. I would recommend calling a tech out.
It is similar to the F11 error - see the following.....
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 29, 2010
Maytag 5000 series washer control locked light is on and washer wont turn on
1. try unplugging or flipping circuit breaker, wait 10 secs, hold in power/on button for 5 secs, plug back in and see if it resets.
or
2. try tapping on door lock position on front of unit and see if it unlocks unit(lock stuck). hit it hard with palm, but not enough to dent or damage
good luck
Sep 24, 2016 | Maytag Washing Machines
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
HOW DO I GET THE CONTROL LOCKED UNLOCKED
unplug an replug it in. then try
or us the .. hold the signal button for 10 secs .
or open top or bottom of unit an reach down behind the door lock there is a ring to pull it down to unlock it.
Jul 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Control locked, how do I unlock it. I can't start the washing cycle.
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
OR press options and select for 10 secs till LOC is no longer displayed
Apr 03, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
I cannot open the door on my Miele top load washer. I have an older model, without a digital screen. I tried to open it when the machine is on, after running a cycle and when it's off. And apparently, the...
Ok. Push and hold start stop button til you hear click or get a sore finger release and listen for click. In plug replug repeat cancel request. If none of these work turn the cycle dial backward one click then forward 3 clicks inside of a 5 sec window. That sequence is washing machinespeak for let go of the lid
Feb 09, 2018 | Miele W149 Top Load Washer
HELP! I have a whirlpool HE3 frontload washer and it is stuck on "Control Locked". I did try holding "end of cycle" button for 3-5 sec. and I also unplugged washer for at least 30 min. as suggested with no...
you can manually open the door by first unplugging unit from power,then remove lower toe kick panel under door,reach up to find the door latch assembly and feel for a small tear-shaped plastic tab located on bottom of door latch and pull downwards 1/4" till you hear a click and door should open manually
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Asko WCAM1812 Front Load All-in-One Washer / Dryer It does not start the lights are blinking on spin. the door remains unlocked
hold down the "cycle signal" button for 3-5 sec. unplug and plug back in. should clear and reset computer
Aug 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Whirlpool Duet makes spinning sound but drum is not spinning.
What is the model number? To get your clothes out and the door open on that model, try unplugging it for awhile and open the door (you probably have tried that already. Some models you can take off the bottom panel and reach up and there is a little ring you can pull to open the door. (most likely) you might be hearing the pump running since it always run when spinning. If you give me the model number I can let you have the test code. You could try Pressing any key (not power or stop) hold it in for 3 seconds let go 3 seconds, press 3 sec, let go 3 sec, hold 3 sec let go. It should come up all lights on. Don't worry you can't damage anything in the test mode. Watch what it says. then press that same key about every 30 seconds to advance it. It's kind of hard to explain but I'm trying my best. It should at least unlock it in the process. Good luck
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
LOC for oven door is unable to unloc
Put the oven in Self Clean mode for 3 minutes and then cancel.. if if that will release the relay that controls the lock. If that doesn't work, Unplug the oven for 10 mintues, then plug it back in holding the CLEAR button down. If neither of those work you will need to contact a service repair man.
Jul 19, 2008 | Ovens
Whirlpool Duet GHW9150P Front Load Washer Logo
419 people viewed this question
Dan Webster
Dan Webster
Sal De
