Question about LG DLG2532 Gas Dryer
Dryer is not heating up - LG DLG2532 Gas Dryer
LG DRYER NOT HEATING ????? ****PLEASE READ THIS LG DRYER UPDATE!!!!! ****
I READ AND FOLLOWED THE SUGGESTIONS ABOVE AND IT WORKED!!!!! AND I SAVED HUNDREDS! LET ME WALK YOU THRU.
(UNPLUG THE ELECTRICAL CORD BEFORE FOLLOWING THESE STEPS)
1.ON TOP OF DRYER THERE ARE SCREWS ON BACK, UNSCREWING THESE WILL ALLOW YOU TO PULL TOP OFF (IT SLIDES AWAY FROM DRYER)
2. NOW THAT TOP IS OFF, UNSCREW SCREWS OFF OF TOP FRONT PANEL (SCREWS ARE ON BACK OF FRONT PANEL BUT CAN ONLY BE SCREWED OFF IF TOP IS OFF)
3. NOW OPEN DRYER FRONT DOOR AND UNSCREW 2 SCREWS UNDER LINT CATCHER AREA, SCREWS FACE THE FRONT - NOW THE WHOLE BOTTOM FRONT PANEL WITH DOOR WILL CAN COME OFF TO ACCESS THE BOTTOM OF DRYER
4. ON LOWER RIGHT HAND CORNER OF DRYER THERE'S AN AREA WITH WIRES AND PARTS - LOOK TOWARDS BACK ALONG RIGHT SIDE OF BOTTOM OF DRYER (ABOUT 6 - 7 INCHES TOWARDS BACK)
(FLASHLIGHT MAKES EASY TO SEE)
5.LOCATE THE FLAME TUBE WHICH LOOKS LIKE AN OPEN CYLINDER (THIS IS A FEW INCHES FROM RIGHT SIDE TOWARDS CENTER OF DRYER) - ON THE LEFT BOTTOM SIDE OF THIS FLAME TUBE THERE ARE 2 SETS OF WIRES (1 IN THE INSIDE OF THIS FLAME TUBE AND 1 ON THE OUTSIDE OF THE FLAME TUBE) THE 1 SET OF TWO WIRES THATS INSIDE OF FLAME TUBE IS WHERE YOU WILL BE LOCATING A "BUTTON OR PIN SWITCH" - THIS WILL BE RIGHT BETWEEN BOTH WIRES (MINE WAS BLACK COLOR BUTTON ON A METAL PIN).
"PUSH / CLICK" THIS BUTTON BUT MAKE SURE THERE IS NO NOISE AROUND YOU BECAUSE YOU NEED TO HEAR TO MAKE SURE YOU HEAR A "CLICK" SOUND - I MISSED IT BUT ONCE CLICKED IT WONT CLICK AGAIN BUT ITS OK CUZ IT WILL WORK).
6. BEFORE PUTTING EVERTHING BACK TOGETHER I HIGHLY SUGGEST YOU VACUUM OUT ALL LINT/ DUST BUNNIES FROM THE INSIDE OF THE AREA YOU WERE JUST IN (AROUND THE FLAME TUBE). i EVEN UNSCREWED THE OUTSIDE OF LINT CATCHER TOOK IT OFF (EASY) AND CLEANED IT. I ALSO VACUUMED THE BACK OF DRYER WHERE EXHAUST COMES OUT AND VACUUMED THE VENT THAT GOES TO WALL AND THE VENT GOING UP TO MY ATTIC AND MADE SURE THE AIR FLOW WAS GOOD THROUGHT THAT WHOLE AREA (SHOP VAC WORKED GOOD CUZ YOU CAN USE IT TO VACUUM BOTH BY SUCKING AND BLOWING AIR INTO THE AREAS WHERE VENTING / EXHAUST OCCUR).
7. PUT ALL PARTS AND SCREWS BACK, PLUG IN AND TURN DRYER ON WITH WET CLOTHES IN IT ...
Posted on Sep 11, 2010
  • snjfaidiga Aug 26, 2011
    Thank you so much. This is the third time this has happened since we bought this expensive set of LG's. Why won't they just put the reset behind a removable door on front or side of machine and lable it "reset button"??? You saved me well over $150.
    Judi
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
DRYER WON'T HEAT
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
www.partselect.com/Repair/Dryer/Not-Enough-Heat/
When your gas or electric dryer is not producing any heat or not enough heat to ... If the sensor is defective, either the igniter won't glow or the gas valve won't ...‎How to test a dryer's heating ... - ‎How to open your dryer's cabinet
How To Troubleshoot A Dryer That Won't Heat ' PartSelect ...
? 4:23
www.youtube.com/watch?v=ahb5pt52drE
Oct 6, 2011 - Uploaded by PartSelect
How To Troubleshoot A Dryer That Won't Heat ' PartSelect.com ... If you're using an electric dryer check ...
Oct 30, 2015 | Dryers
My maytag electric dryer wont heat up
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer does not heat. Fuse, thermostats, heat element all have continuity, power chord is good, 240v at plugin... stumped. It is a model # LER4634BQ1 Whirlpool SN# ME4471484
dryer_heating-element.jpg Heating Element
dryer_thermal-fuse.jpg Thermal Fuse
dryer_thermostat.jpg Thermostat
dryer_timer.jpg Timer motor
Feb 06, 2010 | Whirlpool LER4634J Electric Dryer
Heavy duty kenmore dryer model # 76680100 not heating up to dry cloths
Hello there:
please try this
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Jan 19, 2010 | Dryers
Will run but won't heat
HELLO THERE
There are 5 things that can make a dryer not heat please review the following items that i have provided for you
investigate these five areas if your dryer is not heating up:
Proper Voltage
Jan 18, 2010 | Whirlpool LER4634J Electric Dryer
Dryer not heating. Toubling fine.
hello there there are 5 different things that can majke your dryer not heat up please review these 5 things that i have provided
Proper Voltage
If your dryer won't heat up, it's possible that it is not beingsupplied with the proper voltage. Here are three ways to make surepower is getting to your dryer: First, make sure your dryer is pluggedin. Next, check the circuit breaker panel to make sure all the circuitbreakers are in the correct positions. Finally, check to make sure nofuses in your fuse panel are blown. Any of these could explain whypower is not getting to your dryer.
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 18, 2010 | GE Dryers
Whirlpool dryer will not heat
Hello there:
There are 5 things that would not make the dryer heat up i will post you them here ok
Jan 17, 2010 | Dryers
The dryer does not give heat
Hello there:
Proper Voltage
8574d88.jpg Heating Element
d5b5af3.jpg Thermal Fuse
77d6bd4.jpg Thermostat
Jan 14, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
LG DLG2532 Gas Dryer Logo
294 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
