Question about KitchenAid Superba KSRG25FK Side by Side Refrigerator
Unit no longer cooling at all
I hear the fans and some peridoc clicks from the compressor. Compressor gets very hot hot. None of the copper lines change temprature significantly.
Is my compressor shot?
My unit is 8 years old, it it worth repairing?
    President:
  • 1,218 Answers
Good day,
The clicking you hear is the compressor trying to start and can't.
This can be due to the start components mounted on the side of the compressor or the compressor itself.
The items mounted on the compressor are the thermal overload, the start relay and on many models a start/run capacitor.
When the protective cover is removed, these items can be removed by pulling them off the pins of the compressor.
Most appliance parts houses would be more than happy to test them for you. If any are found defective. Replace.
If the starting components all check good, then it is likely the compressor itself has failed. The price varies but could be near $500.00 with the installation.
Posted on May 25, 2010
My refrigerator freezer does not cool below 70 degrees. I just relace the start relay and now the compressor runs but the condensor fan won't work unless i give it a little spin.
Lubricate the condensor fan with a parifin based oil like Union 76 turbine oil or "Zoom Spout" oiler. These fans are notorious for the bearings drying up on them.
Being careful.... touch the compressor copper lines. One should be very warm almost Hot to the touch.
Also with the unit unplugged..... note that there is a coolant drier with a small capillary tube coming out of one end. Tap the side of this by holding a hammer handle (wood) against it and hit it on the side with a screw driver handle.
Check to make sure the evaporator fan in the freezer compartment is also running when the compressor is on. Anytime the compressor is running BOTH fans must be running. If you can not get the condensor fan up to full speed you will note that the chassis around the door seal area will be quite warm almost hot to the touch and the unit will not be cooling properly. Just for troubleshooting.... direct a fan at the condensor coils and see if the freezer compartment gets cold and that the chassis around the door seals is just warm.
Note about compressors in general.... if you unplug a unit.. it must settle / stabilize for 15 - 20 minutes so that the compressor can restart. Any power off periods less than 15 mins will result in the compressor cycling via the thermal overload every 4 minutes or so... and it does not run for more than 40 seconds when the overload kicks off the PTC relay power.
If you never feel the copper line off of the side of the compressor get hot then the unit has lost coolant.
Thanks for choosing FixYa,
Kelly
May 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My True beer cool stopped cooling last night what should I do ?
That is a broad question. Lets do a checklist. When you plug the unit in the compressor behind the grill on the front should come on and the fan in front of the compressor should come on. The radiator in the compressor compartment needs to be clean from all dust and grease. Many times this is overlooked and can cause real problems by letting the compressor overheat. Now look inside and find the fan cover. It hangs from the inside top of the cooler. It should also be running. If either fan is not running the unit will not cool. Sometimes there is an obstruction, such as someone pushing a six pack up against the fan cover and pushing it into the fan. The fan down by the compressor is sometimes blocked by the cardboard shroud that is built around the fan. Also in a few cases rodents have gotten caught in that fan. If everything is running, you will have to look deeper into the compressor compartment. There is a screw in the front of the radiator that hold the compressor unit in the cooler. Unplug the unit from the wall. Remove that screw and slowly and carefully pull the compressor unit towards the front of the beer box. It will slide almost all the way out. You will see a coil of copper tubing at the back of the compressor that allows enough slack in the lines to slide this unit out. When you push this unit back in it helps to have someone behind the cooler to pull back on that coil as you push the unit back into the machine so it does not get crimped. With the compressor unit pulled out, plug it back in at the wall. If your compressor is running and you have proper amount of refrigerant, the small copper tube from the compressor to the radiator will get very hot, enough to burn your finger, after two or three minutes. After 10 minutes the larger copper line that is usually enclosed in a rubber sheathing should get cold. One way to know if you have a burned out compressor is to listen to the compressor and fans when you first plug into the power outlet. A bad compressor will usually try to start for 2 or 3 seconds and then click out. While it is trying to start the fan will slow down because the compressor is pulling way too many amps and is pulling power away from the fan until it clicks out again. If you can hear the compressor come on and run but it makes no heat to the radiator, you probably have a refrigerant leak. Your freon is gone or almost gone. If it was a slow leak you would usually notice that the cooler does not seem to cool like it once did. If it was working good and suddenly stopped cooling, the most likely problem is a bad compressor. Changing a compressor is usually beyond the average do it yourselfer because it requires welding the unit in place and gauges and a supply of refrigerant which is almost impossible to get without a liscense. Let me know what you find out.
Oct 13, 2010 | True TD-65-24 Commercial Refrigerator
Both refrigerator and freezer have stopped cooling. The compressor sounds like it is working and then will stop. The fan is working. The copper pipes coming from the compressor are hot/warm to the...
This sounds like your refrigeration unit is low on charge...there probably is a leak in the system...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 25, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
My true back bar cooler dosent cool it is not iceing over
If you can gain access to the compressor, you will see 2 copper lines going to the compressor. One is smaller than the other. VERY CAREFULLY lightly touch the smaller line while the unit is running. If the compressor is running, that line will be extremely hot.
Start there.
Let me know if I can be of further help.
May 27, 2010 | True TD-65-24 Commercial Refrigerator
Heat runs constantly. Feels cool unless emergency
make sure out door unit is running not just the fan out side should hear compressor and in heating mode the large copper line should be hot fan should be in auto position on stat hope this helps
Dec 06, 2009 | Heating & Cooling
My side by side refrigerator and freezer artent
ALWAYS CHECK THE EASY THINGS FIRST,LOOK LISTEN AND FEEL. PULL THE FRIG OUT AND CHECK THE COILS AND CLEAN IF DIRTY
2) LISTEN TO HEAR IF THE COMPRESSOR IS TRYING TO START, WHERE THE POWER CORD GOES INTO THE COMPRESSOR YOU SHOULD SEE A LITTLEDOMM SHAPED COVER THAT HOUSES THE CONNECTIONS LISTEN TO SEE IF YOU HEAR A HUM THE A CLICK.
THE HUM IS THE COMPRESSOR TRYING TO START THE CLICK IS THE OVER LOAD TRIPPING OUT FROM TRYING TO START THE COMPRESSOR, IF YOU HEAR THE HUM AND CLICK THE COMPRESSOR IS LOCKED UP AND CAN BE VERY COSTLY TO REPAIR. IF YOU HEAR THE COMPRESSOR RUNNING FEEL THE LARGER OF THE TWO COPPER LINES ON THE COMPRESSOR AND SEE IF IT IS VERY HOT, WHEN I SAY HOT I MEAN HOT SO JUST LIGHTLY TOUCH QUICK. IF THE LINE IS VERY HOT THE COMPRESSOR IS BAD AND PUMPING HOT GAS BACK TO THE UNIT. THIS ALSO IS NOT CHEAP
3) IF THE LINE IS WARM YOU MIGHT BE SAFE IT COULD JUST BE LOW ON A CHARGE THIS CAN BE REPAIRED EASILY SOME TIMES, ALL DEPENDS ON WHERE THE LEAK IS IN THE UNIT.
IF YOU DON'T FIND ANY OF THESE THINGS WRONG AND YOU HAVE ELECTRICAL TRAINING YOU CAN START AT THE POWER CORD AND WORK YOUR WAY THRU THE UNIT FOR ANY BAD COMPONENTS. OF WHILE THE UNIT IS PLUGED IN DOES THE LIGHT COME ON. UNLESS YOU ARE CFC CERTIFIED AND HOLD
A CARD FOR THIS NO YOU SHOULD NOT TRY AND REPAIR THIS YOUR SELF. ELECTRICAL TROUBLE SHOOTING YOU CAN DO
WHEN EVER YOU HAVE TO CUT INTO THE REFRIGERATION SYSTEM ITSELF I WOULD SAY NO UNLESS YOU HOLD THIS CFC CARD THE FINES ARE UNBELIEVABLE IF YOUR EVER CAUGHT
tstewart1956
Aug 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The mini fridge does not cool. This fridge doesnt use any fans so nothing to check there. The compressor seems to be awfully hot (although I dont know if thats normal) you wont born your hand but it would...
Hi, it's possible,your motor overlay relay has switch off motor, if your days are hot, or if room temp get high, that could happened,unplug ref. let motor cool down for about an hour, if compressor is running, but not cooling, it's possible you got a freon leak, normally ref have a condensate line, that passes through, front of door, that usually get rusted and leak,normally we by-pass it, now if there's a leak, you will have to repair leak first, you will have to change filter drier, vacuum and recharge. no you won't be able to buy freon and tap it up, same princple like vehicle a/c, but, different application, could also be an electrical problem, check motor overload, situated on compressor terminal, remove compressor terminal cover, and you will see overload relay, it's round, has one wire connected to compressor terminal and another connected to wiring harness. also, you can check compressor for short circuit, remove 3 wires from compressor terminal, place one tester lead on copper tubing coming from compressor and next tester lead, place on compressor terminal one by one, if you hear a beep (continuity) from any one of those terminals, compressor windings are faulty, replace compressor, or could just be hot summer months, let it cool down, but remember, remove plug from receptacle. or you are victim of low voltage, low voltages are more frequent in summer months, it could damage compressor winding, or compressor overload relay, let it cool down, and retry it. let me know what happened, before you attempt any repairs. and i can tell you what exactly what the problem are. good luck.
Aug 11, 2009 | Sanyo SR-4911M Compact Refrigerator
U-Line no longer cooling
This sounds like the thermostat is the problem. I wouldsuggest touching the compressor at the back of the unit to see if it is hot or cold. If it is hot then you have probably have power down to the compressor, if it is cold you could (if capable) bypass the thermostat to see if it kicks in. Hope this helps.
Aug 23, 2007 | U-Line 2075WC Wine Cooler
Fridge isn't cold
First thing I would check is the evaporator fan in the freezer to make sure its working. About the copper lines, one should be cold to the touch and the other should be hot. if both are cold your compressor may be locked up. Or if its a whirlpool build unit I would also check to make sure the relay on the ompressor is good.Pull it off the compressor and shake it. If you hear like a lot of little pebles shaking in it its bad and need replacement. that was a common problem with some whirlpool units. If that is good remove the back of the freezer and check the evaporator coils to see if there is a frost pattern on it. If not your compressor like I said may be bad or you have a refrigerant leak and there is no more gas in it. Good luck
Jul 19, 2007 | Kenmore 74522 Top Freezer Refrigerator
KitchenAid Superba  KSRG25FK Side by Side Refrigerator Logo
167 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
