Question about KLH ASW12-120 Subwoofer
I am looking for a replacement sub amplifier,
The problem is a piece of the circuit board got fried and i am looking for either parts or a whole new back. so a replacement sub amplifier, which is part of the sub. or a replacement chip for the am.
    Brigadier General:
  • 8,546 Answers
Or you could just write of the built-in amp, disconnect the sub from it and run the driver's leads outside the box, buy any decent amp, connect it to the LFE feed for inout and the bass driver for output and carry on.
That's what I did when a second copy of a powered sub died the same way the first one did.
Posted on May 26, 2010
My psw112 sub stopped turning on and none of the circus are fried on the amp but it looks like it got really hot what can I do to fix it?
Is usually a capacitor or more components on a mosfet circuit some capacitors may have have a white residue . If you know All about electronics and can source the affected parts that's needs replacing and know how to solder you can fix it .
else get an expert to fix .
Mar 28, 2016 | Car Audio & Video
I ended up with one piece of a Teac model CD-X8 MIcro Hi Fi System. you can see what the whole system looks like at http://www.amazon.com/Remanufactured-CD-X8-Wall-Mountable-System-Subwoofer/dp/B000B65GV6...
Yes - you have the sub-woofer. It is a powered sub-woofer with a built in amplifier for both itself and a pair of small satellite speakers. Frankly, given the low cost of the whole system it may not be worth selling on ebay due to the high shipping costs of such an item, but I imagine you could get $30 for it or so on local craigslist or something, assuming you have no use for a sub-woofer...
May 05, 2011 | Audio Players & Recorders
My daughter broke one of my usb ports in the front of my asus cm1630 how do i get replacment parts can i buy a usb 2 or do i have to buy the whole setup that contains the usb ports and media card slots
USB 2.0 refers to the technology, not the connector itself.
http://en.wikipedia.org/wiki/USB
Obtain another USB connector, and solder it in?
Sure, maybe. Depends on your de-soldering/soldering skills, and if the circuit board is damaged.
> Physically damaged in that the board is cracked, and circuit traces are ripped loose, (Repairable with a jumper wire, or wires), AND/OR the USB port was fried out (Short Circuit), and it fried out the entire circuit board.
Obtain another circuit board? This would be the way to go IMHO, but try to find one.
You may have luck on Ebay looking at Desktop Computers > Computers for Parts, or the actual circuit board itself, dunno.
1) http://www.mouser.com/Search/Refine.aspx?Keyword=USB+female+connector
2) http://www.radioshack.com/product/index.jsp?productId=2062744
3) http://www.mgchemicals.com/downloads/appguide/appguide0805.pdf
(PDF file. Takes approximately 20 seconds to download. {Time it takes also until you see the first page)
For questions post in a Comment.
Regards,
joecoolvette
Dec 12, 2010 | ASUS Computers & Internet
Sub-Zero 650 freezer (bottom) too cold. Tried to
probably bad control board. check this. push the on/of key. the whole ref and freezer nedd to stop. if you hear the compressor in the upper part of the unit or the fan. your contol board need replace.
Mar 31, 2010 | Sub-Zero Bottom Freezer Refrigerator
Amplifier draining btry
No power should be applied.
Dec 04, 2009 | Solid Audio Car Audio & Video
Its in protect mode and i don't know how to get it out it was hitting fine then it just stopped and i looked at the subs and they would posh all the way out then back i don't know whats wrong
overloading your amp try just one sub hooked up and see what happens if it starts working do not bridge your subs use two channels and try again other wise you fried the circut board in the amp some where
Oct 31, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Power good no green light no subs
Make sure you got a good ground. do not ground on painted surfaces! If you got power from battery, check the remote wire running to cd player. Hook up remote blue wire with the one for cd player. If you still have a problem and the fuse is good, then the amp is fried
Jan 30, 2009 | Hifonics Brutus BXi 1206D Car Audio...
Fried Woofer
The problem are worsen that before. It is wisely to replace both left and right amplifier
IC, but make ensure that the power supply feed a good amount of voltage to amplifier,
Also a strong good signal. Be sure to measure it.
r_ic7
Jun 22, 2008 | Alesis M1-Active MkII Main / Stereo...
Sub amp not working anymore
sounds like a typical case of poor conections causing the amp to fail... take the cover off of the amp. Inspect where the terminal blocks meet the circuit board. SOmetimes you can repair it sometimes its just too far fried..
Sep 18, 2007 | Performance Teknique ICBM-772 Car Audio...
My 7801 doesnt turn on
check pwm circuit amps turn on with 3-4 volts on mosfet gates ic 494, 5252or 555 controll these.hit me up for more
Apr 03, 2007 | MTX THUNDER7801 SUPER AMPLIFIER CLASS D...
KLH ASW12-120 Subwoofer Logo
214 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
