Question about Goodman CLQ36AR49 Air Conditioner
My AC unit has three wires, green, white red. Coming off the house and off the unit. How do I wire them!!
    President:
  • 1,515 Answers
Hi, if you are talking about the wires,high voltage wires coming from the breaker box, and the same coming from the outdoor unit which are also high voltage wires, you have to set a disconnect box and mount it with in 3 to 5 feet from the outdoor unit. I am assuming you had no prior a/c unit there? If not, the 3 at the house must be ran out of your main breaker box through a breaker, double pole. It needs to match the rating of the voltage on the data plate on your unit, lets say, 30 amps. From your breaker box it needs to be ran through water tight conduit over to the box you will be adding there. Even though you have a green for ground, white and red, the white should be 120 volts and the red the same to have 220 volts. They will wire in this box to the line side. The directions in the new box will tell you line/power in and load/power out to new unit. This box you will need to buy is either a 30 amp or 60 amp disconnect. From the new unit, you will need to buy enough wire of the same size, and a piece of 3/4" seal tight flex conduit and 2- 3/4" connectors. Pull the 3 pieces of new wire through the flex conduit and connect to the 3 wires there. The green is ground so just connect it to a ground or the case. The other end will go through a knock out plug into the box and will connect to the load side. There will be a lug for the green ground. Coming from the house at the breaker box is where these 3 wires should be, and coming out of the breaker, you can use the 3/4" seal-tight to pull enough wire from there to the new box. This is what feeds your outdoor unit. This is just for the outdoor unit. The indoor unit runs on its own power source. There has to be a box mounted there also and wires pulled from the main breaker box to the indoor box. Hopefully who ever installed the unit has done all of this. If you have all of the boxes already there, just hook color to color. If you have never had a split system a/c unit at your home before and you are doing this yourself, there is a lot of high voltage wiring that has to be put in to run both the indoor and outdoor. Get back to me a let me know what you have to work with and if you have ever had a system like this before, and if you set the unit and installed the duct work.
Sincerely,
Shastalaker7
PS If the indoor unit is gas fired, the high voltage will be 120 volts. If its a heat pump, it will be 220 volts.
Posted on May 25, 2010
Midland 77-118. Three wires coming out of unit red,black,and orange. What is the orange for? Also need manual.
Its like the wiring in your house. That little three prong plug. There are three wires, one black,one white, and one green. The green is a ground wire , the black is neg flow and the white is positive flow. Well the red wire is hot ,the yellow wire is neg flow,and the black is ground. Some times the yellow wire isn't even connected. Look inside your radio and you will only see a red and black wire???you will have to google the radio model as such ( 77-118 owners manual)
Sep 01, 2015 | Midland Radio Communications
What do I do with the red wire on a Brinks Halogen Motion Sensing outdoor security light
Please perform these connections with the mains power off.
The standard is the Black wire is hot, the White wire is neutral, and the Red wire is switched. For your Sensor connection 120V is connected Black to Black and white to white while the Load is connected White to White and Black to Red (assuming your load is using standard color coding.
Here is a simple diagram for your connection.
Mar 01, 2015 | Electrical Supplies
Need to install a hot water heater; need electrical diagram.
Generally you will have three wires
1. bare or green wire this is your ground and is secured to the outside of the water heater usually with a green colored screw provide with the unit.
2. connect the black wire from the house to the red wire on the unit.
3 connect the white wire from the house to the white wire from the unit.
In general as long as you hook up the two power wires from the house with the two power wires from the unit it does not matter as one wire will supply 110v and the other wire will also provide 110v..
Verify check and reverify that the power is off anytime you are working with wires.
Sep 01, 2011 | Heating & Cooling
I have a bryant model 702b packaged unit with 5 wire thermostat wiring coming out of the unit. R Y B G and W. The thermostate in the house is 5 wire and goes to the old central unit and them has a 4 ire...
R-Red is power
Y-Yellow is cool
B-Blue is cool as well
G-Green is fan leg
W-White is usually heat Leg
If you have no indoor unit and this is a ac/gas or
electric outdoor unit try this.
R to R/Red to Red
G-G/Green to Green
Y-Y/Yellow to Yellow
W-W/White to White
-Dont Hook up Blue.
Turn power back on turn the fan to on,fan should run
Turn to Heating, heating should come on
Turn on Cooling,if cooling does not come on switch yellow with blue.
Jul 02, 2010 | Heating & Cooling
Thermostat wires running from house to outside Kenmore AC unit were chewed by dog. Got replacement wire. Took panel off. There were three encased wires running into AC unit that were chewed. Only see...
If you have a central air conditioner, or a split system, where the indoor unit is attached to the furnace and a outdoor unit is located outside of the home. 2 copper lines will be connected to it, a larger and a smaller one. If it is a air conditioner and not a heat pump, the A/C usually uses 2 wires, that are connected. Allot of times a installer will use a 3 wire thermostat wire, to run to the outdoor unit, if this is the case, the third wire will be folded back out of the way.
The color of the wire is usually picked by the installer, I myself usually use white and red and fold the green out of the way. If you only had 2 wires hooked to it to start with, it really would not make a differace which one you hook up to either one of the yellow wires.
All you are doing it having one wire coming in and one wire leaving,,,, just creating a complete circuit, just don't connect the two yellow wires together.
Example: If you have 2 yellow wires on the A/C unit and 2 wires coming from the house "example a red and a white" hook the white to "One yellow wire" and the red wire to "the other yellow wire".
You are just creating a complete circuit, when the thermostat calls for cooling, it creates a magnetic pull and closes the contact points, in the air conditioner, outside, this allows the 220 volt to flow to the compressor,,, and ahhhh cooling!
I hope I have not confused you, I am just starting to help on this site and still trying to make things understandable.
Wish you the best,
Paul Gibson
Mar 29, 2010 | Heating & Cooling
Hi Proper way on wiring furnace.
I can give you a start, For heat only, R terminal on furnace to Red wire to R or RH terminal on thermostat. W terminal to White wire to W terminal on thermostat. G terminal to Green wire to G terminal on thermostat. This will get you heat but not air conditioning.
Jan 06, 2010 | Goodman Heating & Cooling
I have a RUUD AC Model UPFA 060JAS, Serial # 3687 F4787 3195. My dog ripped the wires apart on the outdoor unit. Wire coming out of the house (6) are colored red, blue, white, green brown, and yellow. ...
Paul, you will need to look at the indoor unit and determine which wires from outside are connected inside. let me know. more then likley they color coded it but better to be safe. also does the fan inside still run if you switch thermostat to fan ON. if not the transformer may have blown, if yes you need to make sure you shut the breaker controlling the inoor unit off while your messing with the wires, or you will blow the transformer in the furnace
Mac
Sep 26, 2009 | Heating & Cooling
Need to connect 3 wires from pole to 2 wires in unit
It sounds like a 120 volt line coming in from the pole. Red is the hot wire, white the common or neutral wire, and the green ground. Hook the red and white to the two main wire lugs in the unit and the green goes to the frame or ground lug that will tie to the frame.
Jul 12, 2009 | Heating & Cooling
Installing a universal remote on a ceiling fan.
your remote modual should have two or three wires coming from the unit on one side to go to the fixture and three on the other to hook it to power , the three should be to connect to the black (power), the white (Neutral) and green (ground), now the unit has power. The two or three coming from the other side should be a white and two other colors or two the same , black, red, or blue, The white connects to the fan white and the other two go to, one the fan and two the light. Any questions E-mail me...hwyhmmr hotmail
Oct 22, 2008 | Hunter 52" Ceiling Fan With Light And...
Goodman CLQ36AR49 Air Conditioner Logo
129 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
