Question about Bosch Axxis+ WFR 2460 Front Load Washer
No Spin Washer will not spin . You can hear the motor run but no spin . All else works.
  • Bosch Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineNo Spin - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 26, 2010
Maytag washer mah5500 neptune spin cycle is not working correctly timer jumps ahead and back from 8 to 7 8 to 7 sometimes to 6 then back to 7 or 8.in spin test display isall over the place.clothes never...
f your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Jun 15, 2008 | Maytag Washing Machines
Spin is not working
if you can hear the motor running,the water drains but no spin or agitate most likely you have a broken motor coupling.watch video
http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c hope this helps
Mar 15, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
My maytag atlantis washer purchased in 2002 would not spin on the colors spin cycle. I turned the control completely around to the spin cycle and tried again and it didn't work. I also set it on the spin...
Jim, I would be looking at the lid switch assembly. Try to press down on the lid in the very front edge. IF the switch is going out of tolerance, the added pressure will activate the switch and allow the machine to spin. If it were a transmission problem, you would hear the motor. (I'm assuming you are not hearing the motor).
If you are hearing the motor run, check the motor slides to make sure they are not rusted and the motor is able to pivot back and forth freely.
Let me know if you have any other questions on this!!
Aug 19, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Drains but will not spin. I can hear the motor
The machines spin motor winding may be short circuited kindly replace the motor
Dec 23, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer no longer spins.
with the washer set for spin and turned on...raise and lower the lid.
If it spins replace the timer.
If it does not spin...replace the direct drive coupling on the motor.
Mar 11, 2009 | Whirlpool LSQ9600L Top Load Washer
Kenmore portable compact topload washer model 110 49722992--won't spin!!
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Apr 03, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
Bosch Axxis+ WFR 2460 Front Load Washer Logo
157 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
