Question about Dell Inspiron 537 ST PC Desktop
Adding Sata drive to a Dell Inspiron 537ST
I have a Dell Inspiron Desktop 537ST which only has one SATA drive connector. Is there such a thing as a sata drive card that I can install in the computer to add another drive? It's a slim tower also.
  • Dell Master
  • 6,487 Answers
Yes you can use a PCI to SATA connector , check this link for the sample of that device that you can use for your computer to add additional SATA connections.
http://www.usb-ware.com/2-port-sata-pci-card-internal.htm
Posted on May 25, 2010
  • angela_g_cat Sep 01, 2011
    the company referenced by the link closed in 2009.
How do I replace the SATA data cables Dell inspiron one 2305 all in one desktop computer
I replaced the SATA data cables on my own Dell Inspiron 2305. You will need to remove the back of the computer. It is held in place by several small screws, not unlike a laptop. Best thing to do is go to the Dell web site and search for disassembly instructions for your model. Once the back is off you can trace the SATA cables from the hard drive and the optical drive to the spot they plug into the mother board. Your new cables will need to be woven into the same places as the old ones, otherwise the cover won't fit back in place. I recommend buying new cables that have the latch feature built into the connectors. They are much move reliable.
Dec 25, 2013 | Dell Inspiron One 2305 Desktop Computer...
Dell inspiron 531 wont boot saying SATA 0 installed SATA 1 installed SATA 2 none SATA 3 none
Johnathan,have you changed anything in BIOS.set optimal defaults ?
if BIOS can change BOOTDRIVE.windows are in one of the drives.
Aug 18, 2013 | Dell Inspiron 531s Desktop Computer
Install cd drive
Dell Optiplex 740 DESKTOP?
http://support.dell.com/support/edocs/systems/op740/en/UG/dt_index.htm
Under the bold black subheading -
Removing and Replacing Parts, click on - Drives, in the list.
After details on the power cable, and data cable, the Optical Drive is the first drive listed.
Examples of a SATA data cable, and it's connector; and a SATA data cable connector on the motherboard,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the L-shaped opening in the SATA data cable's connector.
Lines up with an L-shape on the motherboard connector.
ONE style of SATA motherboard connector is shown.
Your SATA motherboard connector may differ in appearance. Still has an L-shape in it, though.
(Hold the SATA cable connector in your hand, look at the connector.
If you turn a capital L to the LEFT, and turn OVER, that is the correct position to install the cable, in.
_____I, then turn over )
SOME SATA cable connectors have a Lock on them.
Some are like a tab you press down, others are like a small 'bulb, that you press down on. Suggest use your thumb.
Depress Lock to Install cable, and to Remove cable.
Between a SATA data cable's connector, and a SATA power cable's connector; a SATA power cable connector is Larger.
SATA data cable connector has 7-pins.
SATA power cable connector has 15-pins.
Example of a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Depress the Drive Release Latch, slide the drive towards the Back of the computer, lift up slightly to remove SATA data cable, and SATA power cable; THEN remove optical drive.
(CD/DVD drive)
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 18, 2013 | Dell OptiPlex 740 PC Desktop
570wcd-44-rm5 failed spndle test
Optical drive failed the Spindle test.
Make sure the SATA power cable, and SATA data cable; are tight to the optical drive. Still no? Replace optical drive.
http://www.dell.com/support/troubleshooting/us/en/19/Product/inspiron-570
Dell Inspiron 560/570 Service Manual (1031KB)
Regards,
joecoolvette
Nov 28, 2012 | Dell Inspiron 570 Desktop PC (I5707163PBK)
Can a SATA CD-RW drive be used in a Dell 3000 with IDE drives? I didnt know and bought a dumb CD-RW that turned out to be SATA. All I want to do is replace the non-working CD drive currently in the thing....
Not without adding a SATA drive controller card to the computer. If you can afford it, hang on to the SATA unit, as your next computer will definitely use it, and buy another PATA drive for this computer.
Jul 06, 2011 | Dell Dimension 3000® Pentium® 4...
Can i replace the hard drive parellel type of inspiron 2200 into SATA type hard drive?
Ofcourse you can replace the hard drive as Inspiron 2200 are usually supplied with SATA hard drives. But call Dell support team as they will only replace the hard drive if your computer has hardware warranty or else they will ask to purchase it.
Chio,
Anirban Mazumdar
Dec 04, 2010 | Computers & Internet
Bought internal harddrive and don't know where 7-pin SATA port is on motherboard, or Sata power connector is from PC.
hi, sorry to tell you this but that model of dell desktop does not have sata ports or sata power connectors and has no spare drive bays to mount the hard drive either , you would be best to try and return the drive and purchase an external hard drive and connect it to your PC via the usb socket .
Hope this helps
Apr 24, 2010 | Dell Dimension B110 PC Desktop
IS THERE ANY replacements for YH278 HITACHI 120 GB SATA HARD DRIVE HTS541612J9SA00, THAT IS CAN I REPLACE WITH 250GB.
Generally speaking, you can replace any SATA hard drive with any other SATA hard drive. Notebook SATA drives are all the same size, basically, (2.5 inch), and desktop drives are generally the same size (3.5 inch), Desktop and notebook SATA drives will connect to the same power and interface cables, though desktop drives require more power. Just make sure that you pick a 2.5" drive for your notebook, or 3.5" drive for your desktop, and the drive will attach with no problems.
As for the size of the drive, to my knowledge, any system with SATA should support any size SATA drive (I put a 500 gig drive in my notebook, where the stock drive was 160 gig).
Feb 28, 2010 | Dell Inspiron 6400 Notebook
I am trying to install a gdr-8164b drive in my inspiron 531 but the connectors are different. How would i go about this, is there an adapter that is available?
your drive is an LG gdr-8164b and is a IDE your computer is using for SATA drive which is different you need to change your drive to a SATA or get a PCI with a IDE
Sep 10, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
New IDE Drive - will it work on my Desktop?
According to the manual for your computer it only has SATA connectors. 4 to be exact. There are no IDE connectors.
SATA cables look like this:
There are many good SATA drives out there. It is a better (faster) drive besides.
Mar 19, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Dell Inspiron 537 ST   PC Desktop Logo
130 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
