Question about Sharp AR-235 Copier
Copies have double exposure on them, what would cause this on my sharp ar-2335? thanking you in advance.
  • 328 Answers
See your scan unit and moving.has no shake when moves. or mirror is not clean
Posted on May 29, 2010
SHARP AR-M455, AUTO-EXPOSURE
Press custom settings, then go to key operator settings. The default log in is 00000. Then go to ccopy settings, default, exposure adjust.
Jul 16, 2012 | Sharp AR-M455N Copier
Whole page covered by black and no copy is displayed when we copy orginal
Check the exposure lamp :
open the upper cover and turn on the machine if you didn't see light in copy glass you should replace the copy lamp.
Jan 09, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp -COPIERS - AR-5316 Advanced Digital Imager Copier not workig digital F5 blinging
Hallow, this is a problem with the exposure lamp on the document glass which is not working or if it is lighting, it is not sensing the white mark on the cover which is above it.
Remedy
Please check if the cover that locks the glass is well screwed or present.
Check if the copy lamp is lighting and replace with a working one.
Check if its cable is not disconnected on its power board located beneath it.
Replace the main board of the machine.
Nb use that sequence to solve your problem and good luck.
Oct 18, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp Photocopier 2114 makes all black copies
OPEN top cover make a copy see if copy exposure lamp turns on or not
May 25, 2010 | Sharp AR-5320 Black and White Copier
My sharp ar5516 blink f and 5 what should be the problem
Hello sir; Try to make a copy while lift up the cover, if scan without light. it means the exposure lamp defective, replace it will take care the peoblem.
Dec 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
Automatic exposure adjustment
NP7161: we include - blazes "id"; what throw?
Necessary entering the identification number of the access; the unset: Head - ID - a foots - a head - (on дисплее will appear ID1) - 2 - a start - (on дисплее 2-1) - 0 - (on displey 2-0) - a start - (the codes of the users delete) - ID possible to copy.
NP7161 - a regulation AE
Adjustment AE: -User mode 12 - an the man picture, 12. then - a button "+/- exposure" (24 steps); "Start" - a taking the change
May 16, 2009 | Sharp AR-5316 Advanced Digital Imager...
Double imaging on paper
Yes, the toner is not being cleaned off, you will need t change the roller, it can also cause jamming
Jan 08, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL 1644
here is the fix: Press "C", press the exposure button (below the picture of the little man), press "C", press the exposure button. When you do this all the indicator lights will turn off. Now input "24", press the green start button, input 07, and press the start button again. Now turn the copier off and back on with the power switch on the side.
Press: "Clear", "Exposure Select Key", "Clear", "Exposure Select Key", "24", "Start Key", "7", "Start Key"
Sep 09, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-151
Try this sequence
Press: "Clear", "Exposure Select Key", "Clear", "Exposure Select Key", "26", "Start Key", "39", "Start Key"
there IS another subcode besides E7 try holding the stop or start or clear key you will probably see some different #'s
Sep 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-235 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
