Question about Zenith IQB32B42W 32" TV
Zenith IQB32B42W 32" TV works sometimes but looses picture. Top half of picture goes blank (dark) and the bottom half scrambles into horizontal lines. I hear a pop or click right before this happens. The TV will go off if it happens for too long of a time. Some times unplugging and plugging the TV in again will cause the TV to work again. Any idea as to what is happening and is it worth fixing?
  • Zenith Master
  • 1,869 Answers
Capacitors can be deformed or some solderings on active components can be bad.
Amplitude change and image geometry want change when warming up, buy a canister cold spray and spray some components, Be careful when working at high voltages in the fly-back (horizontal) circuit by crt television, and tripler and Focusing voltage.
Posted on Aug 11, 2017
5 Suggested Answers
  • 398 Answers
SOURCE: Auxiliary button on tv remote (I believe) needs off and I can't get figure out how...
The remote should have TV, VCR, AUX and maybe CABLE buttons at the top, one of which will light up when any button is pressed. Since it is a universal remote, the button at top lights up to let you know what mode it is in. If the AUX button lights up when any button is pressed, it means the remote is currently set to the AUX mode. To set it back to TV, simply press the TV button at the top. This puts the remote back in the TV mode and the TV button should now light up when any button is pressed. If that works and you are using a cable box with that set, then make sure the TV is on channel 3 by pressing 3 ENTER.
Posted on Aug 14, 2007
  • 121 Answers
SOURCE: TV went "pop"
prob not worth repair sounds like horiz sweep circuit. 150 200 to repair.
Posted on Dec 01, 2008
  • 89 Answers
SOURCE: Horizontal lines across TV screen Panasonic CT-31SF13U
The problem sounds like a vertical deflection issue form what you describe.
On average they are usually in the simple repair categories. On average they would run in the $50 range if you take it to a reputable repair shop.
There are several possibilities
Bad capacitor (s)
Bad vertical IC
resistor in the power supply to the vertical circuit changing value
Posted on Mar 13, 2009
  • 318 Answers
SOURCE: Zenith tv picture jumps after 20-30 min.
the variations of the supply causes that. a verticle stability be checked, specially semiconductors and capacitor changing valuas
IT=CV=Q AND frequincy = f=i/t
SO I is for time and T for tempareture
Posted on Mar 28, 2009
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
Zenith 32" TV Chirping Noise No Picture
Components in Power supply are bad most likely a 35v 100ufd capacitor if not then your Flyback transformer is bad
Jun 09, 2009 | Zenith IQB32B42W 32" TV
Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u old is ur TV?
hope u get a answer from hitachi....and good luck
Mar 12, 2009 | Televison & Video
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Samsung LCD television screen fault
My new TV LCD Samsung LC32C530 Series 5 has one half darker and with less contrast than the other.This is noticeable now always. There is a distinct and clear division down exactly half the display which separates the dark and light sides.. Any ideas?Thank you.
Jul 08, 2008 | Televison & Video
Half screen picture
This is commonly caused by failing capacitors in the vertical deflection amp area and sometimes with the output drive devices.
An experienced TV tech can troubleshoot your set and service it for you.
Jerry G.
May 17, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Zenith Z25X22S 25" TV can't read scores at top or bottom
On the inside of the TV, there will be a knob with a RED cap on it, labeled vertial position. (it actually looks like a variable inductor)
With an allen wrench (possible 1/4) give it a half turn in either direction and see what happens. On the Z25x22S model, the vertical and horizontal position adjustments should be right next to eachother, but on the model i worked on, there was no variable pot for the horizontal position.
Hope this helps!
Jan 27, 2008 | Zenith Z25X22S 25" TV
Sound and no picture
Hi, if your getting half a picture AND the other half is black the vertical circuit is failing, either solder is broken or vertical IC needs to be replaced, not a pricey fix, BMW Rider
Jan 04, 2008 | Sony KV-32S26 32" TV
1/3 of picture becomes partially scrambled
sounds like you have a frame fold-over fault, does banging the tv have any effect (slightly bang the set on the sides), if it does then its more than likely a dry joint, check all around the frame output chip, hope this is of some help to you
Jun 02, 2007 | Sony KV-35S26 35" TV
Zenith IQB32B42W 32" TV Logo
49 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
