Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
My printer keeps printing with lines thru the pictures
I've already tried calibrating from my pc & printer...Nothing seems to fix the problem. The color is off and lines are still showing on pictures when printing...
  • clotveins
    clotveins May 28, 2010
    remove both ink cartridges, place black one back into printer following by color one. try to make same print. if of no use, then
    Press Menu.
    Select Clean Printhead, then press OK.
    Select Deep Clean, then press OK. The On/Off light
    flashes green during the cleaning procedure.
    When the On/Off light glows a steady green, select Print Demo
    Sheet, then press Start.If of no use... tell me if there has been any printhead replacement
SOURCE: printing streaks
Sounds like the fuser.
stop the printing before it comes out of
the exit rollers by powering it off.
If half your page is good its the fuser.
Posted on Jan 15, 2008
  • 3 Answers
SOURCE: printer problems
Sounds like one or more of your printheads is worn out. They are designed to be user replaceable, and wear out after a certain amount of usage.
Black is obvious, but if the lines are purplish, your yellow head is bad. If they're greenish, your magenta head is bad. If they're reddish, your cyan head is bad.
Vertical lines are very unusual. Can you scan a printout and post it somewhere that we can look at it?
Posted on Jul 31, 2008
  • 90 Answers
SOURCE: My color on my printer is coming out too blue
Sounds like either the color cartridge is out of yellow or the color cartridge is not working properly.  First step would be to change the color cartridge.
Posted on Dec 14, 2008
  • 18 Answers
SOURCE: Color prints come out too light with lines
Okay, the driver for the printer (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the printer application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the printer driver, and the problem will be fixed!
Posted on Mar 13, 2009
  • 20 Answers
SOURCE: kodak esp 3 printer not printing properly.
you need to clean the printhead
Calibrate the printer (Scan + Cancel)At the same time for 5 seconds
Do a demo page ( Scan + Copy )
And go to the website :
www.kodak.com/go/esp3downloads
And download the latest version of the firmware
your all set after
Visit also the website
www.kodak.com/go/itg
for the troubeshooting guide
Posted on Mar 25, 2009
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
Colors and photos do not look right when printing on glossy paper using the HP Z6100PS large format printer. With photos on glossy paper, the ink seems to reflect off the paper, making the photos have a...
Hi
Did you try to calibrate on the same media what you want to print?
Try to delete any other calibrations stored. And re-calibrate the plotter on the same media or a plain paper.
DO RATE MY SOLUTION
Jul 07, 2011 | HP Designjet Z6100 InkJet Printer
My epson stylus DX 5000 prints out with half the lines of the document missing. It's OK for a couple of lines, then odd single lines and half line are missing. I't has full ink cartridges and ve tried the...
I would go to the epson website and download the latest driver for the printer. More comprehensive printing sofware might require the PCL version of the driver. But for regular printing, just download the latest PS driver and see if that helps
Mar 02, 2011 | Office Equipment & Supplies
I have a Zebra Z4M printer. We use it to print on various labels - pre-printed and blank labels (semi-gloss). I've been struggling to print on one of the pre-printed labels. Everything else prints...
some labels are hard to calibrate, nee to calibrate the sensors with manual calibration.
1} go to the MEDIA AND RIBBON CALIBRATION,
2}take 2 or 3 labels from the base paber, load the way to the based paper stay unther the sensors, 3}close printhead.
4} press ok.
5} Move the ribbon out from sensors and close the printhead.
6) press ok
7) wen printer ask RELOAD ALL, load the labels correcly and the ribbon, close the printhead and the top door, and press ok. The printer run the calibration it self.
wen finish, saved (press setub twice) and test.
Jan 21, 2011 | Zebra Z4M Printer
Picture is pink but keeps printing it in peach
Are you using Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 11, 2010 | Epson Stylus Photo R300 InkJet Printer
R1900 adds blue-green tint to my photo prints
Epson doesn't like Generic Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
Jan 22, 2010 | Epson R1900 Printer
Im trying to print a letter and the its text is faded every other line. i have run a calibration and done several head cleanings and also replaced the ink (which was full). Any ideas? Nothing seems to be...
Since you already the correct troubleshooting try to update the latest firmware of yur printer at kodak.com/go/downloads. Make sure if you download the firmware printer must connected to computer nad printer must turn On. You can also call kodak for a printhead replacement toll free 1 800 421 6699 EXt 05
Nov 12, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kroy K4350 Gap Sensor Problems
Your problem is too complex to solve in one pass on this or any other forum. Give me a call at 800-304-9043 and I'll walk you thru it. I'm Don from Hanover Technical Sales. www.EmpowerCompany.com hanover@visi.net
Apr 15, 2009 | Kroy K 4350 Printer
The printout has lines going through the pictures or wordings
here is the troubleshooting steps
try to remove the ink cartridges and put it baack again but make sure to hear a click sound when you put the ink cartridges,after that try to print again picture and if still has lines through it press the menu in the printer scroll down until you can see the calibrate printer,press ok and select the print calibration page and hit the ok button..after it print place the calibration page in the scanner glass and press start, try to print again a picture and if still has a line call the kodak hot line 1 800 421 6699 and you might have a printhead replacement.
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
311 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
