Question about Whirlpool Dryers
Model # LE7680XMN0--the dryer had been running the day before and I went to start it and it doesn't start--have checked the plug. Also could you tell me how old this model would be?
  • 24 Answers
This is definitely an older dryer. If the power supply is okay and the dryer does not start, the most likely problem is a bad power fuse part number 3392519. Other problems are possible but this is the most likely one. It's located in the back of the dryer behind the large rear panel. It's white and about 1&1/2" inches long. Always unplug your dryer before servicing.
Posted on May 25, 2010
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
I have a Kenmore 90 series dryer, and I have power to the 220/240 plug then when I open the door the light doesn't come on or the dryer doesn't run. I'm not sure where to look next, I don't...
Make sure both sides of the receptacle has 110 volts. Take meter and keep prong in ground slot and then put red prong in the others. You should have 110 volts in each one. If not change receptacle.
Sep 11, 2017 | Dryers
Hi , i have a Kenmore dryer special edition model # 110-8866291 stop working after i open the door while it running , did i blow the fuse ? please help .
its supposed to stop when you open the door,, close the door and try starting it up again, if it doesn't, its going to be one of 2 things,, the thermal fuse blew, they are located in the back of the machine or the door safety switch went out, you can check that by by passing it,, just jumper the 2 wires to it together and hit start , if you have no power at all to the machine, I'd check the thermal fuse first
Aug 23, 2011 | Dryers
After two times my Kenmore dryer would start and then stop mysteriously it now doesn't start. I'm leaning towards the receptacle and plug are the fault as they are both very corroded/oxidized. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 18, 2011 | Kenmore Dryers
I have a whirlpool dryer that won't start. I am renting and the owner doesn't know the model number. The power to the house went out and everything came back on except the dryer. I checked the...
heatman101
Jul 06, 2011 | Whirlpool LGV4634JQ Gas Dryer
I have a Craftsman Blower Model 358.794742, 25cc. It was working great. I used it one day and the next day when I went to use it again, it wouldn't start. The same gas was in it from the day before. ...
may need a carb kit or replace fuel lines and fuel filter check the lines to see if there are any cracks and if it has a primer bulb check that as well
May 19, 2011 | Craftsman Garden
Dryer suddenly quit. It has power because the interior light works, but it just doesn't start. No noises or odd behavior to report. Want to track down the issue and due the repair Asap, but we leave...
May be a broken belt or thermal fuse.
Some dryers have a switch that will prevent the dryer motor from running when the belt that turns the drum breaks. Others have a thermal fuse that does the same thing if the dryer should overheat due to a blockage in the venting. There are other causes for this issue, but these two are the most common.
Post your brand and model number so we can tell which style you have.
May 16, 2011 | Dryers
My dryer was working of I have to say never really has dried as well as I thought it should but it was at least working. However now it will not turn on at all. It was at first just beeping and all the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 30, 2010 | Kenmore Elite HE4 Electric Dryer
The dryer wont show any sign of power. The plug works fine
Press and hold start button for 4-5 seconds.Make sure that the start button has been fully pushed down or turned far enough to activate the dryer.
After that plug something else into the same outlet. If it works, you know you have power to the dryer. If it doesn’t work, you’ll need to check for any blown fuses or tripped circuit breakers.
If the power is there, you need to check door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Make sure that the control settings are appropriate, and that any buttons are fully depressed.
Good Luck and have a nice day.
Jun 21, 2010 | Frigidaire Electric Dryer
Dryers Logo
115 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
