Question about Batesias V171RUXRA (Silver) 17 in. Flat Panel LCD Monitor
Batesias V171RUXRA Monitor bought at thrift store. Have no user manual or set up. Don't know what the red and white Connection on back of monitor are for. I assume Speakers. What type of connect cable do I need to purchase. Thanks
  • 11,361 Answers
Spec: http://www.buy.com/prod/batesias-v171ruxra-monitor-17-1280-x-1024-40-ms-0-264-mm-silver/q/loc/101/203255971.html
Not much of the user manual on the wbe that I can find. You will need the VGA cable to hook it up to your PC for the Video, and mini stereo male to male phone jack for the sound. I am not sure about the power, some websies say it uses AC adapter (Regulated 12vdc 3.5A, http://www.directreplacementbattery.com/viewbatteryfor.cfm/LCD-Monitors-BATESIAS-V171RUXRA-LCD-Monitor-58161-FS1501-1789.html), some says it uses Power cord (no AC adapter). Pictures will help.
budmrtn@aol.com
Posted on May 25, 2010
I don't understand anything about changing the display settings on my Acer p215h monitor I push the buttons but can't figure out what to do
umm...usually if it is a desk top there will be buttons either on the side, front or back or even the top, one looks like a sun and another looks like a square thats normally half white and half black. they are your brightness and contrast...push either end of the buttons to adjust more bright or less bright, more contrast or less contrast.
Sep 16, 2012 | Acer P215H LCD Monitor
Are there built in speakers in my desktop?
Desktop units don't have buit-in speakers.
Will will need to purchase a pair.
Take care!
damnor01
Sep 16, 2012 | HP Compaq Presario SR1738nx-b Desktop...
Hi, I have compaq 7540 monitor 17''. It is showing only part of the screen and when I shake the monitor or plug it displays full screen for a second and gets reverted. Please help on this issue.
Sounds like you have a bad connection somewhere inside the monitor or cable. Try using a different cable (if possible) or trying a friends monitor. If it works fine, then you know that's your problem. CRT monitors are very inexpensive nowadays, and you might be able to find one at a yard sale or thrift store for pretty cheap instead of trying to get it repaired. Hope this helps!
Aug 25, 2011 | Compaq CV 7500 17" CRT Monitor
Correct Colors of the monitor are not being displayed on my Acer X153W monitor. The screen is more Reddish and Greens have become dark. Manually changing Gamma, brightness and contrast values of Red, Green...
check the VGA chord might have a lose connection. Check the connector if the pin is complete. If you are using a video card check the video card connector. Try to test your monitor to other computer if the problem is still the same it means the monitor have an internal defect which you can ask to the supplier where you bought your monitor because as you've said it is till under the warranty so it may replace a new one by the supplier or store where you bought your monitor.
Aug 08, 2011 | Computers & Internet
Hi, I have an Acer AL1715s monitor and the VGA cable is cut about 5 cm from the backside. The monitor has no VGA input on the back but is connected inside with a 13 pin connector. I have to make a new...
you have a rgb connection or a dvi connection.
do not engineer your own version of a vga/dvi cable.
just go and buy a new cable, which should be cheap
here is a service guide for this monitor
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/s.g_al1715_book.pdf
Oct 15, 2010 | Acer AL1715 17" LCD Monitor
I purchsed this monitor at a thrift store. It
Is your remote working? If so use the key pad and open up the menu- look for advanced settings, press unlock (parental controls) also use the default setting to auto reset the channels....
May 29, 2010 | Kogi L7CH Monitor
Monitor won't stay on
What type monitor? CRT or LCD? Most likely a power supply issue.
Jun 13, 2009 | Batesias V171RUXRA (Silver) 17 in. Flat...
Over Range
The display card resolution is set too high for the handling of the monitor, or the system board in the monitor is faulty.
Jerry G.
Jul 14, 2008 | Batesias BT-1501 (Silver) 15 in. Flat...
Drivers
you just type in monitor drivers at the website search.
Apr 18, 2008 | Batesias BT-1501 (Silver) 15 in. Flat...
Batesias V171RUXRA (Silver) 17 in. Flat Panel LCD Monitor Logo
119 people viewed this question
Top Batesias Computers & Internet Experts
David Payne
David Payne
Are you a Batesias Computer and Internet Expert? Answer questions, earn points and help others
