Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
Problems communicating to printer: "Dell Photo Printer 944" The specified resource name cannot be found in the image file.
  • HP Master
  • 6,487 Answers
This error that you're receiving is related to the printer software install on the computer, to correct the problem that you have you need to uninstall and reinstall the printer software from the computer. Then once you run again the installation disc for the printer follow the wizard to install the printer and then restart the computer once you;re done and check if its already working.
Posted on May 25, 2010
  • efsunderl771 May 25, 2010
    Before going through all this, I'd like to emphasize that only Quicken cannot print. All other programs print just fine to this printer.
    Also, the Quicken program not only won't print, it aborts after displaying the error.
    Do you still think this is the proper solution?
  • Mark Gil
    Mark Gil May 25, 2010
    OK thank you for the update, since only Quicken is the only software that cannot print from it and have the problem, so it will be better if you uninstall and reinstall the quicken from your computer to correct the problem.
Dell 944 v apple mac
If dell doesnt make a driver for the Mac system you will not be able to make it compatible. Check with Dell support/drivers to see.
Dec 12, 2011 | Dell Photo AIO Printer 944
Dell 944 printer error code 2200
Unplug the printer. Remove the power brick for 60 seconds. Now plug it back in. This should reset the error messages.
Does it still happen?
The try going here and see if you can fix it.
Dec 11, 2010 | Dell Photo AIO Printer 944
Quicken will not print. Program aborts after error message: Problems communicating to printer: "Dell Photo Printer 944" The specified resource name cannot be found in the image file.
Ensure that your printer is online and all cables are securely attached.
(i) If your printer is on a network, ensure that your network allows you permission to access the printer.
(ii) If you are printing to paper, ensure that the Quicken PDF Printer is not selected.
(iii) If you have more than one printer:
(iv) Ensure that you have selected the correct printer in Quicken. (Select the QuickenFile menu, select Printer Setup, and select the item you want to print. Be sure the correct printer shown in the Printer field. For example, if you are printing a report, select File > Printer Setup > For Reports/Graphs.)
(v)Try making another printer the default printer.
Microsoft Windows Vista:
Click the Microsoft Windows Vista logo (Start button) and select Control Panel.
Under Hardware and Sound, click Printer.
Select the printer and click the Set as default command button.
Microsoft Windows XP:
Click the Microsoft Windows Start button and select Printers and Faxes.
Right-click a printer and select Set as Default Printer.
(vi) Try printing from WordPad or Notepad to be sure Windows is communicating with your printer.
Click the Microsoft Windows Start button, select All Programs or Programs, select Accessories and select WordPad or Notepad.
Enter some text. Select the File menu and select Print.
(vii) If your file does print from WordPad or Notepad, try reinstalling the printer or printer driver.
(viii) If your file does not print from WordPad or Notepad, it probably means that Windows is not communicating with the printer. Check your Windows printer settings.
Thanks for using Fixya.
Good Luck and have a nice day.
May 25, 2010 | Computers & Internet
How do i scan a document?
the 942 printer can scan in 2 ways ,
  • a : from the computer using all in one centre , find it @startàallprogms àdellprinters àand click on aioc (suites xp and vista )
ø U may not see it (aioc ), if the printer driversare not properly installed .
ø when it open , click in scan or preview buttons..as it is self explanatory .
ø if u can open the application but still cannotscan ., then u may have the firewall blocking its communication and may anothersettings in the pc doing it ..please let me know ..
ø replay to me and I will help further .
  • b.: if u want to scan from the printer :
> use the arrowkeys on the printer to change it to scan mode and then press the scan button
> u may prompted to select the comp name …u want to scanto .. and then select the application to be used ..still cannot scan ., then umay have the firewall blocking its communication and may another settings in thepc doing it ..please let me know ..
Oct 26, 2009 | Dell 942 All-In-One InkJet Printer
How do I scan multiple pages into one document
When Save as PDF file is selected: The Save as PDF file dialog box opens. Specify the file type, file name and destination folder.
Select from the following PDF file types:
PDF When multiple images are selected, each image is saved as a separate PDF file. PDF(Multiple Pages) Multiple images are saved in one PDF file. PDF(Add Page) Selected images are added to a specified PDF file. The images are added to the end of the PDF file. You cannot rearrange pages of the PDF file to which images are added.
Oct 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Change setting
on windows go to configuration panel, select printers and faxes icon
in the printer and faxes window mark the dell printer, right mouse click and select properties.
Look o
I hope this answered your question.
n the different printer tab and select as default output draft.
Aug 30, 2009 | Dell 944 All-In-One InkJet Printer
Error 1102
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Dell 924 All-in-One InkJet Printer
Dell photo all-in-one 944
completly removed the net work, printer and 3300adaptor, all dell products as well as both computers, and started from scratch. If it happens again, dell is out.
Jul 07, 2008 | Dell 962 Photo All-In-One InkJet Printer
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
Seeker5211
Seeker5211
