My purchased a reconditioned Ricoh 2020D. The printer worked for a while on our network but is now in offline mode and we can not get it back online. We have been having trouble setting up the scan function but have been unable to get the Scanrouter lite software to work. Any ideas on what to check/change?
  • jolivier May 25, 2010
    Our Ricoh 2020D printer appears to be online at the equipment console - green light, no jams, etc. I can print config pages from the console. However, from the desktop via the network, the printer is offline and jobs are queuing up. This condition started when we were working on the setup of Scanrouter software. What should I do from this point?
  • 493 Answers
Please do the followings:
- Be sure that the printer is working correctly, i.e. no flashing lights, paper in the tray, no error messages on the printer screen, etc..
-You can also try to unplug the printer for a few seconds and then plug it back in to see if that does the trick (if it is indeed an issue with the printer itself).
-Check the printer if there is a light on the printer which indicates if it is on line or not. (Usually steady=online, blinking=offline. )
-Unplug your printer USB cable from the PC and plug it into another USB Port of the PC.
- Can you print a test page pressing the buttons on the printer?
- What is your operating system? If your OS has the option on the control panel, perform troubleshooting.
See is there any problem identified (if identified click solve/fix problem
- Uninstall and reinstall the updated and compatible version drivers of your printer.
- Check the printer Spooler and delete if it is not empty.
- Restart your computer and print a test page.
While printing, select that default printer from the menu if it not selected by default
If you can't find how to do, please write me your operating system and its version. Then I can explain.
For example:
In Windows 7 Operating system:
The Spooler can be deleted totally as below:
- Go to "Windows 7" Start Menu, Control Panel, System and Security and Administrative Tools.
- Double click on Services icon.
- Scroll down to the "Print Spooler" service, right-click on it and choose Stop.
- Navigate to the following directory: Start>Computer,
C:\WINDOWS\system32\spool\PRINTERS
- And delete the everything inside of this folder. Do NOT delete the folder itself, just the everything (the sub folders,files) inside of it.
-Go back to the Services window as you did above and right click on the Print Spooler service and choose Start.
- Restart the computer.
- Print a test page
NOTE: Maybe you have already done some of them above. But please check thalatest status again before printing test from the computer.
Waiting your comments.
Posted on May 25, 2010
    Hi -
    I went through your checklist and am still stuck. The printer has no messages or flashing lights. By all indications at the console the printer is online but is offline from any PC on the network. The faxprinter function is offline as well.
    I can not print a test page from any PC. Our PC operating system is XP.
    PLEASE NOTE: This printer worked well UNTIL we attempted to install/configure the ScanRouter Lite Software to setup the scanner. At some point during that process the printer went "offline". Are you familiar with the Ricoh Aficio Scanrouter setup procedures?
    Thanks
  • 4,281 Answers
First make sure there is not any paper jam inside the printer .
Pull toner and refix it.
Then open back cover of printer and reattach the RAM memory.
Open fuser assembely and make sure roller is working fine and it is not torn.
Also clean dust from all parts.
Also RESET your printer settings to defaults.
Make sure your printer green led flash if it flahs orange is means it is offline but if green led is flash then it is online.
Let me know if you need further assistance.
Thanks for using FixYa.
    The printer appears to be online at the equipment console - green light, no jams, etc. I can print config pages from the console. However, from the desktop via the network, the printer is offline and jobs are queuing up. This condition started when we were working on the setup of Scanrouter software. What should I do from this point?
Print driver (2228C PCL 5C) shows printer queue offline. How can I bring it back online? I have rebooted the printer. There dosen't appear to be an option on the print queue when going in as admin on...
Remove the data cable from the back or size of the printer. Turn the printer on and let it cycle. Then plug back in the data cable. It should show a green light by the cable if you are reconnected.
May 12, 2011 | Ricoh Aficio 2228C Copier
How do I turn off Telnet on a Ricoh Aficio 2020D?
I think that the easiest way is with the WebImageMonitor (Web Interface).
Open your browser and write the IP adress of you machine (ex. http://192.168.x.x/)
Then you must login as administrator.
User: Administrator
PW: password.
Then go to network settings and disable the telnet
Apr 12, 2011 | Ricoh Aficio 2020D Copier
Cannot Print nor Scann with Aficio 1515 PCL
Press the [Printer] button and then the the button under it. It looks like an arrow pointing to the right. Look on the screen it will switch between offline and online/ready depending on the condition of the network.
Aug 21, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Dell printer 1710 n .
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
Jun 12, 2009 | Dell 1710n Laser Printer
Revised IP address for Ricoh 2020d
Go to user tools counter. Go to settings. Go to interface. You should see the IP address settings window. Some Ricohs have auto DHCP. Usually I turn that on to get it to recognize your router. Make sure your gateway address is inserted as well.
Jan 11, 2009 | Ricoh Aficio 2020D Copier
My Ricoh Laser Printer is not working
For to use the network printer first of all you should have a network connection port.
If you have one on your printer than you should install a driver on the computer from where you will print then connect the cable with network LAN cable which the one end is connected into the printer and the other into the network switch or router. After this is done go to start menu on you computer than go to printers and faxes and select the printer driver 1515 press the right click and click on properties then go to port and create a TCP/IP port similar to the computer ip address.
EXAMPLE:
if the address on the computer is 192.168.0.100
than put the address of the printer as follow
192.168.0.101
Please look at the paper sheet which is printed from the machine by her self when the machine is turned on for the first time in the day.
There should have a port name which can be 10001 or 9100 or 9101 or similar.
Enter that number in the TCP/IP port properties than go to the machine and press the [User tools/ Counter] key then go to system settings and than network settings and enter there the ip address which you had enter before on the driver in the computer.
Jun 02, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
78 people viewed this question
k24674
jasbo
jasbo
