Question about Frymaster Dean SR42G Deep Fryer
Black smoke coming out of flue and two burners burn yellow flames while the other burns blue some fumes
  • 77 Answers
First.. the burner tubes need to be cleanes...sounds like a few have soot build up. Messy job...do outside with a hose. Check the burner orifice size to make sure they are all the same.
Tom
Posted on Aug 17, 2010
I have a Gibson gas furnace model gl1ra072c12a, the middle two burners flame are blue both end burners are yellow . All were cleaned. as well as jets what could be the problem?
If the flames are yellow AND lazy, not acting like the two blue flames are, the problem sounds like excess carbon build up within the heat exchanger ABOVE the two yellow burning burners. If that is the case, the yellow burning flames are contributing additionally to the carbon already in there. Eventually, the lazy flames will roll out into the furnace vistibule and possibly burn wiring creating a major problem. There are looooong wire handled bristle brushes 30" long that must be used to thoroughly clean the heat exchanger after the burners have been removed. A shop vac will help greatly in reducing the nasty carbon mess.
Usually, the vent collector hood and flue is removed to brush down from the top and up from the bottom alternately. If there are air shutters on the burners, make sure they haven't been throttled too far down limiting the combustion air causing the original problem.
You need a certified HVAC service tech to look at this issue.
Dec 09, 2014 | Heating & Cooling
Flame burning too orange
You need to get a Plumber or Appliance Tech to come out immediately and check the fuel to air ratio. You are not burning your fuel at the proper mixture. A blue flame is good, yellow-orange is bad.
Normally this is because the burner area is dirty or the pressure regulator may be set too high/low. The black marks are a sure sign that your ratio is too rich and it's just going to build up more soot and become unhealthy and dangerous.
http://inspectapedia.com/plumbing/Gas_Flame_Noise_Defects.htm
Don't wait...
Mar 27, 2014 | Water Heaters
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
What causes carbonmonoxide in a furance
Carbonmonoxide is produce through the combustion products. If you have a crack in your heat exchanger it can spread CO though out your space. VERY VERY VERY VERY DANGEROUS THIS CO WILL KILL YOU!!!!!!!!!
Apr 30, 2011 | Goodman Heating & Cooling
My natural gas heater is putting black soot out all over my walls and ecerything else. Could you tell me what the problem is and what to do about it?
It needs a service asap soot gives off fumes do not use it , It could be blocked air ports on the burner , burner blocked , blocked injector , burning at wrong presure , blocked flue .
Any of these but get it serviced this will all be checked when you have it done .
Feb 12, 2011 | Heating & Cooling
Heater fires up and runs for a few seconds and shuts off think the heat exchanger is filthy would that cause it.
There are several things that can cause this:
Check for blockage in the flue pipe or improper flue design resulting in inadequate venting.
One way to quickly determine a venting issue is to visually observe the flame on the burn tray. It should NOT be yellow and should burn evenly across the burner. There should NOT be any areas of the burner that appear to burned or deteriorated. Look for evidence of leaks,
You may need to dismantle the top section of the heater to visually inspect for sooting.
You may need to inspect the flame sensor mechanism (if applicable) for dirt or sooting.
If it is determined that your exchanger is sooted up, you have a blockage in the flue pipe or improperly designed flue.
Nov 28, 2010 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
When one of the gas hobs is on ,it does not burn with a blue flame but a more yellow one .also black soot forms under the burner plate.it is on lpg
Have to adjust the piolot lights for the amount of gas coming out. U have too much gas coming out(yellow flame). On older gas ranges, there was a small screw between the piolot light & burners that had to be adjusted. (if this is a older model) have to turn the screw just a little at a time, till ur flame returns to blue on ur burners. Hope this helps.
Sep 12, 2010 | Microwave Ovens
On Barbeque side burner it burns with a high yellow flame getting
Try using compressed air to blow out the burner and make sure the gas is turned off when you do it.
Apr 20, 2010 | Grilling
Lots of yellow - then very low heat
Are the flames still yellow? If so the burner just needs to be adjusted which is very easy? Look at the ends of the tubes that come out of the burner and end right at the back of the gas controls. You should see a small piece of metal that will slide or spin to close a hole. You want to close or open it a little at a time while the grill is burning. Adjust this until you only see blue flame or blue flames with a little bit of a yellow tip.
Jun 13, 2009 | Char-Broil Commercial Stainless Steel...
I just replaced the heat exchange unit. It ran ok for a while then after it got up to temperature and shut down it wouldn't turn on again by itself. Fumes. I took off the cover for the burner and could see...
Be careful opening combustion chamber with fumes present. The soot means the gas, or fuel to air mixture is incorrect. The inlet of the burner should have an adjustment that slides. That is an air coke . It may be closed or completly open. Adjust it to a blue flame. Close the combustion chamber when lighting.. If fumes build up, Ther is an explosion hazard when working on heaters. Any type . good luck
May 29, 2009 | Heating & Cooling
Frymaster Dean SR42G Deep Fryer Logo
469 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
